So this issue has been slowly progressing over the past few years, and now it's to the point that I think I should do something about it.
Here's an overview of what's going on:
Starting the engine cold results in an idle around 700rpm, a little bumpy, then if you give it just a little gas, it sounds like it has a lumpy cam idle. If you give it half throttle, it revs up to 3 or 4k rpm, and will act like its got a 2-step and it'll shoot out black smoke like wild.
Once the engine's warm this issue goes away totally, except the idle is about 1300 rpm, and you can tell it's still running rich by the smoke, smell, occasional pop on decel, and the fuel economy has dropped significantly it seems.
Here's a video demonstrating the issue while cold.
https://youtu.be/IlMomAjrDpw
Making this thread party for help, partly because it sounds so cool when my engine does this, even if it is so bad for it, like it sounds like it might be...
But it's worth mentioning the valves are at like .02-.025"
It will be interesting for the record, what changes when I get those valves back in spec.
Maybe that's all this is. But I also wanted to share that video. Enjoy
