940 M90 clutch setup 500whp+
stonie
Switzerland
Sure somewhere are still some threads about this but with my english i dont know how to search!?
what clutch setup is good enough to handle 500whp+ and 600nm torque.
searching for a "normal" clutch with torsion springs and single disc.
flywheel? dogdish?
Links to threads are welcome.
Sachs -712 PP, some kind of 4/6puck sinterclutch disk and a flywheel that fits (standard dogdish with a litte bit of work).
Almost bolt-on solution
I'd recommend the ttv flywheel that is made for the 707 and 765 with use of the 850 style clutches. I love my lightweight flywheel from ttv with the 850R clutch.
flywheel? dogdish?
You sure you have 600n/m?
228mm STAGE IV - Handles 420 ft. lbs. of torque with stock disc.
Good price and matches nice steel flywheel with 60-2.
That combo is less that the crazy ass Sachs Racing pressureplates in EU.
had 630nm at 1.4 bar of boost with 9.5:1 compression now im going to 8:1 compression and about 2.2 bar of boost.
so 600nm is what the clutch should hold for sure...
thanks for your reccommendations
