Marvelous3
Who engineered this?
- Nov 12, 2002
- Atlanta
I can basically make it do it on command. Anywhere between 20-45mph if I turn the wheel to the right about 15 degrees or to like 2 o'clock it I hear this wub wub wub noise come from the front passenger side wheel. I put powerstop slotted rotors on it a little bit ago and after that install it when I noticed it. It does not do it on the other side which makes me thinks it's not the rotors. The sound will also stop if I put the brakes on. Wheels are torque to spec so the wheel and rotor are on tight.
Loose wheel bearing or just the slotted rotor catching some air and making noise? It seems to drive fine otherwise. Ideas?
