Old 09-12-2018, 11:23 PM   #2101
LC4CARL
Aero challenged
LC4CARL's Avatar
Originally Posted by vwbusman66 View Post
Man, I can't wait until you realize that you really need the extra power of a B234FT with a Holset backed by a T5.
I really love this thread. I wish I was this thorough with my own projects.
@PDXvolvo on IG
Old 09-12-2018, 11:29 PM   #2102
LC4CARL
Aero challenged
LC4CARL's Avatar
mrak,
Your advice is much appreciated. I hope to sort this out this weekend. Yes on the turbo dizzy. Iíve heard of some modification that can be done on these, but canít find the thread.
Old 09-13-2018, 12:08 AM   #2103
https://forums.tbforums.com/showthread.php?t=218855
Old 09-13-2018, 03:02 PM   #2104
LC4CARL
Aero challenged
LC4CARL's Avatar
Thx!
I had fun playing with an MSD on my Chevy years ago.
Old 09-15-2018, 01:24 PM   #2105
MrBrown
MrBrown's Avatar
This!
Originally Posted by KeizerBrickGuy View Post
No clue on the storm, they're still considering sending me back out for fires. LOL
Good ol SAD. Iím still correcting the mess with everyone we sent out.
GhettoFab build thrizzie
Old 09-23-2018, 10:57 AM   #2106
LC4CARL
Aero challenged
LC4CARL's Avatar
I want to send out a huge thanks to all my buds that have helped me with advice on the engine swap. Truly could not have done it without you. Through the ups and downs, I've learned a ton and strengthened friendships. What a great hobby. Hope it starts...
Old 09-23-2018, 02:21 PM   #2107
soclosenotnear
Put it all together and didn't turn the key? What's left to do? So much anticipation.
check my feedback here
Old 09-23-2018, 02:40 PM   #2108
JW240
All idiot, no savant
Looking good! Fingers crossed tho im sure it runs first try.
240 | 1991 | 345K Km | B230F+T | Cosworth T3 60/63 | M90 | TrueTrack (parked for a few months)
dd: 940 | 1992 | B230FB
Old 09-23-2018, 03:32 PM   #2109
LC4CARL
Aero challenged
LC4CARL's Avatar
Getting close. Alternator in this morning. And now we understand why remote oil filters are so popular. Gauges hooked up last night (except wide band that needs a bung). Hope to pre-lube today and check for leaks. One more care package from DO88 due tomorrow. Then splice MAF harness.
Old 09-23-2018, 03:44 PM   #2110
LC4CARL
Aero challenged
LC4CARL's Avatar
Oh, and wire the distributor.
Old 09-23-2018, 11:17 PM   #2111
LC4CARL
Aero challenged
LC4CARL's Avatar
Old 09-23-2018, 11:26 PM   #2112
Oil filter motor mount. Mint.
Old 09-23-2018, 11:27 PM   #2113
Jack
junkman
Jack's Avatar
Eww that should be marked with a warning. Why not pressure wash?
I love you even more Jack.
Donít bother, I would literally rather throw them away than give you the pleasure. I will never sell to you.
Old 09-24-2018, 12:17 AM   #2114
LC4CARL
Aero challenged
LC4CARL's Avatar
March of Ď16. One of my earliest photos of the car.
Old 09-24-2018, 01:57 PM   #2115
LC4CARL
Aero challenged
LC4CARL's Avatar
Any suggestions for the BOV?
Old 09-24-2018, 02:27 PM   #2116
thessejway
Wannabe TBer
thessejway's Avatar
Go for elk
thessejway is offline   Reply With Quote
Old 09-26-2018, 09:33 PM   #2117
LC4CARL
Aero challenged
LC4CARL's Avatar
Does anybody know where to plug the coil into the ecu so it gets an RPM signal and runs the fuel pumps?
Thx.
Old 09-26-2018, 10:42 PM   #2118
bobxyz
bobxyz's Avatar
Did you replace and rewire the K-Jet fuel pump relay with a LH2.2 setup? If not, the red/white tach wire from the coil goes to the K-Jet fuel pump relay and turns on the pump when it sees cranking.
Old 09-26-2018, 10:49 PM   #2119
The car is all LH2.2/Mopar. He's having trouble figuring out the RPM signal. On the phone now.
Old 09-26-2018, 11:28 PM   #2120
LC4CARL
Aero challenged
LC4CARL's Avatar
Injector rail off. Tried jumping from negative coil to a variety of connections. No gas. Pumps work properly if jumped at the fuse box.
Old 09-28-2018, 12:31 AM   #2121
LC4CARL
Aero challenged
LC4CARL's Avatar
Hooked up the old Mopar wire harness. More or less. Swapped 240 / 740 ecu Ďs. Had intermittent fuel spray. It sort of tried to start. No spray right now. Iím lost.
Old 09-28-2018, 02:35 AM   #2122
John242Ti
LH-Jet & Carb Free Zone
John242Ti's Avatar
Beginning to think that EZK might be a better option than Breakerless. Especially since the car was originally an LH 2.2/Chrysler car to begin with. I had enough issues trying to get a B23F swapped '85 245DL running, and I only went from LH 2.2/Chrysler to LH 2.0/Chrysler. Would try to run once in a blue moon while cranking it over. Harness on the B23F was in better shape than the harness from the B230F, otherwise, I would've stuck with 2.2 and had a running car with oil pressure.
I also would not plan on driving the car to Tacoma on Saturday. Better to catch a ride with one of the other guys or to bring the BMiniW instead and just park in the normal customer parking lot area. There's a reason why I didn't bring the 245 down to iPd. Knew that something might happen on the trip down or back and didn't want to chance it. So, I took the Exploder.
@john242ti on IG
Old 09-28-2018, 03:59 AM   #2123
mrak
Beefsma by Design
mrak's Avatar
Thx.
Yeah it's coil negative into the grey wire that sits underneath the intake. It's a double plastic spade. one side is the orange wire that comes from the TPS #2 and runs to the ecu, and the other side is a grey wire. The grey one is the one you want.
I feel like I basically did the same swap you did, except I had a 2.0 car, that I converted to 2.2 with a 2.2 harness. Then did a +t with breakerless ignition, until I went EZK.
mrak is offline   Reply With Quote
Old 09-28-2018, 10:53 AM   #2124
LC4CARL
Aero challenged
LC4CARL's Avatar
Awesome. We are close.
Old 09-28-2018, 10:26 PM   #2125
LC4CARL
Aero challenged
LC4CARL's Avatar
You stud.
She runs!!!
