Old 10-24-2018, 04:42 PM   #2276
Originally Posted by mocambique-amazone View Post
Valve cover?
Plug if distributor hole at the end of the head?
Pan gasket maybe
RMS, the flywheel seems dry
LS-swap: way to easy
Good luck, Kay
Old 10-24-2018, 05:15 PM   #2277
LC4CARL
Aero challenged
LC4CARL's Avatar
Told ya to pressure wash it too.
@PDXvolvo on IG
Old 10-24-2018, 05:17 PM   #2278
LC4CARL
Aero challenged
LC4CARL's Avatar
Originally Posted by brendon_ak View Post
It really doesn't look that bad with regards to how much oil there is, chances are it's coming from somewhere up high on the motor and seeping down the block. Grab some brake clean and a rag and wipe it all down then heat cycle the motor to see if that gets you some better results.
Yeah, may grab some of that black-light dye too. Only got maybe 100 miles on it. Underside of trans is coated.
This too shall pass.
Old 10-24-2018, 11:16 PM   #2279
brendon_ak
Trans coated with engine oil? Do you have a full exhaust on there? When I had my open DP and oil leaks, tons was coming out and getting blown all over hell by the exhaust.
Old 10-25-2018, 12:47 AM   #2280
LC4CARL
Aero challenged
LC4CARL's Avatar
Yep, full exhaust.
Been thinking about the pcv. On my old domestic vehicles there was a filtered air intake routed to one valve cover and an “exhaust” (pcv) on the other. On the Volvo we exhaust the crankcase through the flametrap, but is there a crankcase “intake?” Or, assuming zero blow by, would it draw a vacuum on the sealed crankcase?
Old 10-25-2018, 01:25 AM   #2281
brendon_ak
Isn't the engine an air pump? So if the case can vent then your vacuum on an NA engine should come from the intake side, no? Or am I not getting it?
Old 10-25-2018, 11:28 AM   #2282
Originally Posted by LC4CARL View Post
Yep, full exhaust.
Raw unburned oil fouls catalytic converters and makes emissions skyrocket. That's why crankcase vents are put on the intake nowadays.
Putting the outlet of the PCV valve on the exhaust stream creates a strong venturi effect. The hole itself is located in a strong low pressure area; so the more exhaust stream there is, the more engine vacuum you will have. It is terrible for emissions, as above.
Old 10-25-2018, 11:48 PM   #2283
LC4CARL
Aero challenged
LC4CARL's Avatar
I checked the Bentley, it looks like the Redblock has a “sealed” PCV. I also read that the turbo cars don’t use the flame trap. Can I remove it? IPD says it’s to: “protect against possible crankcase explosions due to a backfire.” This must be an intake side backfire. And with the turbo, the vacuum line is separated from the intake by the turbo.
Old 10-26-2018, 12:53 AM   #2284
LC4CARL
Aero challenged
LC4CARL's Avatar
Further thoughts: does the aftermarket catch can do the same thing as the factory oil separator (flame trap box)?
Old 10-26-2018, 01:26 PM   #2285
bobxyz
bobxyz's Avatar
I was looking at the turbo PCV system in detail while putting my '85 B21FT back together. The "flame trap" or "flame arrestor" is the mesh screen that prevents fire (e.g. intake manifold backfire) from getting into the block. On high proof alcohol (everclear, 151 rum) there's a flame trap on the opening to prevent accidents:
In the non-turbo setups, the flame trap is a plastic mesh within the PCV lines. In the turbo setups, the mesh isn't needed (not quite sure why). The vent off the oil separator gets split into a bigger line to the pre-turbo intake hose, and a smaller line to manifold vacuum. Some posts say that the manifold vacuum line isn't needed.
The breather box drains directly back into the block. The catch can gets what's left over (or could replace the breather box if the catch can drains well to the block).
Old 10-26-2018, 01:54 PM   #2286
oldschoolvolvo
oldschoolvolvo's Avatar
Essentially yes...both are intended to condense oil out of crankcase vapors and drain the oil back to the block and route the vapors back to the intake in order to burn them during normal combustion.
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
Old 10-26-2018, 03:19 PM   #2287
John242Ti
LH-Jet & Carb Free Zone
John242Ti's Avatar
The B21FT does not use a vacuum line. Fitting has a vacuum cap installed. Only the B23FT/B230FT engines have one, but the housing is still empty. On the past five B21/23FT engines I've had, the trap housing was deleted with the breather hose connected directly to the breather box and going to the elbow just after the airflow sensor assembly. First engine I dealt with that had that setup was a dealer-maintained B21FT installed in a 1-owner 1982 242T. Did the same on the B23FT that was swapped into it, and have done the same on subsequent K-Jet turbo engines. No problems.
@john242ti on IG
Old 10-26-2018, 04:15 PM   #2288
bobxyz
bobxyz's Avatar
^^^ Thanks John, that really helps make sense of the conflicting info I've seen -- why the flame trap housing with split big/small nipples is listed for B21FT, and why my old one had the small nipple melted/glued closed. Any idea why the B230FTs use the small nipple with a manifold vacuum line?
Old 10-26-2018, 06:14 PM   #2289
LC4CARL
Aero challenged
LC4CARL's Avatar
Great stuff. Will have to check my booze next time I serve a Flambé.
Old 10-26-2018, 06:18 PM   #2290
LC4CARL
Aero challenged
LC4CARL's Avatar
Interesting between, what I call, an "open" and "closed" PCV system. Visible on my old truck (way left) is the crank "intake" (K&N on passenger VC). I suppose on some level this could influence the air / fuel ratio. Perhaps that's what the PCV valve (PCVV?) is for?
Old 10-26-2018, 08:55 PM   #2291
culberro
culberro's Avatar
On the rally car PCV system, I made it more like a "normal" pcv system.
I drilled a small hole (1/8in) in the bottom of the oil cap. I then disassembled the cap, and stuffed it with filter foam. Stock oil box to catch can, then catch can to the pipe right after the air-filter.
This allows filtered air to travel through the cap, all the way through the engine, both oil separators, and then it get's a slight vacuum pull into the intake. Kept it really clean and worked well.
You can also add a restricted barb and tee the last breather into the intake manifold to pull even more vacuum, but if there's a leak anywhere in the system it'll throw off the fuel metering if using a MAF.
Old 10-26-2018, 11:17 PM   #2292
LC4CARL
Aero challenged
LC4CARL's Avatar
That sounds neat.
Old 11-01-2018, 10:42 PM   #2293
LC4CARL
Aero challenged
LC4CARL's Avatar
I like:
https://www.corsasteelies.com/
Old 11-01-2018, 10:50 PM   #2294
Stance the wife's Mini.
Old 11-01-2018, 11:42 PM   #2295
LC4CARL
Aero challenged
LC4CARL's Avatar
That’s cool.
Old 11-02-2018, 12:42 AM   #2296
That’s cool.
Old 11-02-2018, 01:05 AM   #2297
LC4CARL
Aero challenged
LC4CARL's Avatar
I cannot imagine the MINI being any lower.
Old 11-02-2018, 01:49 AM   #2298
Buy her some dope AF corsa steelies for christmas?
Old 11-03-2018, 09:28 AM   #2299
LC4CARL
Aero challenged
LC4CARL's Avatar
Funny how steel rimpz have come back to some extent. I recall Corvette rally's being the hot ticket in school. Still a nice looking set up. Nice that the aftermarket has brought out modern sizes on the old school stuff.
Old 11-03-2018, 10:31 AM   #2300
Used to be you had to weld heavy barrels from trucks to your hubs or band them, and screw with the offset.
