Old 03-04-2019, 07:45 PM   #2451
LC4CARL
Aero challenged
LC4CARL's Avatar
Well cool. I'm sure that those Split-Fire spark plugs are where I made my gains.
@PDXvolvo on IG
Old 03-06-2019, 09:39 PM   #2452
LC4CARL
Aero challenged
LC4CARL's Avatar
Snow DL!
Old 03-06-2019, 10:43 PM   #2453
quillc
yv1a.com
quillc's Avatar
Nice dyno pull!
Cam ran out of breath. Need more cam.
Chris
www.yv1a.com
Old 03-07-2019, 12:49 PM   #2454
Originally Posted by quillc View Post
Nice dyno pull!
Cam ran out of breath. Need NPR 27 row.
fifty
Old 03-07-2019, 02:39 PM   #2455
LC4CARL
Aero challenged
LC4CARL's Avatar
The factory IC is so large. Is it a restriction with my tiny blower? May explain why it went rich on top.
Old 03-07-2019, 03:31 PM   #2456
culberro
culberro's Avatar
Or it's leaking, causing it to go rich. I might be swapping out the NPR for something bigger in the next few weeks. Let me know if you're interested.
Old 03-07-2019, 05:51 PM   #2457
LC4CARL
Aero challenged
LC4CARL's Avatar
Do chicks dig NPR's?
Pls keep my number. Should work great with my top-mount and anti-lag set up.
Old 03-07-2019, 05:53 PM   #2458
LC4CARL
Aero challenged
LC4CARL's Avatar
So stupid busy with work. Drove 4k miles last month. Snow damage claims like crazy. 12 hour days. ARRRRrghh!
Rant over.
Old 03-07-2019, 06:41 PM   #2459
culberro
culberro's Avatar
Chicks don't care, but you should notice an immediate improvement if you're running north of 10psi on a smaller turbo. Especially if the old intercooler was leaking at all.
Old 03-07-2019, 07:39 PM   #2460
LC4CARL
Aero challenged
LC4CARL's Avatar
Suhweet!
Old 03-08-2019, 11:30 AM   #2461
LC4CARL
Aero challenged
LC4CARL's Avatar
Five 240's at the local JY. One is a factory turbo.
Race you there...
Old 03-08-2019, 12:45 PM   #2462
Damn. 242 GLT. I can here many swedes crying out loud across the ocean.
Carl, if you go to the Sherwood yard, can you give me a call when you get to this one? I need a few interior bits...
Old 03-08-2019, 03:53 PM   #2463
LC4CARL
Aero challenged
LC4CARL's Avatar
You bet!
Old 03-08-2019, 03:57 PM   #2464
LC4CARL
Aero challenged
LC4CARL's Avatar
Got the Row 52 email this morning. Ran over when the yard opened. And....
She was picked clean.
I did grab the ignition box for a spare. And I met a couple of fellow Brickers which was nice.
I yanked the turbo. I could feel that the shaft had some play. But when I looked inside I was bummed.
I took it to the counter and they quoted $117. Pass.
Not my best day.
Old 03-08-2019, 04:17 PM   #2465
cwdodson88
But you left the map pockets!
The Build Thread
SVEA - PUSHROD TURBO!
Old 03-08-2019, 04:21 PM   #2466
LC4CARL
Aero challenged
LC4CARL's Avatar
Ha. The passenger side was mint! I let a guy with a tan car have it.
Sad to see a neat little car like this go to pieces.
Old 03-08-2019, 04:45 PM   #2467
:grrr
Not my best day.
Old 03-08-2019, 05:27 PM   #2468
LC4CARL
Aero challenged
LC4CARL's Avatar
You want me to snag that FT for you? It's pan to pan...
Old 03-08-2019, 07:21 PM   #2469
Local only?
Old 03-08-2019, 10:12 PM   #2470
LC4CARL
Aero challenged
LC4CARL's Avatar
Old 03-09-2019, 06:25 PM   #2471
LC4CARL
Aero challenged
LC4CARL's Avatar
Note to self: don’t leave wet hand tools in gear bag overnight.
Old 03-09-2019, 11:41 PM   #2472
LC4CARL
Aero challenged
LC4CARL's Avatar
My tach has been in the fritz for sometime. Seemingly it would only work when warmed up. Even then it was intermittent. I recently picked up a 9800 speedometer cluster at the JY. After juggling parts several times, I ended up with the JY case, a spare 6k tachometer, the speedometer I was using, and the temp faker by pass. On my ten minute drive tonight everything worked. We’ll see.
Old 03-10-2019, 01:38 AM   #2473
LC4CARL
Aero challenged
LC4CARL's Avatar
https://www.ebay.com/itm/1981-1982-V...UAAOSwCnpcgia3
I found the dash from PNP 242. Grrr.
Old 03-11-2019, 07:18 PM   #2474
77volvo245
77volvo245's Avatar
crack whore price
STSmachining
Old 03-12-2019, 09:10 PM   #2475
LC4CARL
Aero challenged
LC4CARL's Avatar
My niece digs Volvo’s.
