Old 03-09-2019, 07:24 PM   #1
tshawytscha
Default Attn PDX tbrickers: need an injector!
So, figured I'd do some maintenance it being a nice sunny day. Was going about replacing injector seals and dropped an injector and broke the plastic tip area. If it ain't broke break it right? I'm assuming that means it's shot. Are there any locals that have a spare greentop injector laying around that they'd be willing to sell me?
tshawytscha is offline   Reply With Quote
Old 03-09-2019, 07:29 PM   #2
sbabbs
sbabbs's Avatar
I got plenty out here in Scappoose. But is the little pointy thing on the bottom of the injector bent? If not it might be okay. You don't need that plastic bit on the bottom at all I don't think. Seems like I had to take those off the ford browntops to make them fit, or to put new injector seals on the bottom.
Old 03-09-2019, 07:29 PM   #3
https://www.picknpull.com
Old 03-09-2019, 07:32 PM   #4
sbabbs
sbabbs's Avatar
YEah there is a picky pull in vancouver still in business, way closer.. That being said do they have a turbo 740 or 940 in the yard?
Old 03-09-2019, 07:34 PM   #5
sbabbs
sbabbs's Avatar
Found this, says it's 16v.. No greentops then..
Pick-n-Pull - Tumwater
8010 Old Highway 99 SE • Tumwater, WA 98501 360-357-4466 Store Layout Map|Part Pricing
Engine 2.3L L4 DOHC 16V
Trans 4-Speed Automatic | 5-Speed Manual
Color WHITE
Set Date
1990 Volvo 740 Wagon 20 02/5/2019
Old 03-09-2019, 07:46 PM   #6
tshawytscha
The metal tip does not look bent. Good to go?
https://photos.app.goo.gl/5y1igKJbyQZbSB7x7
Old 03-09-2019, 07:49 PM   #7
sbabbs
sbabbs's Avatar
Yes your fine.
Old 03-09-2019, 07:55 PM   #8
tshawytscha
Sweet. Thanks guys.
Old 03-09-2019, 08:00 PM   #9
An injector seal kit will come with a new pintle cover.
https://www.rockauto.com/en/partsear...um=+1287010704
Old 03-09-2019, 10:52 PM   #10
mblue240
mblue240's Avatar
I have all these down in Beaverton. I also have part of a rebuild kit left over and you're welcome to have the little cap.
https://forums.tbforums.com/showthread.php?t=301784
-Michael
Tbricks build
Yep, Michael is right.
