Old 03-14-2019, 08:12 PM   #1
Patestrickland
Patestrickland's Avatar
Question 240 Steering shake
Hey guys. Iím back again with another problem with my 240. So the steering shakes really bad when going hwy speeds (60-70) and I just canít figure out why. Iíve replaced the rack, the tie rods (both inner and outer), new ball joints, and a new lower steering shaft u joint. What else could possibly be causing my steering wheel to shake so badly?
Patestrickland is offline   Reply With Quote
Old 03-14-2019, 08:15 PM   #2
Patestrickland
Oh yeah also the wheels have been balanced and it has just had an alignment.
Old 03-14-2019, 08:19 PM   #3
Are the front wheels straight?
Old 03-14-2019, 08:21 PM   #4
Patestrickland
You mean straight as in no dents?
Old 03-14-2019, 11:10 PM   #5
NotSoFresh
Sick ****** T-Brick Prick
NotSoFresh's Avatar
Switch the front wheels and the back and see if the behavior changes.
Also, are the bushings good?
Old 03-15-2019, 07:17 AM   #6
DET17
Reformed SAABaholic
Balance likely not your issue. Have your tires inspected for a "belt separation". If you have one of these little darlings up front it will shake like a disco at 65mph.
Next question: was there an event the initiated this behavior?
Old 03-15-2019, 08:02 AM   #7
Straight as in runs true?
Old 03-15-2019, 10:21 AM   #8
NotSoFresh
NotSoFresh's Avatar
If you switch the fronts and rears, and the vibration moves to the rear, it is one of those two. Now switch just one side front to back. If the vibration changes back to the front, the wheel you just put there is at fault. If the vibration does not change, the suspect wheel is the back one you didn't move the second time.
This can find either a bad tire or wheel. If you find a bad tire, replace them all.
If none of the tire swaps changes the vibration, you got something else going on.
Like loose wheel bearings or bad bushings.
It is also possible that you have cooked torque rod bushings and at highway speeds you are getting a driveline harmonic shake due to bad pinion angle. Bad torque rod bushings can take out driveshaft center supports, u-joints and output/input bearings if left too long. I have also had this happen in a car.
Get under the car with a pry bar and make sure stuff that should not move doesn't, and stuff that should move only moves in the direction intended.
On an old car I had the big crossmember bolts down beside the engine come loose and needed torquing. That car shook a bit til i fixed it.
Old 03-15-2019, 10:46 AM   #9
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
Virgos are no longer round.....
1980 242 Turbo
2004 V70R
Old 03-15-2019, 12:33 PM   #10
JohnLane
Virgos are quickly and easily bent by tire shop clowns who are unaware that they have to be mounted/dismounted with the face of the wheel facing down.
Old 03-15-2019, 05:57 PM   #11
vwblue1967
vwblue1967's Avatar
I had old tires that gave me the steering wheel shakes at highway speeds, they were worn but ive def seen worse. I was looking into steering u-joints and a rack but new tires and its smooth sailing.
85 245 - ipd sport springs and sway bars yoshifab torque rods, kaplhenke bne strut mounts and TAB's. Poly bushings Bilstein tourings. B cam +4. 2.25 exhaust.
93 244 stockish.
vwblue1967 is offline   Reply With Quote
Old 03-21-2019, 04:31 AM   #12
Otto Mattik
Otto Mattik's Avatar
Had at least one 205/60-15 Firestone do this, vibration typically happened under load at 65/70+
Originally posted by Jack
_________________________
Old 03-21-2019, 10:51 PM   #13
philski o'flood
philski o'flood's Avatar
is it like a side-to-side or an up and down?
Old 03-22-2019, 12:16 PM   #14
A tough rowing ho
How much pressure are you running in the tires?
Old 03-22-2019, 12:26 PM   #15
Get the wheels and tires road force balanced.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
