Old 01-27-2019, 09:21 PM   #1
LC4CARL
Aero challenged
LC4CARL's Avatar
Default Cuts out on accel
I submit to your superior wisdom, intellect and breeding, the following drive-ability concern:
The car:
'87 245 / M47 / B21FT swap. 740 turbo box, diverter valve routed back to intake, 3.0 bar regulator, breakerless distributor, LH2.2, orange tops.
The condition:
Generally runs great. 8 psi max. On occasion, in high-gear, at highway speeds, a light tip into the throttle yields a momentary engine "cut out." Like the fuel or ignition has been momentarily switched off, then on. It never feels like it's going to stall. But it is quite apparent to the occupants that there was a "hiccup." It's been happening for about six months now. This is a fairly repeatable condition. It does not occur under heavy throttle.
Thoughts, ideas?
Life begins at 10PSI.
Old 01-27-2019, 09:34 PM   #2
2turbotoys
Salaminizer
2turbotoys's Avatar
I'm no 2.2 expert, my first thought is throttle position sensor adjustment? I'm sure someone will have better ideas but I would check that
2006 V50 T5 AWD 16 PSI +
Old 01-27-2019, 09:41 PM   #3
Cwazywazy
Cwazywazy's Avatar
I'd start with cleaning the MAF. In the winter my car would do that occasionally, regardless of throttle position. Sometimes it'd happen in the summer if the engine was still cold. Never figured it out.
I don't know what I have
Old 01-27-2019, 09:45 PM   #4
Pro Sneaker Peddler
Start here: https://volvoforums.com/forum/volvo-...eration-45060/
Old 01-28-2019, 08:01 PM   #5
LC4CARL
Aero challenged
LC4CARL's Avatar
Much appreciated guys. I'll keep you posted. 90 days to Davis. GO!
Old 01-29-2019, 12:18 AM   #6
LC4CARL
Aero challenged
LC4CARL's Avatar
Played with the TPS. The 2.2 seems to be a basic idle and wide open affair. Swapped in my spare 007.
I wish I had a better sense of whether it is an ignition or fuel problem. With the old style “batch fire” EFI, it’s all or nothing.
Drive it tomorrow. Keep reading.
Old 01-29-2019, 02:22 AM   #7
LC4CARL
Aero challenged
LC4CARL's Avatar
591 vs 541?
Old 01-29-2019, 03:19 PM   #8
Mbeas96
Mbeas96's Avatar
Ive had this same problem except with lh2.4. My wideband reads super rich when this happens.
Ive played with the tps as well to no avail. I've done/checked a laundry list of things, and it seems to be coming down to either o2 sensor or fuel computer.. Let me know when you figure your problem out!
Old 01-29-2019, 07:41 PM   #9
2turbotoys
Salaminizer
2turbotoys's Avatar
I had to set my TPS with a multimeter once to get rid of a similar problem. For some reason it just wanted absolutely perfect positioning. THis was odd but it worked. (LH2.4) Not saying that's the problem but it was doing a very similar thing.
Old 01-29-2019, 09:04 PM   #10
15A
World's Oldest Brewery
15A's Avatar
What shape are the intake hoses on the turbo in? They're known to get tired and collapse. I also had a similar issue with a cat that was plugged / going bad.
A long shot....if you're using the 700 airbox? was there any of that gawd awful foam still glued into the lid?
(IF YOU WANT ME TO LEAVE YOU FB AFTER THE FACT, JUST SAY)
I didn't sleep well last night so I made my coffee this morning with Red Bull instead of water.
I got halfway to work before I realized I forgot my car.
15A is offline   Reply With Quote
Old 01-30-2019, 02:30 PM   #11
LC4CARL
Aero challenged
LC4CARL's Avatar
Hoses are new. Cat is, well, installed. TPS and MAF worked OK with B230. Obviously the B21FT install changed everything. A fairly repeatable condition: high gear, light "roll on" of throttle equals "buck." Feels like a momentary suspension of either spark or fuel. Hope to have wide-band hooked up sooner than later. Perhaps a clue lies there.
Old 01-30-2019, 04:15 PM   #12
300+hp on the shelf club
What does your boost gauge do when this happens? I mean is this happening as it transitions from a n/a engine to boost? If so there is enrichment that should be happening and also the spark needs to be very strong. Air leaks can be sneaky, too. so it can't hurt to double check. All of those things would affect the transition alot. The wide band would let you know more as you are going to find out.
Since you are in hgh gear it would seem to suggest a momentary spark blowout. High gear steady state and then making boost is a very tough situation with a high gear load about to become much more. Try a .026 plug gap. What type of plug are you using? Coil and powerstage connections clean and tight? Good heat sink goop on the powerstage? It may be that something like the coil or powerstage just aren't up to snuff anymore. I'd check the secondary resistance of the coil as well.
I like your swap the best! Only thing I'd do different is LH2.4 or megasquirt.
Old 01-30-2019, 06:13 PM   #13
LC4CARL
Aero challenged
LC4CARL's Avatar
Old 01-30-2019, 06:23 PM   #14
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
Hmmm, what about in tank pump stuff?
The in tank pump does tons of work, and the piece of hose between the pump and the sending unit could go bad and cause odd things to happen, especially when it warms up and under boost...
I had a weird stumble during throttle onset in a LH22 car, turned out the intank was clogged, and the piece of hose went bad like two days after I changed the pump
For the record I was able to tell something was up with the hose when the car ran terrible below about half a tank of gas where the hose would be exposed to air, and suck that up instead of fuel.
1980 242 Turbo
2004 V70R
Old 01-30-2019, 07:03 PM   #15
LC4CARL
Aero challenged
LC4CARL's Avatar
Test drive!
Got in about 10 miles. Car runs great (well...). Cruising at highway speeds 60-70 mph. Light throttle. Only cut out once. It actually surprised me as I had given up intentionally trying to recreate the condition. On a mild grade, 65 mph, at little to no boost.
This is pretty typical. It may only happen every 10 miles or so.
Old 01-30-2019, 07:07 PM   #16
LC4CARL
Aero challenged
LC4CARL's Avatar
Worth a look. The two pumps are a year or two old. Just regular NA stuff though. New plastic line from chassis pump to motor. New / used 3.0 bar FPR.
Ever since I cut those springs...
Old 03-09-2019, 08:06 PM   #17
LC4CARL
Aero challenged
LC4CARL's Avatar
Made it to the coast and back. About a three hour drive. Only “glitched” once or twice. Grabbed an ignition box from the JY and put that in. We’ll see.
