Old 03-02-2019, 03:52 AM   #1
940Viking
Default What is this "hole" for?
Engine is B230fk in 1995 940 estate.
It was on the exhaust side at the back which connects to the gearbox.
B230FK - 95 940 https://imgur.com/a/gqkxwsw
Any help would be appreciated.
940Viking is offline   Reply With Quote
Old 03-02-2019, 04:34 AM   #2
Wilford Brimley
LOCAL ONLY
Wilford Brimley's Avatar
Gloryhole.
94 940T "Deb" build under way http://forums.turbobricks.com/showthread.php?t=354303
B5.5 passat wagon, low af sexier than most wagons here.
Old 03-02-2019, 05:33 AM   #3
petiww
petiww's Avatar
It was a for a diagnostic rpm pickup sensor.
1980 Brown 244 GL
Old 03-04-2019, 01:17 AM   #4
MasterBlaster
Probably used to look like this:
(No, you don't need it)
http://www.turbobricks.org/forums/sh...d.php?t=250487
493,000 km so far...
Old 03-04-2019, 08:51 AM   #5
Here's looking at you kid
I keep thinking about using this sensor with MS as the cam signal so I can run wasted spark.
"i will destroy all of you!"
-Sheldon Plankton
Booty Scooty
https://youtu.be/i4oAOZ8nbq4
Old 03-04-2019, 10:39 AM   #6
JohnMc
JohnMc's Avatar
Not to nitpick, but you don't need a cam sensor for wasted spark - and you'd need something turning at half speed, like a cam.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 03-04-2019, 10:59 AM   #7
Yeah you're right, it would hit that sensor 2x per combustion event. I'm trying to buy a DSM CAS setup right now. I'm getting intermittent signal drop outs from my 2.2 distributor, I'm just tired of screwing around with it. It was a weak link before with EZK, it just transferred it's issues to the microsquirt. I'm thinking it's the pickup itself because when it drops out I can downshift and everything comes back to life with the higher rpms.
Old 03-05-2019, 05:43 PM   #8
shellshock
Below, is a photo of Clay
shellshock's Avatar
IIRC, the sensor there in the 2.2 stuff was strictly for diagnostics, right?
1988 740 Turbo
2005 S60R M66 flashcama
2007 XC90 V8 Sport
1983 SAAB 900 Turbo
shellshock is offline   Reply With Quote
Old 03-06-2019, 05:08 AM   #9
Yes it was, I have a microsquirt though that could probably decode that sensors rpm signal. I'm using the 2.2 distributor for that signal now.
Old 03-11-2019, 09:17 PM   #10
rom
rom's Avatar
the seks.
Religious people scare me.
rom is offline   Reply With Quote
