Old 03-04-2019, 01:09 PM   #1
ODDmanout
ODDmanout's Avatar
Default weird Billy Idol
My idle does not want to stay still, kinda like Billy Idol's lip snare. I have a 86 740 non-turbo.
During a cold start it will idle up to 1,100 or so like it should. After a minute or so it cranks up to 1,500. then will back down to 900 or so after a few minutes. Once in gear, it is an auto, it is fine and stays with in Volvo mandated idle.
So, A\C relay? If i could fine the hiding bastard?
Idle control valve? Should I Blast it?
Thanks!!
ODDmanout is offline   Reply With Quote
Old 03-05-2019, 05:44 PM   #2
shellshock
Below, is a photo of Clay
shellshock's Avatar
Have you tired to pickup the signal from David Bowie's nipple antennas?
But anyway, Year make and model?
1988 740 Turbo
2005 S60R M66 flashcama
2007 XC90 V8 Sport
1983 SAAB 900 Turbo
shellshock is offline   Reply With Quote
Old 03-05-2019, 11:33 PM   #3
ODDmanout
ODDmanout's Avatar
It is a 1986 740 non turbo
Old 03-06-2019, 07:40 PM   #4
ODDmanout
ODDmanout's Avatar
BUMP
Old 03-08-2019, 09:08 PM   #5
moustacio
Hey there,
I'm no authority but hopefully this will get things going at the least.
Yeah cleaning the IAC is easy so I would, and if nothing else you get some gunk out of it. And pulling the fuse to stop the a/c from kicking on would let you rule that out or not. Probably other ways to test but.
Maybe check out the tps and a quick throttle body cleaning.
Hopefully others will have more experienced advise but it could be a variety of things
moustacio is offline   Reply With Quote
