Old 03-05-2019, 08:46 PM   #1
volvofan1990
volvofan1990's Avatar
Default What Are Your Go-To Junkyard Snags?
I went to the junkyard today after a few months absence, and I was blessed with finding a 100% complete 740 turbo in the yard. I pulled all 4 hydras (Only 20 a piece!) but it was too damn cold, so I hightailed home with my finds.
I am debating going back tomorrow to pull some worthwhile parts. I recently acquired a turbo car myself, and am still figuring out what parts are important and what are not. What are some of your go-to's?
You're a sick man, or a glutton for punishment I don't know which, maybe both?
volvofan1990 is offline   Reply With Quote
Old 03-05-2019, 09:53 PM   #2
All the Kool-aid.
All of it.
Old 03-05-2019, 10:58 PM   #3
Mr. V
Mr. V's Avatar
Relays
Alternator
Starter
Interior trim
In tank pump assembly / fuel sender
Old 03-05-2019, 11:02 PM   #4
philski o'flood
philski o'flood's Avatar
money, drugs, guns
philski o'flood is offline   Reply With Quote
Old 03-05-2019, 11:14 PM   #5
white855T
I always get intercooler brackets(top & bottom), intercooler piping & clamps(usually discard hoses unless they've been replaced or in very good shape). Turbo if it isn't worn out. Exhaust manifold(only if its not too cracked as I can have it easily repaired). Ecu & ezk. Alternator if its a Bosch 100 amp(none of that Denso crap). I fix a lot of Volvo's so I like to have these parts on the shelf ready to go. But if you have no use for the extra parts, then just get what you need.
Buyer/Seller Feedback
Old 03-06-2019, 12:01 AM   #6
apachechef
Burnt Sierra Madre
why no love for the denso?
Dammit, Lummert.
Old 03-06-2019, 12:04 AM   #7
white855T
Every Denso that I have ever used(or comes with cars that I buy) craps out. I've never had a Bosch unit fail.
Old 03-06-2019, 12:34 AM   #8
apachechef
Burnt Sierra Madre
opposite for me, Densos get installed, and only come out to out to avoid the crusher. 5 densos, and maybe seven bosch failures. You seem like you have a bigger sample size.
weird.
Old 03-06-2019, 01:25 AM   #9
iHateVolvoPeople
951 ecus, and turbo ecu/ezk. I’ve found like 3 951 ecus. Even pulled one out of an 89 740.
Also fuel pump relays, got about 5-7 OE Volvo spares somewhere in my garage. And various bulbs for marker lenses, headlights etc. 1156/7s are what, $2.50 a pop brand new? Not that the price is super high, but having spares in the trunk means you don’t have to drive to the store. Junkyard doesn’t even charge me for bulbs half the time and it’s always nice to have spares.
Feedback Thread
Current:
93' 244T m47
93' 245 m47
90' 744 AW70
94' M-Edition Miata, 93k
95' Camry auto, 246k
93' Camry auto, 278k
Past:
80' 242gt m46
88' 245T m47
92' 940 turbo AW71
94' 945T AW71(L?)
Last edited by iHateVolvoPeople; 03-06-2019 at 02:05 PM.. Reason: To add more stuff
Old 03-06-2019, 11:13 AM   #10
A tough rowing ho
Make sure you only get known good parts to swap in your Camry/240/Miata.
Old 03-06-2019, 11:36 AM   #11
Mark G
STARTTLS
Mark G's Avatar
Since Philski gave you the real answer, here are some other things:
OEM audio gear (amplifiers) from good brands. For example, some OEM Volvo amps are just rebranded Alpine.
As was said before, ECU/EZK from turbo cars. Relays that don't look cooked.
Anything turbo specific. The coolant bottle, washer bottle. The intercooler as well as each and every hose, elbow, and clamp if it's still there. The turbo, the exhaust manifold, the down pipe, the brackets.
Oil coolers, lines, & sandwich plates. Don't cut the lines if you don't have to.
Gauges, clusters with tachometers (240).
Clean interiors: seats that are dirty but not torn, plastic that doesn't look sunbaked. Minimally cracked dashboards.
100A Denso alternators that aren't covered in oil.
Also, any cars that look modified for performance. I've known people to find working Megasquirt setups in random JY cars. And seriously, check under stuff and in the trunks. Lots of random stuff to be found.
-Mark
Sold: 1981 242 DL
Parted and crushed: 1990 245 DL
1993 245 DL
Feedback thread
Instagram
Mark G is offline   Reply With Quote
Old 03-06-2019, 12:46 PM   #12
A tough rowing ho
Check for upgraded sway bars too they're easy to snag.
Old 03-07-2019, 12:51 PM   #13
towerymt
the real Towery
towerymt's Avatar
Connect 6 intercooler hoses/pipes together, shove the little couplers inside, get charged "intake hose, $8"
Old 03-07-2019, 12:55 PM   #14
white855T
^^^ yes. Definitely have done that with no issue. I usually get that stuff free as I'm a frequent flyer at the junkyards.
Old 03-07-2019, 10:13 PM   #15
2turbotoys
Salaminizer
2turbotoys's Avatar
Couple small easy things that haven't been mentioned:
Always check for factory waffle mats, easy sale, doesn't get easier to remove. 240 mats are pretty expensive these days, and 7/9 still get good $
I always take as many nice factory hose clamps as possible, as well as nuts, bolts, plastic fasteners
Always pay attention to whats around you. I was at a pick n pull with flat rate prices, alloy wheels are $80 for a set of 4. A Porsche 944 with Fuchs rims was there, so I grabbed them and easily resold them for $600.
2006 V50 T5 AWD 16 PSI +
Old 03-08-2019, 02:00 AM   #16
philski o'flood
good score, a set of 7s and 8s starts at $1000 around here
Old 03-08-2019, 08:40 AM   #17
2turbotoys
Salaminizer
2turbotoys's Avatar
I tried for a while to get $900 but when I bought a house I just sold them cheap so I didn't have to move with them. They were 15" 7 & 8's, if they were 16" I would have tried harder.
Old 03-12-2019, 10:55 PM   #18
oifish
I'm feeling extra zazzzy
oifish's Avatar
A little more involved to remove but, I'll check 850's and V70's for a 15g or 16t turbo. A small little inspection mirror helps to read the label. If the entire thing isn't caked in oil, I'll usually pick one up.
1990 Volvo 744T M46 - Daily Driver - ( ͡° ͜ʖ ͡°)
1996 Chevy C1500
__________________________________________
Buy/Sell Feedback
oifish is offline   Reply With Quote
Old 03-12-2019, 11:38 PM   #19
forty2
Pulled a 3.1* MAF/AMM, charcoal evap can, some trim bits, two VOLVO badges that will soon create one LOLVO badge, from a trashed 1993 240 automatic. It had only been put out two days before but someone had already snagged the passenger seat foam (but left a good grid, wtf) and those stupid fasteners that hold up the felt under the glovebox that I ended up buying from IPD last night. The charcoal can on my car is cracked, and having a spare MAF never hurts. Dash was cracked, most of the exterior trim was bad or missing. I thought I'd see more 240s here in Georgia than when I lived in MA but no.
Didn't know where to look for the ECU but it's probably still there.
Anyone know offhand what size Torx is used for the SRS airbag? I can't get my Torx driver in there b/c it's using bits on a 1/4" driver which is too fat. I have a replacement airbag for the old cracked one and will cut the wires to disable it and pull the SRS lamp. I would not trust a 28-year-old airbag to protect me in a frontal and I always wear my seatbelt. Or can I just put a regular 240 horn pad in there in place of the airbag? Rather do that than have an old explosive sitting in front of my face.
*1993 automatics also had 3.1? I know manuals had that from 199x, my '91 has it.
forty2 is offline   Reply With Quote
Old 03-13-2019, 02:21 AM   #20
apachechef
Burnt Sierra Madre
Don't disable the airbag on purpose, never heard of it being worse than not having it.
Old 03-13-2019, 11:32 AM   #21
Matt86
Matt86's Avatar
Most of the 200 series that show up at the yards these days are roached out...every once in a while a decent one will show up, harvest various trim parts, electrical parts, clusters, fairly new replacement parts (if good quality...like Bosch), 1993 A/C parts, rare accessory parts...gotta hit them up the day they hit the yard or soon after. Check the trunk/cargo area too. Found two brand new OE Volvo 240 motor mounts, still in the box in the trunk of a discarded 200.
2007 V70 2.4
1989 245 DL
Matt86 is offline   Reply With Quote
Old 03-13-2019, 08:12 PM   #22
2turbotoys
Salaminizer
2turbotoys's Avatar
I love finding factory tool kits, have a small stack of them now, but I use the tools.
Old 03-13-2019, 11:49 PM   #23
tryingbe
Boosting along.
tryingbe's Avatar
I havn't been to junkyard for more a year, eBay with shipping is cheaper...
85 GLH 367whp
00 Insight mpg > yours.
Old 03-14-2019, 02:19 PM   #24
57plymouth
57plymouth's Avatar
Any LS engine larger than a 4.8. Nice interior stuff for my 240. That's about it.
Sven, the 1991 245
Old 03-15-2019, 12:00 AM   #25
NotSoFresh
Sick ****** T-Brick Prick
NotSoFresh's Avatar
Always check the cars beside the car you are looking at. People will take off stuff they don't need to get to the part they do need. The stuff they take off and don't want? In the car next door. Under the dead hooker.
