Old 03-12-2019, 03:37 PM   #26
JohnMc
JohnMc's Avatar
It's not the fuel pump overfilling them, or they'd be overfilling out the vents.
Have you tried backing the mixture adjusting nuts all the way up? Just to see if you can get it leaner.
I was figuring the pump was giving it enough gas, because the filter was sitting there visibly full of fuel, the assumption being that you'd see that empty out of the carbs weren't getting enough gas. But wet sooty plugs, and a rev or two keeping it going for a while longer just makes me think it's a rich mixture carb issue.
Are the carbs balanced front and rear (air flow)?
Also, maybe try the mixture check pins - they sit under the dome's edge and push the piston up a specific amount. Try those at idle and see what they have to say about the mixture.
Push the pin up and:
- if the idle slows down, that carb is too lean. Adjust the jet downward slightly to richen
- if the idle speeds up briefly, then slows back down, that's good
- if the idle speeds up and stays faster, that carb is too rich. Adjust the jet upward slightly to lean
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 03-12-2019, 09:01 PM   #27
Addicted242boost
))<>(('s Avatar
So here's my notes. It took 10 minutes of cranking again but it finally started and idled like ****.
Plug Wire Resistances
Cyl#1 8.8
Cyl#2 14.7
Cyl#3 7.1
Cyl#4 6.75
Coil Wire 10.7
Both of the coils I have are oil filled, so I've placed them right side up for testing.
Coil w/ external resistor
Bat 12v
(+) on coil side (disconnected from coil) 12v
(+) on coil side connected to coil and ignition on 11.7v
(-) with ignition on 5.9v
(-) when cranking 7.5 to 7.6. When it hits 7.7v it attempts to fire.
Coil w/ internal resistor
Battery 12v
(+) side when disconnected from coil 12v
(+) side when connected to coil 11.7v
(-) with ignition on .13v
(-) when crankking 4.5-4.6v
Car was backfiring through the carbs when running at both 15 flats and 0 flats (carb jet level with the body or whatever its called).
When pressing on the mixture check pins it would almost instantly die (idle dipping down) at both 15 flats and 0 flats. I am running 15w50 in the dashpots. I've also tried ATF
Since it sounds like it's running lean with the idle dipping at 15 flats, I'll go try and add more. Each time the car dies I am pulling the plugs and they are black.
***EDIT***
I readjusted the carbs to both 17 flats each and it started.
Rear carb idled high in pressing in the the mixture pin. Changed it to 15 and it was fine.
Front carb idle did not change when pressing in the mixture pin, so I left it at 17.
Both carb air flow is balanced by using a hose and my ear. I don't have a gauge.
With the car idling, it is at about 1100-1200RPM. However the tach on my multimeter reads 3500 when placed on the (-) on the coil. If I attempt to lower it to around 800-900 it begins to stumbled every so often. I revved the piss out of it for 1 minute and pulled plug #1 and plug #4. Both were black. No black smoke out the tailpipe.
))<>(( is offline   Reply With Quote
Old 03-12-2019, 09:49 PM   #28
Addicted242boost
))<>(('s Avatar
I figured I should also mention while it's idling at the 1100-1200 that the timing gear pulley reads well above 30 degrees. If I lower it to 30 it will die. Previously I was able to get it to idle around 20.
Old 03-12-2019, 10:41 PM   #29
Have you checked the advance mechanism in the distributor? If the springs are broken the timing will be very erratic.
Old 03-12-2019, 11:07 PM   #30
Addicted242boost
))<>(('s Avatar
The springs are intact and pull back on the advancer plates when you move them with a screw driver.
Old 03-13-2019, 09:18 AM   #31
alschnertz
Enough already!
alschnertz's Avatar
Have you checked for an intake manifold gasket leak?
Or a warped intake manifold?
I know that doesn't affect timing and realize you have pulley issues also.
Old 03-13-2019, 09:35 AM   #32
JohnMc
JohnMc's Avatar
As long as you see the spark advance and retard as the revs climb and drop, it's probably OK. A little timing wobble is not unusual in an older 'well experienced' distributor running ignition points.
A balancing tool is a great multiple carb tuning shortcut, absent that you have to do a very iterative process of trying to balance them by ear. Basically, when you screw the idle screw in and out some small amount (like 1/4 turn), on each carb, it has the same effect on idle speed. Screw it in 1/4 turn on the back carb and idle rises some small number of rpm, then go back. Then try it on the front carb and see if it goes up more, same, or less rpm. If it goes up less, then the carb is flowing less air, and needs to be opened up slightly. If it's the same, leave it alone. If it goes up more, close it slightly. And vice versa.
This is (considerably) complicated by the fact that the carbs might not have the same jet tuning - one may be running richer or leaner, thus affecting the idle speed produced from that carb. So after you've gotten them roughly balanced via the idle adjuster screws, then start tuning the mixture on each carb using those lift pins (when lifted, idle goes up and stays up - too rich, goes up then returns - good, goes down - too lean). Then go back and rebalance them via the idle screws, and if it made a difference, go do the mixture again. Until you aren't doing any adjustments on either.
Of course, this is where you have to mention the throttle shaft leaks on a worn old set of SU's. They feature brass shafts rotating in a cast aluminum body with no rubber seals of any sort. When the shaft wears into the softer aluminum (perhaps due to unleaded fuel? Or just... cheap design) it can create an air leak. And at idle, where you adjust these carbs using the lift pins, the vacuum is largest, and the 'metered' air flow is the smallest, so the leaks have the larges effect on mixture, leading you to set them to account for the leaking air, and leaving them too rich at all the other throttle settings.
Back when my PV had SU's it seemed like I needed to do a tuning session on them more or less seasonally. They just tend to drift out of tune for some reason. In small ways.
Old 03-13-2019, 02:31 PM   #33
jwernerny
jwernerny's Avatar
[Without reading the whole thread over...] If you replaced the points, did you make sure you lubricated the piece that follows the distributor cam? If you don't lubricate it, it wears very fast and causes huge drivability problems within a couple hundred miles.
John Werner
* 1992 944T * 1988 764 GLE V6 * 2002 WRX Wagon (needs motor) * 2006 Honda Odyssey *
jwernerny is offline   Reply With Quote
Old 03-13-2019, 08:25 PM   #34
Addicted242boost
))<>(('s Avatar
Replaced the ghetto coil with the blue Bosch coil. Read 12V on (+) with ignition on and connected, so that's a step above the **** coil. Fired up but idled like ****. Re-adjusted carbs again because fuel was spitting outside of the mouths while cranking, but wouldnt fire.
At this point I'm 99% sure it's a weak spark. I laid down spark plug #1 connected to distributor near a piece of metal. The spark was faint, white, and didn't fire every time.
As far as the lubing, yes, I lubed the distributor arm, ceramic or plastic thing that rubs on the cam in the distributor, oil filler, and the top part under the rotor.
What would cause this? Cap, rotor, plugs, wires, coil, points are all new.
This is the rotor/cap/plug combo I have on the car
https://www.ipdusa.com/products/8337...ess-conversion
Old 03-13-2019, 08:35 PM   #35
gsellstr
gsellstr's Avatar
Interesting, no condenser in that tuneup kit...
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 03-13-2019, 08:38 PM   #36
Addicted242boost
))<>(('s Avatar
Yea, I had to buy it separate.
https://www.ipdusa.com/products/6591...utor-condensor
P.S. just tested spark from coil to coil wire and its strong, but a yellowish color.
Also I think someone asked, the intake manifold gaskets are new. I replaced all intake side gaskets. I've also tested the condenser.
Here's what the cap and rotor look like:
Old 03-13-2019, 09:07 PM   #37
It could be a couple of things causing weak spark.
The points come with some corrosion inhibitor on them which needs to be removed prior to installation. I use a flap torn from the box to clean them.
The new condensers are a little smaller than the original ones and the clamp doesn't fit tight enough. I use a piece of brass shim stock to tighten it up so it gets a good ground.
The post that connects the points and condenser needs to be centered where it goes through the body of the distributor. Also, the paper strip inside the distributor insulates the points spring and needs to be in place.
Old 03-13-2019, 09:19 PM   #38
Addicted242boost
))<>(('s Avatar
Ive taken apart the distributor to make sure everything has a good ground and the screw is centered through the body. The paper is still intact, but old. I used a piece of plastic/o ring to make sure the bolt is centered and doesn't move.
As of right now, the points/condenser assembly goes: Bolt head-points clip/holder-metal clip thing-paper-distributor housing-rubber o ring in hole-rubber grommet-metal washer-spade connector-points-metal washer-nut. The condenser I have is firmly grounded/held in place against the distributor housing.
Where can I buy a kit like that? Besides the distributor itself, that's the only thing I haven't replaced in the entire ignition system.
I also keep reading about B18s and "armored cables". I'm running some ****ty stranded 16awg wire with ****ty auotzone connectors on the end between the the (-) on the coil and the condenser.
Old 03-13-2019, 10:10 PM   #39
The proper order is bolt head, rectangular metal washer, points spring, square phenolic washer, paper strip - distributor housing - small round phenolic washer (centered in recess in dist. housing), metal washer, condenser wire, metal washer, lock washer, nut. The spade connector wasn't used on these distributors from the factory but you can use it if you want. The original wire just had a ring connector. The other parts in the kit aren't used on this style distributor.
Double check that condenser. If you can move it in the clamp by pushing on it with your thumb, it's too loose.
I have the distributor post kits in stock. The price has gone up on the kits so I customize them by removing the unneeded parts to lower the cost.
I believe the "armored cable" you're reading about is the coil (+) wire that's shielded by a double thick flexible metal tube and attaches the coil to the ignition switch. It's a theft preventative measure because it prevents the car from easily being hot wired.
Old 03-13-2019, 10:27 PM   #40
Addicted242boost
))<>(('s Avatar
Let me pull the distributor and re-fit everything. It sounds like I'm missing some washers in there, so I'll round some up.
Old 03-15-2019, 09:39 PM   #41
Addicted242boost
))<>(('s Avatar
Pulled the distributor and I was off on the order, it's close to your description. The red circle thing is the bit of plastic im using to keep the screw centered in the house.
Old 03-15-2019, 11:01 PM   #42
NotSoFresh
Sick ****** T-Brick Prick
NotSoFresh's Avatar
I had a hell of a time in the past with similar symptoms. I eventually discovered that the recommended points gap didn't even get me close to proper dwell due to what I suspect is worn distributor lobes.
Gap is really just a way to get the dwell. More gap=less dwell. Dwell is the number of degrees the points stay closed. Dwell is the important number.
This is the ghetto farmboy way to measure dwell:
(edit: Unhook power to points FIRST..)
Print off a protractor about 4" diameter and tape to rotor with cap removed. Fashion a pointer out of a wire from somewhere on the block to above the protractor. Hook up multimeter to both sides of points, and set to beep for continuity.
Turn engine over by hand slowly noting what angle the beep starts and what angle it stops. The difference is your dwell.
If the dwell and points gap don't jive with the manual settings at the same time, something is worn. Set the dwell and disregard the gap.
Old 03-16-2019, 12:40 AM   #43
Addicted242boost
))<>(('s Avatar
that actually makes a lot of sense. I'll check it out tomorrow!
Old 03-16-2019, 05:44 PM   #44
Addicted242boost
))<>(('s Avatar
It was the ****ing brand new condenser even though it passed the multi meter test.
After mucking with dwell and points again I was looking through a box and found the old condenser I pulled when I did the tune up kit. I figured why not try it since I've tried everything else. Fired right up, idled great, revved the best it's ever revved since buying the car.
Took it for a drive and its smooth through the entire RPM range. Case closed.
What would cause a brand new condenser to fail even though when I do the charge/discharge test with a multi-meter it passes?
Old 03-16-2019, 06:37 PM   #45
alschnertz
Enough already!
alschnertz's Avatar
Simple.
New does not mean good.
Old 03-16-2019, 07:14 PM   #46
300+hp on the shelf club
A condenser is a reactive component. Might be that it's the wrong value for the application? Could just be a new bad part? I've had them fail new. It happened to me when driving my 60 356b a long time ago. It shut down and had no spark. Wasn't far from home so went back and got another one. fixed it. Change your points every year for maximum performance.
Old 03-16-2019, 08:18 PM   #47
Pro tip, always buy Bosch tune up parts.
Old 03-16-2019, 09:34 PM   #48
Addicted242boost
))<>(('s Avatar
It was a Bosch part per IPD. No part # listed on it though.
Glad it's finally figured out though. Took it for a drive and it revs about as happy as a stock B18 can rev. Super pumped.
Thanks everyone for the help!
Old 03-16-2019, 09:44 PM   #49
I know that's what Bosch is selling now but I can't swear that Bosch is making them. They're pretty good about putting their logo on everything they make. The one you have doesn't say 'Made in Germany' like this one so maybe it isn't a Bosch part.
The original condensers had a solid wire and fit better in the clamp.
Kudos for finding the problem!
Old 03-16-2019, 11:46 PM   #50
NotSoFresh
NotSoFresh's Avatar
I have had the whole tip, contact and all break off of the arm of a set of mexican bosch points after about 200 kms a while back and fall down into the distributor. Get this, I was on an uphill in a standard on a narrow road with a line of cars behind. That was fun..... Luckily I had the old points in the trunk, so i got it home.
When I finally found good made in germany points I bought 3 sets, 3 condensers, etc, and I keep them along with a cap, rotor, plugwires, plugs, and some vacuum and fuel line all in an icecream pail in the trunk. Along with a multimeter, and a protractor taped into the lid.....No kidding.
Funny thing is I haven`t had a problem or needed an adjustment in probably 12000 kms....Checked the points other day, they look almost new.
Ahhhhh, Carbs and points life....
