Old 03-09-2019, 03:13 PM   #1
73amc
Default Cam gear shim
I pulled the cam gear off this 93 b230ft I have to freshen it all up before I put it in. I noticed there wasnt a shim behind the cam gear like there was on the 88 motor I pulled out. Do some use the shim and some dont? I have the shim off my 88, just wondering if it needs to be there or this was designed without one.
Thanks.
73amc is offline   Reply With Quote
Old 03-09-2019, 04:36 PM   #2
It's only used on some engines. Check the alignment of the belt on the cam gear and use the shim if the belt isn't centered.
Old 03-09-2019, 05:01 PM   #3
iHateVolvoPeople
Is this only dependent upon year? I have seen timing belts ride in different locations on the cam gear before and was wondering whuy. (Crank washers installed properly).
Feedback Thread
Current:
93' 244T m47
93' 245 m47
90' 744 AW70
94' M-Edition Miata, 93k
95' Camry auto, 246k
93' Camry auto, 278k
Past:
80' 242gt m46
88' 245T m47
92' 940 turbo AW71
94' 945T AW71(L?)
Old 03-09-2019, 05:04 PM   #4
It looks that way. All B230 engines in the '85-'87 240 catalog use the shim while only certain engine #'s in the '88- catalog use it.
