Old 03-10-2019, 08:17 PM   #1
11BC2
Default Suggestions on fixing this?
The lift gate strut ball mount bolt stripped out the threaded hole in the chassis.
Any items on how to repair the hole?
The OD of is larger than a timesert, so I canít use that.
11BC2 is offline   Reply With Quote
Old 03-10-2019, 08:21 PM   #2
2turbotoys
Salaminizer
2turbotoys's Avatar
Weld a nut in there?
2006 V50 T5 AWD 16 PSI +
Old 03-10-2019, 08:49 PM   #3
NotSoFresh
Sick ****** T-Brick Prick
NotSoFresh's Avatar
In order of decreasing simplicity and increasing cost and reliability of repair:
1: JB weld?
2: Drill new hole and tap beside it? Its just a strut, location is not super critical.
3: Drill and tap much bigger, thread in a butter soft, mild steel bolt, with permanent loctite. Do not use a hardened bolt. Next, drill into center of bolt, tap for original thread size.
Kinda like making your own heli coil in-place
5: Weld it up and tap it new like. Add bondo, paint and stuff.
4: Get a new body shell and transfer all parts over to it. Scrap this shell
1982 GLT 244 redwood metallic, turbo, lowered...RIP
Colonel Mustard: 1979 242DL, B21A, SU carb, M45, GT sways, Limited-slip, rad hubcaps, Manual rack, no ac e-fan
Blueberry: 1989 244, dark blue. Ipd everywhere. H-cam. Advance and full retard switches on dash. Galaxy wheels, LSD, other stuff from a bunch of cars on here.
Originally Posted by NativeJesus View Post
This isn't even a trailer park suspension.
740s donít look hot.
More like ugly fat girl that can blow well but eats the sandwich she made for you
Old 03-11-2019, 09:06 AM   #4
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
Rivnut?
1980 242 Turbo
2004 V70R
Old 03-11-2019, 11:58 AM   #5
A tough rowing ho
Get broomstick prop rod for tailgate.
1980 Richelieu red JDM flares franken-242DL now with 8.8, 1989 silver 780 sienna rear spring nivomat delete.
Old 03-11-2019, 12:20 PM   #6
IansPlatinum
IansPlatinum's Avatar
Check and see if you can tap to 5/16-18. also check if these ball stud are compatible with stock socket.
https://www.mcmaster.com/ball-studs
'96 854 Platinum - "Trusty"
'92 245 - "Boat"
'71 145 - "Rusty"
'73 1800es - "Sunny"
Old 03-11-2019, 12:23 PM   #7
Weld it.
Old 03-11-2019, 02:01 PM   #8
300+hp on the shelf club
Did you verify a Big Sert won't fit?
http://www.timesert.com/html/bigsert.html
Old 03-12-2019, 10:35 PM   #9
11BC2
A little excessive...but effective! #3 is also a great idea.
Originally Posted by Uncleknucklez View Post
Rivnut?
I canít believe I didnít think of that,thanks!
Currently in use, but I use a nice piece of of stained redwood 2x2.
I use timeserts all the time and didnít know they made these. Thanks!
Old 03-13-2019, 04:34 AM   #10
Otto Mattik
Otto Mattik's Avatar
Originally posted by Jack
_________________________
Feedback Link: http://forums.turbobricks.com/showthread.php?t=323689
Old 03-13-2019, 06:40 AM   #11
A tough rowing ho
My 780 came with a piece of wood to hold the trunk open, I got some of the gas struts off of rock Auto for cheap now it pops open by itself.
