Old 03-11-2019, 10:26 AM   #1
Patestrickland
Patestrickland's Avatar
Question 240 ac
So guys the ac on my 93 240 isnít working. My car still blows air itís just not cold. I tried recharging the ac and that didnít work. My power steering still works so my condenser isnít locked up. Should I just replace the whole ac condenser?
Patestrickland is offline   Reply With Quote
Old 03-11-2019, 11:10 AM   #2
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
Check that the heater valve isn't stuck open?
1980 242 Turbo
2004 V70R
Old 03-11-2019, 01:49 PM   #3
iHateVolvoPeople
Try properly evacuating and recharging the system, but replace the receiver drier first.
Feedback Thread
Current:
93' 244T M47
93' 245 M47
90' 744 AW70
94' M-Edition Miata 5 speed, 93k
95' Camry A140E, 246k
91' 745 Regina AW701, maybe future turbo project
Past (Volvos):
80' 242gt M46
88' 245T M47
92' 945T AW71
94' 945T AW71
90' 745T AW71 (Donor car for the 91)
Old 03-11-2019, 03:02 PM   #4
80/20 speed parts club
Pull everything, make your car lighter and faster. Send it all to me,
Old 03-11-2019, 04:35 PM   #5
Matt86
Matt86's Avatar
Is the compressor clutch engaging? Start with that. Check to see if its getting power when activated by the snowflake switch. If not, check the low pressure switch on the accumulator.
2007 V70 2.4
1989 245 DL
Matt86 is offline   Reply With Quote
Old 03-11-2019, 05:10 PM   #6
Patestrickland
I think it might be the heater valve has gone bad. Did some research and i found that if the heater valve is bad then your ac will blow heat all the time which mine does. I will check for the other things too.
Old 03-11-2019, 05:26 PM   #7
2manyturbos
Start with the obvious. Is your compressor clutch engaging the compressor?
Old 03-11-2019, 05:36 PM   #8
billkaz
Bomber Dream
billkaz's Avatar
I know that is true for the older style brass heater valves, which where phased out in 1991 as I recall. Not sure if the newer style fail in the same manner.
1992 240 Wagon
2006 Mazda6 Wagon
billkaz is offline   Reply With Quote
Old 03-11-2019, 05:43 PM   #9
300+hp on the shelf club
it's very important to have the correct amount of refrigerant. That said I would start with making sure the compressor comes on and if it doesn't check the low pressure switch on the accumulator near the firewall.
Last summer my 93 was blowing warm and the compressor was cycling quite fast yet no cooling. I checked the low side pressure and it was correct. The system was low on refrigerant and once charged up to the proper amount it has worked fine. The only way you know how much is in there is by pulling out the remaining refrigerant and weighing what is removed. Then you can add the correct fill after you leak check the system.
Old 03-11-2019, 10:28 PM   #10
Patestrickland
Checked to see if the clutch was spinning on the compressor when the ac is turned on and it’s not. Is there a way to fix this?
Old 03-11-2019, 11:57 PM   #11
iHateVolvoPeople
.........yes. There’s a lot of ways to fix this. There’s also a lot of reasons as to why it would not turn on. That’s what you need to diagnose before throwing a new compressor on there.
You can bypass the low pressure switch very easily. This will tell you instantly if you have a clutch issue. And in my opinion it’s the fastest test.
If bypassing it causes the clutch to engage, you likely have a refrigerant level issue.
Old 03-12-2019, 12:00 AM   #12
apachechef
Burnt Sierra Madre
They can. I've replaced 1993 ones for that.
Dammit, Lummert.
Old 03-12-2019, 12:01 AM   #13
apachechef
Burnt Sierra Madre
Checked to see if the clutch was spinning on the compressor when the ac is turned on and itís not. Is there a way to fix this?
reread reply #5
Old 03-12-2019, 03:52 PM   #14
Patestrickland
I jumped the low pressure switch and the clutch engaged
Old 03-12-2019, 03:54 PM   #15
2manyturbos
So, that is telling you the system is low on refrigerant, or, the pressure switch is bad. More likely, the system is just low on refrigerant.
Old 03-12-2019, 04:51 PM   #16
Patestrickland
Filled the system up with refrigerant and still no ac. The clutch only engages after I jump the switch off but if I don’t jump it off the clutch won’t spin.
Old 03-12-2019, 04:54 PM   #17
Wren
Porkchop Sandwiches
Wren's Avatar
What does "filled up the system" mean? Tell us your procedure start to finish.
Old 03-12-2019, 05:59 PM   #18
Patestrickland
Turn the car on, turn the ac on, turn the blower on full, fill er up
Old 03-12-2019, 06:01 PM   #19
2manyturbos
In general, that doesn't work. You need the compressor running in order to pull the refrigerant into the system. What did you try to fill it with? Does the can tap have a gage on it?
Old 03-12-2019, 06:32 PM   #20
Kjets On a Plane
Devoid of Luxury
Kjets On a Plane's Avatar
The lines are apt to rub thru with worn motor mounts, the 1993 condenser galvanically corrodes, & the compressor can often be worn out at this late date/200Kmi+ of even fairly pampered use give or take some oil soaked mounts/accessory bushings all cockeyed and/or a low charge/low oil to help it kiv out a little sooner.
Technically speaking, a micron gauge, some dye in the oil with the proper flashlight, vacuuming and recharging should help nail it down pretty effing quickly.
This isn't necessarily difficult and/or expensive, especially with an R134a car that uses cheap/abundant/legal refrigerant.
But spending a whole hundred dollars or god forbid reading the repair book/sticker specifying charge weight is against cheap/lazy TB religion...
How PSI a stock can support?
Always Be Crushing!
Old 03-12-2019, 11:15 PM   #21
apachechef
Burnt Sierra Madre
Get out of here with your blasphemy!
Proper tools?
A little light reading?
A little forethought and reasoning?
HERETIC!
Old 03-13-2019, 08:23 PM   #22
Patestrickland
Problem solved. The problem was the system was low on refrigerant. I had just filled it up before I made the post but I didn’t fill the system up the right way. Once I got the clutch to engage I filled it up while the clutch was engaged and now my system blows cold. Thanks guys!
Old 03-13-2019, 11:11 PM   #23
Enjoy the coolness!
Old 03-13-2019, 11:15 PM   #24
iHateVolvoPeople
There ya go!
You should replace the RD before it explodes and destroys your entire AC system.
Old 03-14-2019, 02:34 PM   #25
2manyturbos
There is no reason to replace a receiver drier if the system has not been opened up and exposed to air. ALL automotive AC systems leak refrigerant. The fact his system was low is to be expected.
