Old 03-11-2019, 01:49 PM   #1
Primergy
Primergy's Avatar
Default 240 Roof insulation material options
I'm planning to pull down the headliner in my 240 to run some wires soon.
At the same time I'd like to insulate it a bite before putting back the liner.
What's proven & tested to keep inside temps moderate and maybe also work on cabin noise?
_-- Sanders 2020 --_
Old Volvos for everyone!
Primergy is offline   Reply With Quote
Old 03-12-2019, 03:15 AM   #2
TIPSP
Got Boost?
TIPSP's Avatar
I used Dynamat superlite to kill panel vibrations in the 75. I only used where I needed it, so I can't tell you if it made the interior temp drop... (Most likely it did not make any difference in my case).
My car doesn't have tinted windows either, and that is where most of the heat gain comes from. Tint really helps.
Dynamat has an excellent adhesive back, so i would stick it any where. It's pricey, but works well.
Even if you cover the entire interior, The noise will still transmit through all the windows, seals, door seals... etc.
Old 03-12-2019, 08:40 AM   #3
GeneralBurrito
GeneralBurrito's Avatar
And a lot of noise comes through the shifter hole if you have a manual.
Old 03-12-2019, 10:25 AM   #4
sksmith
sksmith's Avatar
Probably need one of these.
http://www.vp-autoparts.com/us/main....&artno=1254484
Steve
Old 03-13-2019, 03:05 PM   #5
buffalo
In my 83 wagon I used some 1/2" polyisocyanurate insulation glued up between the "ribs". I used flexible strips of thin plywood bent slightly to wedge the foam in place until the glue dried. On the wagon, that's a lot of hot metal just above your head when the sun is shining. Total cost about $20.00
buffalo is offline   Reply With Quote
Old 03-15-2019, 09:58 AM   #6
JW240
All idiot, no savant
JW240's Avatar
Yes was thinking about insulation above headliner.. But how to remove the headliner? Started at the tailgate and tried to remove it but after the first foot or so i stopped.. Was doing something wrong.
I have some felt insulation for use in cars. Not that expensive and pretty light even.
Old 03-18-2019, 02:37 PM   #7
dbarton
Dejected by Volvo
dbarton's Avatar
How rigid or flexible was that stuff?
Looks like about $10 for a 4 x 8 foot sheet from Home Depot.
Rmax R-Matte Plus-3 1/2 in. x 4 ft. x 8 ft. R-3.2 Polyisocyanurate Rigid Foam Insulation Board
Old 03-19-2019, 03:49 PM   #8
buffalo
Default Rigidity
That's the stuff. Even though it has "rigid" in its name, it will flex enough to fit the gentle curve of the roof. Like corrugated cardboard. The thicker it is, the more rigid. I would stick to 1/2".
Old 03-20-2019, 07:01 PM   #9
Primergy
Primergy's Avatar
That Polyisocyanurate is nice! Sure better than cheapo silver-backed bubble wrap with adhesive. Good insulation but will do only very little in terms of sound I imagine.
Also looked into 3M automotive insulation but it costs an arm & a leg!
Old 03-21-2019, 09:27 AM   #10
dbarton
Dejected by Volvo
dbarton's Avatar
When I was in high school I help a friend of mine cover the floor of his tin can Karmann Ghia with leftover house carpet padding. Closed cell stuff that looks like it's compressed of lots of different colored pieces, about 1/2 inch thick. We glued it down with contact cement. The difference was phenomenal in noise reduction.
Dave B
Old 03-21-2019, 02:57 PM   #11
Primergy
Primergy's Avatar
I can see that. It does have some weight / density to it.
If there is room, maybe I can add that and a layer of insulation.
Old 03-22-2019, 12:45 PM   #12
PCH
TrafficMaster 3in1 insulation from Home Depot worked great for me. It's thin and pliable, you can glue many layers together using spray adhesive. I redid all floor insulating mats under carpet using 5 layers (to get the same thickness as original fiber mats). DynoMat is great for sound but heavy, while TrafficMaster is very light and effective for temp control.
Old 03-22-2019, 06:00 PM   #13
dbarton
Dejected by Volvo
dbarton's Avatar
Tell us how great it was. Did it reduce any temps or sound at all?
Old Yesterday, 07:39 PM   #14
PCH
For sound it worked better than stock floor insulation that's made from some kind of cardboard/pressed fibers stuff (on my 945). 5 layers added up to same thickness so the carpet fits nice over it. I also used couple of layers under all of the the wagon's plywood floor.
