Old 03-11-2019, 10:05 PM   #1
volvo gt
volvo gt's Avatar
Default 1979 242 sunroof drain lines
Hello
California no longer has a drought that's for sure.
I noticed damp carpet on the passenger side a few days ago. I lifted the carpet and put a towel there to soak up the water.
The sunroof drain holes appear to be clear.
My question is, where do the sunroof drain lines empty out?
I wonder if anyone has a link or diagram they can share or advice?
Thank you
1976 262 E-Coded hydraulic manual
1981 242 Turbo manual
1979 242 GT manual
1972 164 auto
1989 244 auto
volvo gt is offline   Reply With Quote
Old 03-11-2019, 10:18 PM   #2
Addicted242boost
))<>(('s Avatar
Sunroof drains in the front near the door hinge/light switch in the door jam. It goes down the A pillar then down behind the kick panel area and out the jam. Make sure that tube hasn't been pushed in.
The rears connect to the back of the sunroof tray and down the c pillar then through the trunk.
))<>(( is offline   Reply With Quote
Old 03-11-2019, 10:57 PM   #3
volvo gt
volvo gt's Avatar
Thank you! It's been a very long time since I needed to check any of these.
Old 03-12-2019, 02:09 PM   #4
300+hp on the shelf club
You can use some air pressure applied to the drian hoses in the door hinge area and blow out any debris. Be sure to open the roof and cover the roof and interior in case something nasty comes out!
Old 03-12-2019, 02:09 PM   #5
2manyturbos
At this point, they may have shrunk and pulled off of the steel tube at the channel in the roof. Another member here had that problem with his GT. Both sides did the same thing.
Old 03-12-2019, 02:10 PM   #6
yeah, it's pretty old tubing now.
Old 03-12-2019, 02:17 PM   #7
2manyturbos
The original tubing was hard as rock. It was really difficult to get out. Tip, if this is the case, use the old tubing to pull the new tubing down through the pillar. Just the way electrical wire is pulled through conduit. I made the mistake of pulling the old tubing out and then trying to feed the new tubing down through the pillar. It took forever. There are some sharp edges inside the pillar the tubing would run into and stop cold.
The original tubing had shrunk so much it was 3/4" from even touching the steel nipple, let alone, sliding onto it.
Old 03-17-2019, 04:53 PM   #8
volvo gt
volvo gt's Avatar
Thanks you. who sells the tubing?
The drivers side tube is visible near the door hinge. The passenger side is pushed in and seems a bit short and the holder is gone.
I wonder if I should put some cat litter or other absorbent in the bottom of that pillar?
I would hate to have rust start if it has not already.
Old 03-17-2019, 06:02 PM   #9
cleanflametrap
cleanflametrap's Avatar
It has been nearly 20 years since I patched this. By the look in the picture, I got hose from a junker, but otherwise vinyl hose is sold at the hardware store.
-Art
Old 03-17-2019, 09:34 PM   #10
volvo gt
volvo gt's Avatar
Thank you Sir. Pictures help a lot.
Both front holes drain perfectly now and no new tubes or parts were needed.
We changed the door hinges too while we had it all opened up. The rear sunroof drains will get
checked next time.
tb is very helpful!
