Old 10-03-2013, 11:43 PM   #1
GreatDaneShane
GreatDaneShane's Avatar
Default redblock straight eight?
Could you just weld the cranks nose to tail and megasquirt it or something? Not should you, but could you. Benchrace yoloswag, but what would need to be done to make it happen?
GreatDaneShane is offline   Reply With Quote
Old 10-03-2013, 11:45 PM   #2
Anything's possible but paying someone to do it is the trick.
<-- IN B4 it's moved to OT
Old 10-03-2013, 11:47 PM   #3
Karl Buchka
Never go full retard.
Karl Buchka's Avatar
A flexible coupling would probably be a better idea, you know, so you can service the belts on the rear engine without cutting them apart every time.
Fake Race Car
Old 10-03-2013, 11:52 PM   #4
GreatDaneShane
I was thinking some sort of sprocket held together with a chain. They built some twin v8 thing on monster garage and used something like that. Is there like a tried and true way to hook two cranks together, or would I just need to get creative?
Ot? Its a performance modification, no less feasible than all these noobs asking about how psi and whatnot.
Not really trying to pay anyone here. Have access to necessary resources.
Old 10-03-2013, 11:59 PM   #5
GreatDaneShane
Reeaaaaallll mennn of geeeeeeenius! Mr. Obvioisproblempointerouterwhoprovidesconstructivef eeeeeedback!
Old 10-04-2013, 12:03 AM   #6
$EEKING 945 TURBO WAGON
It's been done many times in the worlds of big buck drag racing, salt flats, tractor pulls, semi tractor pulls-but horrendously - even astronomically and absurdly expensive, convoluted and needing constant and very extensive fettering. It's a very interesting and stimulating challenge- but only for courage and pocketbooks extending beyond lunacy.
One of the hottest I ever saw was two big bore road bike GSXR cranks sculpted into an impressive HP to weight advantage- in FOUR wheels.
But better for dreaming than doing, at least for this little boy with little boy pockets.
$EEKING 945 TURBO WAGON is offline   Reply With Quote
Old 10-04-2013, 12:05 AM   #7
Alex Buchka
8 cylinders
Alex Buchka's Avatar
Two sprockets and a duplex chain. Make use of your resources and post some photos when you're done.
Old 10-04-2013, 12:10 AM   #8
GreatDaneShane
Not talking v8s or tractor pulls. Just sticking two together, and megasquirting it. Custom intake, custom header. Would it need a shared oilpan? Bigger waterpump or just run the two stockers? How would you do it turbobricks?
Old 10-04-2013, 12:26 AM   #9
Mueller
Mueller's Avatar
We know, but those 2 examples have been done, no different doing a V8 than doing a straight 4.
See how those had been done, learn from example.
Why would it need a shared oil pan?
Old 10-04-2013, 12:27 AM   #10
Dan
TQ>HP
Dan's Avatar
make an adapter to bolt them together, but I don't see an easy way to transmit power to the front pulley. The snout would need machining to attach the adapter and transmit the power, adapter would run wp also
1985 Chevy TPI V8 740.
“Expertise in one field does not carry over into other fields. But experts often think so. The narrower their field of knowledge the more likely they are to think so.” – Robert A. Heinlein
“We must reject the idea that every time a law is broken, society is guilty rather than the lawbreaker. It is time to restore the American precept that each individual is accountable for his actions.” – Ronald Reagan
Old 10-04-2013, 12:32 AM   #11
Back to back chain drive and run one in reverse with a custom cam.
Old 10-04-2013, 12:33 AM   #12
Mueller
Mueller's Avatar
I wouldn't want them solidly attached to each other, too many things that can and will go wrong.
Old 10-04-2013, 12:35 AM   #13
Dan
TQ>HP
Dan's Avatar
Guibo then? Although a real straight 8 would be one long crank
Old 10-04-2013, 01:25 AM   #14
Go for it, and post pictures of the resultant carnage.
Old 10-04-2013, 01:39 AM   #15
Lando
Arthur Digby Sellers
Lando's Avatar
Two redblocks bolted to a planetary gear box, mated to a transaxle mounted longitudinally. Then you take one of the output shafts and custom fab a drive shaft to a Dana 44. It could be done in a week or less, Yoshifab makes kits.
Originally Posted by 11110000 View Post
I didn't think there was anything to the whole 7/9 thing, but I have to say that my 745T is the only Volvo I've owned that blew up and self-immolated.
Lando is offline   Reply With Quote
Old 10-04-2013, 01:42 AM   #16
centason
Knipex=welfare queen
centason's Avatar
Or just get a Pontiac or Buick straight 8. I watched a YouTube video many moons ago of a guy running a Buick 8 turbo at Bonneville. Made ~240mph iirc, and the hole shot was insane because of the shear torque. Chrysler did a concept car with two neon motors, in lies the failure there in the latter. The means has been around since the 30's. I think '53 or '54 was the death of most of the American 8s.
Member: TBCCS
"The urge to save humanity is almost always only a false-face for the urge to rule it.” -H.L. Mencken
centason is online now   Reply With Quote
Old 10-04-2013, 04:26 AM   #17
745 TurboGreasel
745 TurboGreasel's Avatar
My buddy has a 32 Buick with a mildly modded straight 8. It leaves the line pretty good, but you have to shift for 2nd at 3-4 MPH.
Feedback
Old 10-04-2013, 05:49 AM   #18
While you're at it, why not just do a straight 12 like Lincoln did in the 30's ?
Old 10-04-2013, 06:28 AM   #19
centason
centason's Avatar
Need MoAr crankshaft.
Old 10-04-2013, 06:33 AM   #20
7mgtesup
Back seat drive?
Could be an interestin project but ultimately there are much easier ways to go fast.
Turbo lag is the moment the car next to you thinks he's going to win.
7mgtesup is offline   Reply With Quote
Old 10-04-2013, 06:52 AM   #21
Default Go for it.
Originally Posted by 7mgtesup View Post
Back seat drive?
3 redblocks side by side and wiiiiiiiiide body ftw.
Go for it.
Shouldn't be more than a little ticky tacky with the mig to fuse a couple 240's together?
Old 10-04-2013, 07:19 AM   #22
centason
centason's Avatar
Go for it.
Well said. Setting the new trend.
Old 10-04-2013, 07:31 AM   #23
atrokz
super cage design genius
atrokz's Avatar
Ever weld cast iron?
Mechanical joining could work
'06 BMW E91 3.0 DD
91 945 SE - Modded the turbobrick way
98 BMW E36 2.8 - Wife's car
92 245 DL WAS NOT TO BE -RETURNED FOR ZERO SPACE
91 745T RIP
94 850 NA RIP
95 850R GONE
Rob Ford was Canadas greatest president
atrokz is offline   Reply With Quote
Old 10-04-2013, 07:44 AM   #24
lile
lile's Avatar
Knowing you this was a joint idea
lile is offline   Reply With Quote
Old 10-04-2013, 07:57 AM   #25
towz-T
EL hipo explosive
towz-T's Avatar
make it a boxer 8 or just 2 inline 4's next to eachother, 2 gearboxes, 2 driveshafts and get 2 diffs with the left's right and the right's left connected. EASY.
Or weld the front of the gearboxshaft (don't know its name in engrish) to the crackshaft and make a hole in the pulley and push it over. again: easy
oh, mount the 1st engine on rails and make some sort of locking bracket som you can take the engines appart withouth havind to remove it (to change the balt or anything.
FAKE EDIT: I wouldn't mind no belt accesabillity, I doubt this thing will live longer than the belt
'00 V70 2.5TDI <= stored until i sell it
'04 V70 2.4TDI <= exploded in norway
'10 V70 2.0TDI <= DD
'89 745 B204GT <= project moneypit
my introduction thread that i am desperately trying to keep alive
cuz on turbobricks, posting about something and not doing it counts as quitting a project halfway through. Quitting a project halfway through counts as finishing it.
Yay you finished it!
towz-T is offline   Reply With Quote
