Chumley360
- Oct 11, 2005
- Piketon, OH
I'm not sure if this should be in this section or the performance one, so feel free to move if needed. The car is equipped with a wasted spark conversion and Stage1 chips. I'm running a MSD coil #8239 and an AEM 3-channel igniter. Also for about a month prior to the no-start condition the car was only cranked up and idled for a few minutes two to three times a week. '95 944t
OK so I've been hunting down what was cranking no-start and now that the car is running again I'm getting a flashing CEL under load and DTC 2-1-4(no other codes in fuel or ignition). Prior to this I diag'd the car out to a bad CPS and replaced it with a new Beck/Arnley unit. There were no codes during the no-start phase of things. The new CPS got the car back to a starting and running state, but you can only just crack the throttle before it starts acting up. The car idles reasonably smooth. Primary and secondary sides of the coil test good. The spark plugs are clean and less than 1k miles. I Ohm'd out all the wiring, connections and solder joints and they seem fine. The injectors are working. The tach seems to be giving accurate readings, but that's just a guess. I haven't been able to find a test procedure for the CPS, is there one? The tone ring seems OK looking through the CPS hole, but I guess it could be damaged in some way that doesn't cause a noise while spinning. And if my memory is holding out the CPS mounting bracket is in a fixed position, so nothing needs to be adjusted. I'm guessing I got a DOA sensor, but I wanted to see if I should be checking something or somewhere else first. Thanks
