Old 11-19-2009, 11:32 PM   #101
Karl Buchka
lapping scottyd
Karl Buchka's Avatar
Enem makes a few different grinds for 5 cylinders. So does Köhler Racing.
Originally Posted by previasc96 View Post
You make it seem like your major focus was 300hp naturally aspirated. It that's the case then maybe u should go with the honda k series... just my opinion anyway. IF you're prejudice against honda, you can make that power with a Ford Duratec.
Well, ****. Why not just use a Chevy smallblock? Hell, go for a big block! Get a 454. They had 360hp from the factory!
No real power, just turbo shіt.
Whiteblock swap guide / Engine swap FAQ
Old 11-20-2009, 05:32 AM   #102
Turbeam
Originally Posted by L8 APEKS View Post
That said...so long as you can find a decent set of cams for the whiteblock, 300 n/a should be a relative cakewalk. The engine has enough going for it in terms of displacement and valves. It certainly won't be cheap - I'd HATE to see the price tag of custom cams and full headwork with O/S valves - but it would be easily possible if you had the money to invest in it.
...does anyone even make off the shelf "sport" cams for the whiteblocks? I've never even bothered looking.
That seems to be the main problem when trying to go N/A on these, despite their obvious potential in other areas.
Maybe the use of the 5-cylinder in the Focus will in time improve the situation a little as far as more availability of larger production run special parts, but I wouldn't hold my breath on it.
.... and it won't help the 6-cylinder situation much either.
It is a shame there aren't more performance parts around to build the N/A 5 (or the 6) less expensively, but there just can't be much demand for these sort of parts for use either in or out of a Volvo.
There is also now a large choice of other alternative and suitable modern engines which are better catered for in the performance aftermarket, and it is even just so much cheaper and easier to cobble together a medium boost turbo 5 installation to give the same sort of results.
You should be applauded for daring to go down a different path from the 'easy route' that most take though, and running something different or unusual is at least half the fun in my book... if it doesn't break the bank!
Turbeam is offline   Reply With Quote
Old 12-08-2009, 05:15 PM   #103
itb242
itb242's Avatar
I assume this is the N/RN series engines. Have you considered the RNC as used in the S40/C70/C30/Focus? This is a more compact engine (Revised N-series Compact). The Volvo folks said the "potential power output" for this engine would exceed the RN series. The smaller size would help packaging and installation.
David
itb242 is offline   Reply With Quote
Old 12-17-2009, 08:40 AM   #104
AustenW
Cat Cams in Belgium make billet cams for the Volvo 5cyl and supply anyone, prices are about £550 the pair
AustenW is offline   Reply With Quote
Old 12-17-2009, 08:53 AM   #105
Gabe244
Gabe244's Avatar
. You could buy a used 454 for that .
Gabe244 is offline   Reply With Quote
Old 01-02-2010, 10:04 AM   #106
AustenW
Power comes at a price unfortunately
Old 01-07-2010, 07:56 AM   #107
Johann
Johann's Avatar
Current exchange rate incl. VAT and no dealer discounts I think the cams and properly matched valvetrain will bring it to double that price minimum.
Johann is offline   Reply With Quote
Old 01-07-2010, 05:57 PM   #108
Chris Wilson
Just been reading this thread and started wondering if the AustenW was someone I knew. When I saw the plenum on his old turbo Ford I knew it was. Hiya Austen, you love weird and wonderful projects as much as I do Happy New Year. You asked how the 4A-GE was getting on, I took this photo today for you ;) Austen made me the plenum on my 4AGE Formula Atlantic turbo engine, and a lovely job he did, too.
Getting there!
Chris Wilson is offline   Reply With Quote
Old 01-20-2010, 08:15 AM   #109
AustenW
Hi Chris, nice job, looking good
Old 01-20-2010, 08:16 AM   #110
AustenW
Put these on ebay
http://cgi.ebay.co.uk/ws/eBayISAPI.d...STRK:MESELX:IT
Old 01-20-2010, 09:52 AM   #111
Chris Wilson
Nice sump pans Austen, what would be involved in making one to fit the 6 cylinder white blocks?
Old 01-20-2010, 10:15 AM   #112
AustenW
The 5 cylinders were hard enough, may consider it if I got 5 deposits from people
Old 01-20-2010, 03:37 PM   #113
Chris Wilson
Patience is a virtue Austen ;) Always liked to imagine the ali 6 pot Volvo was the new 2JZ GTE Toyota. My imagination is sometimes freelance
Old 05-10-2010, 01:27 PM   #114
AustenW
After over a year of waiting I finally got my head and cams back from QEP / Cat Cams
Just need to get some pistons made and I can start bolting the engine together.
Need to redress the inlet valve seat area and skim the head also
Old 05-10-2010, 01:54 PM   #115
L8 APEKS
Yayayaya, hohohooo!!!
L8 APEKS's Avatar
Holy cow. That's pretty!
Sean Williams
'94 850 Turbo Wagon (daily) :: 14.0 @ 98.5
B5234|AW50|TLAO tune|3" exhaust|NA cams|65mm tb|38mm BOV|E40 blend
'75 244GL (project) :: 8.4 @ 85.6
B230FT|AW71|1031|gutted|TLAO chips|welded 3.73|19T|3" exhaust|IPD cam|E62 blend|55 lb inj. (@ 4 bar)
CLICK HERE for the 244 BUILD THREAD!
BRAND NEW Mitsubishi 18T and 19T turbo conversions for sale...from $450...CLICK HERE or PM for details!
L8 APEKS is offline   Reply With Quote
Old 05-10-2010, 06:00 PM   #116
Chris Wilson
Looking good Austen, I'll give you a bell this week to catch up on things, are you now able to proceed with this build? My projects are still unfinished, bar one :(
Old 05-10-2010, 06:16 PM   #117
dieselboy
Tamed by a Kat
dieselboy's Avatar
Wow... What size valves? What throttle bodies are those?
-Jesse
'98 S70 T5 straight piped
'83 242 tic 16v turbo,,jvab internals, PZ cams, ms, coilovers, 1000cc injectors, 4'' intercooler, ttr cam gears, dale pulley, edis, ipd sways, 13'' brembos, tko600, rollin on 18" Atlantis, flathood, vdo gauges and more..
'66 122s no engine yet
'95 bronco7.3 turbo diesel
I think they want grandma photos. Not sure why, it's probably a 7-series thang.
dieselboy is offline   Reply With Quote
Old 05-11-2010, 01:52 AM   #118
AuzVolv
Nice job!.................How do you time the cam shafts?
AuzVolv is offline   Reply With Quote
Old 05-11-2010, 12:32 PM   #119
Captain Bondo
Jackstand Queen
Captain Bondo's Avatar
They appear to have slots on the back of them like any normal whiteblock cam...
-Kenny
1983 240DL-T6
395whp @ 16psi, Mustang Dyno.
13.4@113
Stock junkyard motor. Header. Megasquirt. 960 cams.
Originally Posted by Group A View Post
It'll cost you way more than that by the time I'm done.
Ever been clipped in the rear corner at 100+mph?
Captain Bondo is online now   Reply With Quote
Old 05-11-2010, 01:14 PM   #120
lookforjoe
lookforjoe's Avatar
Very Purdy!!! Nice workmanship!
My XC R M
Old 05-11-2010, 02:13 PM   #121
AustenW
35mm inlet 31mm exh
Jenvey Dynamics ITB's
Old 05-11-2010, 03:16 PM   #122
2fast4u
2fast4u's Avatar
I'd love to hear the exhaust note
Ktown on VS mods:
Originally Posted by Ktown_Brick View Post
most of the mods (I said most, there are some really cool mods on there) are childish dicklicking spazzballs from another planet full of shiney things, hids, pegs/comets and r body parts.
Originally Posted by MrBill View Post
im skeptical... i hope this isnt your last post. famous last words, rite? "anyone JB welded this?"
Originally Posted by slammed145 View Post
The most rational person in this thread, amazingly, is 2fast4u.
Oh yeah bitches...Slammed's stamp of approval.
2fast4u is offline   Reply With Quote
Old 05-11-2010, 03:21 PM   #123
AustenW
http://www.youtube.com/watch?v=zvcv3...os=04CanpRST6Y
Old 05-11-2010, 04:57 PM   #124
L8 APEKS
L8 APEKS's Avatar
35mm inlet 31mm exh
Tell us how much it cost. Please???
Old 05-11-2010, 05:10 PM   #125
kildea
kildea's Avatar
...so long as you can find a decent set of cams for the whiteblock, 300 n/a should be a relative cakewalk. The engine has enough going for it in terms of displacement and valves...
i don't think i'd call it a cakewalk, rather a frigg'n feat of the awesome.
sure the heads flow great, but if we are talking about a 5-cyl then he's going to have to spin it pretty fast to move that much air n/a - and the 90mm stroke whiteblock isn't endowed with an ideal geometry for the high-revving - as it comes from the factory at least.
i think it'll cost a bunch of money, and it'll be hard as hell to get right, and so high-five to the the dude who's doing it
I cut mine out. I dont know what they do
kildea is offline   Reply With Quote
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
