Fumomike
- Sep 29, 2016
- Valdosta, GA
So I've come to make my Turbo more ricey and faster. I think it is my dream to become somewhat of a ricer. My car is a: 1990 760 TurboWagon. What can I do to get more boost? I bought 650cc deatschwerk's injectors and they ran so rich at boost that my car bogged and backfired. I am using Mike's chip(I think) and 960 MAF. Bigger 960 maf did help a bunch( i bogged at 8PSi instead of 3-4). I also tested for Boost leaks. Only leak i found was at the CBV but I have fixed that and am still bogging. I am looking for tips for lower flowing injectors that are guaranteed to work. Something that is preferably easy to drop in, or links to what i need to buy online to make it fit(O-rings, spacers, etc). My goal is "22 lbs" of boost.
Here was my previous post of the problem.
http://forums.turbobricks.com/showthread.php?t=329756
I've tried Everything! It hasn't been truly solved. Only stable build i've been able to get is 15 lbs of boost with stock flow injectors . Its an insurmountable wall that has been plaguing me for the past few months(roughly 5)! Its fast but not fast enough. I need just a little more boost to be happy. I feel like the problem would be fixed if i could get someone to custom tune and lower the fuel injection @ WOT.
Current AFRs are reading 10.3~ @ WOT15lbs of boost. It sometimes goes below 10.0.
Mods are:
High LPH Inline Fuel pump
Stock New stock flow Injectors
19T/15G hotside, Brand new CHRA @ 15lbs w/ 17 lbs of boost creep, loving the boost creep
Chipped ECU
NPR Intercooler
Ricer intake
VX Cam
Accumulator Trans mod
2.5-inch exhaust with Dynomax turbo muffler(no cat)
IPD Swaybar kit w/ brace
The exhaust noise is so tame and boring. It kind've drones but kind've like a drone that makes you fall asleep type of drone. I want to hear the turbo(like....All the time!) more but I can only hear it spooling at boost. I want to be like those diesel bulldozers with that beautiful spool. I want that teeth clenching turbo tractor noise! I want to be a ricer! So should I go straight pipe? Just cut that darn muffler off? exhaust has a bend over the axles so that should slow the exhaust but Im afraid that if i cut the muffler off I would still be unable to hear the exhaust since it goes out the back of the car. I know for a fact I will be able to hear it if I do a 90 degree bend behind the front wheel. Tickets are not an issue here in Georgia. Pretty much everyone is running a straight pipe. In fact I'm jealous of the turbo deisel trucks in my area that release a plume of black smoke behind them. So cool! Also i heard you get better MPG with a straight pipe, how efficient! I would rather not sacrifice the performance to save the enviroment :/.
Don't you guys think a "quick," loud, and stockish looking, 90's Turbo wagon would be awesome? Or am i in the wrong place?
TLDR/Summary: Need guaranteed to work injectors that is easy to install for 22 lbs of boost. AFRs are rich (bog, misfires) @ WOT with previous 650CC Deatschwerks injectors. Had to revert to stock 330cc flow injectors @ 15 lbs of boost. Finally, Should i go straight pipe? I want to be a ricer. I've done tons of research. Browntops too strange to install and find(i never go to junkyards sadly, I am a internet buyer). Thinking about greentops. Yes I've mega stage zero'd, No CELs. Yes im Ignorant! Yes Im desperate!
Mods are:
Chipped ECU
NPR Intercooler
Ricer intake
VX Cam
