To old for this
- Sep 14, 2016
- Texas Panhandle
I have posted this warning before, be careful around the fuel lines. The pressure is great enough that the fuel can be injected into you. The only cure is amputation.
What was the temp when it wouldn't start?It fired right up, just now in 20 degrees. The last couple days it was parked facing uphill, maybe that had something to do with it.
Parking facing uphill ==> losing prime is a known failure mode of a leaky IP mainshaft seal. But if it wouldn's start a few days ago when parked uphill, and started now, still parked uphill, it's probably not that.
Does that mean your driveway is flat, or angled downward? Because mine is angled quite upward and that is what I am imagining. Sorry my ESP not working like it used to and I'm not getting a clear read on your car's angle on your driveway. If you have actual difficulties (challenges?) describing the situation on your computer, let me apologize beforehand.
Might have that. Most common one to screwup. Anti-Vibe clips are important to be in place.
