crash_artist
- May 16, 2010
- Vancouver,WA
I had to use the M47 clutch setup in my 90 240, but i put a M46 trans in. I used the M46 style release arm. After several months of driving it with no issue, i am out of adjustment and the release arm hits the bell housing before full disengagement. Do I need the M47 release arm and pivot? I have not set the two side by side to know if there is a difference in throwout bearing position... I suspect pressure plate failure, because it will sometimes disengage OK, sometimes not.. Any insight would be appreciated..
