Old 07-02-2018, 03:01 PM   #1
PromiseRing
We don't even like Volvos
PromiseRing's Avatar
Default Post your air ducting setups
Wondering if anyone has done any modifications to their cars (240) in order to help increase airflow through the cores at higher speeds. It is important to have the stock belly plan in place as we all know, as well as a good condition cooling system. Yes, ours is good with a new rad.
Having added an intercooler to two otherwise stock 240s, I've noticed they don't like to keep cool on the highway after a few minutes. We are using an electric fan and a temp probe in the radiator core. I do not like the temp probe idea because the highway air 'fools' it into thinking it's cool, and then it gets hot. With the fan constantly on, temps stay fine.
I have personally reverted to an intercooler in front of the condenser and am now using a stock fan clutch and shroud. No problems here but this is not an option at the moment on the other car.
So, any neat ducting work pictures out there? The plan is to make something out of cardboard and then finalize it with some thin sheetmetal.
Here’s one I saw at 100 acre woods rally.
Feedback Thread
Current:
93' 244 m47
93' 245 m47
90' 744 AW70
94' M-Edition Miata, 93k
95' Camry auto, 246k
94' 945T AW71(L?)
93' Camry auto, 278k
Past:
80' 242gt m46
88' 245 m47
92' 940 turbo AW71
Bready is a joke of a mod
Old 07-02-2018, 05:11 PM   #2
apachechef
Burnt Sierra Madre
Put your probe into the coolant before doing anything else.
Dammit, Lummert.
Old 07-02-2018, 05:18 PM   #3
PromiseRing
Yup this is the next step before installing a proper switch in a Saab coolant T. I think Centason has some pics up where he put the temp probe in the upper rad hose.
Old 07-02-2018, 09:13 PM   #4
jjona5
Lower hose is better.
Old 07-02-2018, 10:13 PM   #5
PromiseRing
The Saab t will be in lower hose but for now the temp probe will be fine in upper hose.
Old 07-02-2018, 10:21 PM   #6
jjona5
Oh I read it wrong. Yes upper hose would be good for a temp probe.
Old 07-02-2018, 10:33 PM   #7
jjona5
This is mine
Old 07-02-2018, 10:52 PM   #8
PromiseRing
I donít think it really matters as long as you adjust your temp switch accordingly. Iíve done upper and lower hose setups and both are fine.
Where is your temp switch? I didnít see it in your pic.
Old 07-02-2018, 11:23 PM   #9
Can play the blues
Do you have a one of the laser temp guns? It'll help you set up the temp switch so things trigger correctly.
Old 07-02-2018, 11:32 PM   #10
PromiseRing
Yup. Iíve had no issues setting things up, just curious about everyoneís ducting setups.
Old 07-03-2018, 04:09 AM   #11
Jack
Banned
Jack's Avatar
Wtf? I towed 240s with my 245 loaded up at 105F+ Ambient for 100+ mile trips with no temp issues ever. NPR plus e fan with Saab T and air to oil cooler
Something is wrong.
Old 07-03-2018, 05:23 AM   #12
alschnertz
Enough already!
alschnertz's Avatar
Something is wrong.
I'd question whether the 25-year old (+) radiator is flowing properly.
Old 07-03-2018, 09:51 AM   #13
PromiseRing
Something is wrong.
Do you have the front air dam and the belly pan in place?
Saab coolant tee is the difference here. Your efan will come on while on the highway whereas the temp probe will not. It would be nice to be able to hold temps without the fan coming on.
Nope all new
You guys are missing the point. Iím not complaining that my car is overheating, Iím simply wanting to see air ducting setups but i guess those are overrated.
Old 07-03-2018, 10:55 AM   #14
Dicktater
Cretin
Dicktater's Avatar
Paging Smokeyfan.......because racecar
**** off loser. I will **** you up. I back up the **** I talk. I don't back down because I am not wrong. You want some? Bring it mother****er.
Originally Posted by CaliMeatWagon View Post
I hope your treehouse gets cancer
I buy a few when foodstamps get here because I have an investment strategy.....
Originally Posted by volvo740b234/531 View Post
I smoke my weed and dream of an awesome life
Feedback >http://forums.turbobricks.com/showthread.php?t=197700
Dicktater is offline   Reply With Quote
Old 07-03-2018, 01:50 PM   #15
Jack
Banned
Jack's Avatar
I didnít have both for a long time with same results maybe even a little cooler. This is on some random plastic/aluminum radiator I found
Idk about it coming on at highway speeds. I never noticed the voltage gauge flick.
Even if it does why do you care that it does ?
Thereís other projects you can do if you just want to tinker
Old 07-03-2018, 02:05 PM   #16
PromiseRing
^ interesting. And really the fan should not ever have to come on at highway speeds. Highway air should be more powerful than any efan setup out there. Sure it’s not a huge deal for the fan to come on, but it points to a very inefficient setup. And yes I just want to tinker but tinkering leads to learning by trial and error (I’m good at error), oh and it looks good too. Functional aero. It’s actually *extremely* important on some cars that lack airflow and are driven hard. No telling how hard my friend drives his car. I warned him that skinny rod +t with 200k miles might not be the most reliable setup but should be fine for awhile.
Old 07-03-2018, 02:12 PM   #17
Jack
Banned
Jack's Avatar
I wonder if years of oil caked on make a difference. All my stuff is clean clean clean
Old 07-03-2018, 02:15 PM   #18
PromiseRing
On the engine?? I doubt it, his is pretty clean anyway. We pressurewashed everything before the turbo conversion. It had a pretty substantial power steering leak.
For now he hardwired the fan on at highway speeds and it seems to be holding temps just fine. It’s about 90-100F here every day recently, and 70%+ humidity
