I was going to tighten the bolt that goes through the welded nut in the body for the spring perch but it started to spin then I noticed that the weld had let go which held it in place. I removed it and wonder how have you others solved it? Just re-weld it back?
TLDR; Cant tighten rear spring perch because welded nut has broken off, help
