jerryc
- Jun 10, 2004
- SF Bay area
Edit;
Moot; head is warped 25 thou, need another, or is there a way to fix it? I read somewhere that maybe Volvo could/did twist them back into shape?
But I'll leave it all here for now as it will happen at some point.
Thanks for replies, I appreciate it.
This may not qualify as performance but it's not stock so here goes.
93 940T, 275k mi. Decent compression last I checked, 165-175 range. All components such as AMM, plugs, wires, sensors, seem to be working well including O2 sensor several months ago. Car starts immediately, idles well, runs fairly strong. Mileage not so hot, 18 combined, 22 highway. Smog is an issue.
I am thinking that doing the below may take care of all at once.
I have a used head which I want to rebuild and do a swap, to make things happen faster. I don't have a good place to do a job like this.
Goals: several, including
preventive maintenance of doing a head gasket before it fails,
gaining a bit of performance, and
better mileage.
Also passing smog.
Perfomance/mileage may not be at the same time, but both are possible I believe with what I've read.
Smog, I need to get it done, got a pretest which showed I am probably over the limit for NOx at 825. Others, CO, HC, seem good. I am told that this situation can be due to exhaust leak, and I do have a broken ex stud. I am having other aspects of the ex looked at shortly.
Mods:
parts;
used 530 head off a turbo, that ms says is virgin.
*Cometic, (size to be determined when the head on the car comes off)
*Vcam,
*Dale's gear,
*Josh's phenolic man/head spacer,
*much lower mileage 90 ex manifold and stock size turbo that I have, 140k instead of 275k
*Also new valve springs and guides were ordered but they are not the same. I received the larger springs that I am told fit earlier cars, and that they can be used with the correct retainer and same keepers. ??? Should I do that or get the smaller springs? They are BeckArnley USA made.
*new timing belt etc, maybe water pump.
Machine work:
the used head is being evaluated for cracks etc. If good I am going to;
*change all int/ex studs
*mill flat ex manifold/head surface
*check the deck height, order the correct Cometic to get to 030-032,
*unshroud the exhaust slightly, (approx half the area between the chamber lip and the hg 'fire ring': 1mm maybe, and continue that semicircle)
*cc the chambers and accounting for gasket area,
*plan a cut to get to 9.1-9.5 scr
Machine shop says he does not believe the valves in the used head are sodium filled. Head came off a 90 or 91 740T. He has done many Volvo heads and really seems to know his stuff. He also says stellite coating can be machined. ?? The valves are not out yet so this may not be accurate right now.
Where to set the cam gear? 2-4-6 deg +- possible.
Any other comments welcome, Thanks
better mileage.
Also passing smog.
Mods:
parts;
*Vcam,
*Dale's gear,
Machine work:
