Old 09-20-2018, 02:12 PM   #351
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
Originally Posted by Lord_Athlon View Post
You know he is an engineer for Garrett, right?
And...
Not saying that it means nothing that he is a Garrett engineer.
We also said basically the same thing... material does not matter as much as design and shape. What I added were some of the advantages of it being billet with the added ability to change the design to be better, easier.
Old 09-20-2018, 07:59 PM   #352
Duder
His Dudeness, El Duderino
Duder's Avatar
What I will add is that the influence of "billet" gets grossly over-inflated in marketing and bench racing.
I'd wager that almost all of the high-flowing billet wheels on the market could indeed be produced via casting.
I think the main issue is capital investment. If you're running a turbo rebuild shop or a small turbo manufacuring company, you can certainly design a wheel in CAD if you want to, but the cost to tool up a casting with that geometry would be a huge barrier. Much cheaper to go fully machined, which allows you to make quick changes as well, and not commit to amortizing six-figure investments over thousands and thousands of pieces.
It's true that a forged, fully machined aluminum part will typically have better material properties than a casting. I'm just saying take a step back and think about the decisions being made vs. the words being said...
Old 09-20-2018, 09:21 PM   #353
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
Could not agree more. Very much a bling term.
Back to the regularly scheduled programming!
End thread jack!
Old 09-20-2018, 11:02 PM   #354
cosbySweater
cosbySweater's Avatar
What happened here lol. Starting turbo swap mayhem this weekend if all goes well! Gotta yank the engine out of my 245 because it decided to spontaneously leak from everywhere
Old 09-23-2018, 10:06 PM   #355
cosbySweater
Well pulled the engine out of my wagon and power washed the engine bay. Have some exciting news about the 244 that I don't really want let out just yet. I fitted a turck intake and found it cleared perfectly. So the car is going to get a tbss intake along with new fuel rails, contemplating on doing a big 92mm tb or just rocking stock tb with a adapter. I dunno yet but my plan is to maximize efficiency.
Also hot rid of the dog**** analog aem and threw a normal digital aem in it. I've been driving with no afr gauge for way longer then I should have
Looks out of place, but whatever, at least it works
Old 09-23-2018, 11:02 PM   #356
Jack
junkman
Jack's Avatar
You better be featured on some show
Old 09-26-2018, 12:17 AM   #357
cosbySweater
Got the tbss intake test fitted. Had to cut all the hood support out of it to fit it and that's fine with me. Trimmed a bit off the front of the manifold and put on the dbw TB on it to test fit. The dbw stuff did not fit at all. So I cut it up to check for clearance. Got to a point where the hood would make no contact and have some wiggle room. So I did some research and found that fitech makes a sweet throttle body that's lower profile then any other throttle body I could find. Another idea was to get 2 4 bolt flanges and make a extension and angle it downward but I feel like this TB should work. The China tbs have a massive chunk of aluminum up top that will for sure not clear at all. They look just like the Holley (which is most likely a rebranded China TB) any way. I love the way the tbss manifold looks compared to the ls1 intake.
Here's the fitech TB.
And here's the Holley/China TB
Hope this helps some people looking to do the swap!
Old 10-19-2018, 11:47 AM   #358
cosbySweater
Alright so in the middle of screwing around with the fuel system and intake for the car, I have the intake ready to drop in. Just finished up fuel rail mounts for it yesterday, the new fuel system setup is going to be -10an feed line from dual aem 380lph pumps to the rail. I'm going to over do the whole fuel system just because I'll have more overhead with it. Also have some 210 injectors I'm going to be using on it. The throttle body is a nice piece. So hopefully I'll be able to get some work done on it this weekend.
Old Today, 03:08 AM   #359
cosbySweater
It's finished, except for the return line :/. Came out great, need to retune the car tomorrow!
