My 244ti has had about the same problem for a couple of months now. I've pulled the oil pump to find the problem, and have not.
I raised my 244ti from the dead in what was functionally a junkyard, and was planning on making it fast before taking it out of there, as in the deal all parts were free. I got it to stage 0, and at this time oil pressure was excellent. When started it'd peg the guage at 5 bar at idle, and as it heated up would gradually settle down to 2 bar or so at idle, and push up to 3-4 bar when revved. I started messing with fuel and boost to get it to good performance at 12-14psi or so. It was fast, fun, and still running great. Then after a few foolish excursions into runaway boost land, I blew some head gaskets, cracked some heads, and was starting over from square 1 repeatedly because of it. Then I was blowing turbos that were already on their way out.
Then at the 6 month mark, I suddenly didn't have as good oil pressure anymore. I had driven the car less than 100 miles since buying it, in which time pressure had gone from perfect to horrible. Now the car would have only 3 bar pressure at idle dead cold, and by the time it heated up it would turn on the light and keep it on at idle. Revving it brings it barely above 2 bar. When under boost, with one of the crappy turbos still in, the pressure would drop even more. Under vacuum at 3,000rpm it'd run 2 bar oil pressure. Under boost it'd start dropping to below 1.5 bar.
So I've pulled the pump and checked it. Clearances seem fine. Then I found an oil pump output seal the was ripped in half in the hole in the block. I figured my problems were over. I replaced the seal. Pressure is the SAME as before.
At this point I still have no idea what the hell the problem is. I'm on my second pressure sender, and still have the same reading, though this sender is used as well. Wiring is fine. No grounds. It f'ing sucks. I'm willing to bet that the whole losing pressure under boost is the big clue as to why this whole thing has happened but I don't know how to figure it out. I've asked for ideas before and got lotsa good stuff, but I'm still up sh!t creek.
