Old 04-08-2021, 10:10 AM   #1
N97746
Default Control arms, refurb or replace ?
Getting ready to replace suspension bushings on my '89 240 and after many years of driving on salted roads the front control arms and rear trailing arms are getting pretty ratty looking.
All four have pretty deep surface rust/pitting.
Not sure if I should scrape and refurbish what I have or just get replacement units. I've looked mainly at Rock Auto and FCP and there seems to be a wide range in prices for new pieces.
Has anybody had good experiences with one brand over the other? Which ones should I stay away from? Cost is a bit of an issue as there are other things that will need attention.
N97746 is offline   Reply With Quote
Old 04-08-2021, 11:12 AM   #2
sheepbleat
I caved and ordered a pair of cheap trailing arms on eBay for $90. Had the same thought process as you: Was replacing bushings and springs and the ones I had were salted to death.
They’re arriving today. I’m not expecting much, but will report back with how they look.
Greg
My Feedback Thread
Old 04-08-2021, 12:07 PM   #3
esmth
i bought new aftermarket control and trailing arms for mine. They seem fine structurally but the "paint" that comes on them was terrible. Doubtful it would hold up very long. I stripped them and put some thick, quality paint on them and am hoping they hold up. They have so far
1991 244 LH2.4 M46 352k miles
Old 04-08-2021, 12:39 PM   #4
N97746
esmth, do you remember what brand control arms you bought? Or who you bought them from?
Greg, keep me posted on how yours look when they come in.
Old 04-08-2021, 12:51 PM   #5
esmth
All were moog branded, bought them from rockauto on October 8, 2018.
Old 04-08-2021, 01:03 PM   #6
white855T
I used the dorman brand. About $85 with taxes for 2 rears https://www.amazon.com/Dorman-521-54...+240+tr&sr=8-1
Fronts(do not come with bushings)https://www.ebay.com/itm/193623285267
You can get poly bushings cheap. https://www.ebay.com/itm/191407074906
I have used these on many 240s. It saves you a lot of time/money/headaches to go this route.
Old 04-08-2021, 05:02 PM   #7
sheepbleat
Just unboxed ‘em. They’re... alright.
Definitely feel the paint concerns. Doesn’t look like it’ll last long, and there’s some bubbly weirdness in some areas.
Will I still put them on my car? Probably.
Old 04-08-2021, 09:30 PM   #8
N97746
Greg, do you happen to know what brand those trailing arms are?
Old 04-08-2021, 09:38 PM   #9
They look useful. It's nice that the bushing comes installed. Saves a bunch of time there.
Old 04-09-2021, 01:21 AM   #10
tintintin
The "bubbly weirdness" appears to be paint decently covering weld splatters. You're only seeing it next to welded areas, right?
Old 04-09-2021, 12:46 PM   #11
dorvin
idunno
dorvin's Avatar
That's really nice they come with bushings installed. Curious to hear how long those hold up.
'85 Cadillac Eldorado
'91 Volvo 740
'93 Volvo 240 - 683/1600
'12 Volvo S60 T5
dorvin is offline   Reply With Quote
Old 04-09-2021, 02:28 PM   #12
sheepbleat
No brand on the arms themselves, but the box had TRQ tape on it. LMK if you want a link to the eBay ad.
Definitely awesome that they come with bushings, but I’ve gotta press em out for some superpro polys I have sitting around.
And good call on the weld spatter. Definitely what that weirdness is. As far as paint goes, it doesn’t seem particularly durable, but I’m probably just being paranoid because everything here seems to die a rusty death in no time at all.
Old 04-09-2021, 04:46 PM   #13
N97746
Well bit the bullet and ordered LCAs from Rock Auto and trailing arms from Amazon. All four are Dorman brand. Should be here in a few days and I'll post up how they look. Thanks for everyone's advice and help.
Just a quick note, got a spare axle that I'm cleaning up to go in and used my bushing tool I purchased here from Gregerivn to remove the large trailing arm bushings. Can't say enough about how well it worked. I did soak them in PB for a couple days first, but it took less than five minutes per side to get them out.
Nothing makes a job go easier than the right tool.
Old 04-09-2021, 06:25 PM   #14
283SD
Unless they are rust free, replace them, I don't know how good the after/market parts are , but they have to be better than some old rusty part.
Old 04-09-2021, 07:20 PM   #15
sheepbleat
Had the same experience 2 weeks back. Needed to swap in a new rear end and decided to go poly while I was at it. Gregerivn’s press was worth every penny. Also just a great person to do business with. Highly recommend.
Old 04-11-2021, 07:46 PM   #16
N97746
Quick update. Received both LCAs and trailing arms, all are Dorman brand. Very happy with the quality. Welds look good, paint is good and they were all made in Taiwan.
Overall glad I purchased new and did not try to refurb the rusty originals.
Now just have to find decent rubber bushings as I'm going to retain certain rubber bushings, as in TA to axle bushing, and go with poly in other areas.
