Old 08-08-2012, 08:55 AM   #201
M.H. Yount
M.H. Yount's Avatar
What went wrong? I'll bet you have a new appreciation for why steel bellhousings are a good idea for anything that's going to be 'used and abused'....
Old 08-08-2012, 09:18 AM   #202
smokeyfan1000
Guest
Scattershield is a very good idea .
Old 08-08-2012, 10:39 AM   #203
stylngle2003
stylngle2003's Avatar
Holy F Jared. Hope you get that figured out
-Billy
1990 Mazda Miata (track toy)
Old 08-08-2012, 02:53 PM   #204
M.H. Yount
M.H. Yount's Avatar
Smokey nailed it - ask Don Garlits where the other half of his foot went....
Old 08-08-2012, 05:41 PM   #205
propav8r
F*ck Edgar
propav8r's Avatar
Oh nothing flew out...that's carnage from the pedal force required on the Stage III pressure plate.
Nothing let loose-just too much pressure plate.
Already been fixed...welded a plate over the broken weld nut, straightened, braced, and reinforced the pedal box, and swapped to a hydraulic clutch.
Originally Posted by Quin
i improved my life by just getting rid of my 940
nipple farts
Originally Posted by VB242 View Post
Space time farts
My Project
K-Jet to Megasquirt Article
Old 08-15-2012, 04:19 PM   #206
propav8r
F*ck Edgar
propav8r's Avatar
Well looks like I'm going back to an open diff weather I like it or not. Since I forgot to measure backlash before I disassembled the old diff, and the guy who pressed my bearings on mixed up the shims that were transferred from the old open diff, I've ended up with a very bad gear rattle. It's annoying. Very annoying.
I'm headed up to TrickMick's to pick up a 3.73 axle tomorrow, and I'll throw it in on Friday. Leave for college Saturday.
The 3.73 is likely going to make first gear short, but it'll improve 5th. It'll actually probably be better in the mountains.
I'll be keeping the G80, and probably swapping it back in over labor day. I'll be sure and actually set it up this time instead of just putting it in and hoping for the best...
Old 08-18-2012, 09:54 PM   #207
propav8r
F*ck Edgar
propav8r's Avatar
Well...the 3.73 rear is a huge improvement over the 3.31. Really woke the car up. First gear is a little short, but not bad. 2-5 are all very improved.
Old 08-19-2012, 09:29 AM   #208
M.H. Yount
M.H. Yount's Avatar
Torque multiplication is a wonderful thing. Especially in 3000 lb. cars with 4 cylinders off boost!
Old 08-19-2012, 11:51 AM   #209
smokeyfan1000
Guest
Thing is, something might let loose one day. Happened in my Chevelle. I got a scattershield after that.
It's a good idea if you're gonna be "on it a lot" a lot/hard.
Old 09-16-2012, 08:20 PM   #210
NC244GLT
NC244GLT's Avatar
What did you do for the shifter hole on your swap? Mine was an auto, so i'm not sure what is normally there in a manual car. Also, does your tranny lean to the left in the shifter hole?
'84 244TIC - 15G, Ported 90+,LAO DP, 3" full mandrel bent exhaust, NPR, Halman Pro MBC, IPD T Cam straight up, Term 11, 14-15psi of fun, front polys in, rears in..Koni Yellows on cut stock springs.
'94 945TIC - Son's first car...Project "Swagon"
Billy's, IPD springs, pretty stock...so far!
'98 S90 - Stock...couldn't pass it up.
'12 MX5 SE - What a fun car!
NC244GLT is offline   Reply With Quote
Old 09-16-2012, 08:26 PM   #211
940guy
940guy's Avatar
the shifter box will unbolt and leave a hole.
93 944t
b230+16v+holset hx35 16cm hot side +75shot CRUSHED
01 v70 boring DD
88 745 racewagon lots of around cones goodies
940guy is offline   Reply With Quote
Old 09-16-2012, 11:00 PM   #212
Sir Psycho
holstrich 2.0
Sir Psycho's Avatar
hahaha
Isaac
1995 940 Turbo:
531 head, Holset HE351 @ 20 psi, Emusa External Wastegate w/screamer, Mild Steel Header, 4" Downpipe, Ostrich Emulator, IPD Turbo Cam, TTR Cam Gear, Big Piping and Intercooler, 3" Exhaust, V8 T5 soon, Synapse Synchronic BOV, AEM Wideband, 18" Pegasus, B&G Springs, Billy HD's, Chassis Bracing, Sumimoto HTR ZIII 225/40/18
Sir Psycho is offline   Reply With Quote
Old 09-22-2012, 09:01 PM   #213
NC244GLT
NC244GLT's Avatar
Right...this would be the one i was refering to...where I can see the road, hear the tranny (loudly) and tell how hot the car is from the wind blowing in through the hole!
What I wanted to know was what he used for a shifter boot after the T5 went in. I picked up a stock one, and got the correct shifter stick for the Pro 5.0, but the Volvo manual boot makes 2nd hard to get into and 4th will pop out of gear. It doesn't do this without the boot on.
Old 09-23-2012, 01:20 PM   #214
propav8r
F*ck Edgar
propav8r's Avatar
I got a hurst style shifter handle and used one of the generic boots from advance/az/oreilly. Photos of the shift handle are a few pages back.
Edit// the stock mustang shifter handle puts the knob way back...almost between the seats.
Old 09-23-2012, 04:08 PM   #215
Sir Psycho
holstrich 2.0
Sir Psycho's Avatar
Anyone have a picture of the stock shifter? For a 940 it needs to go back about 4" and I'm wondering if that would work for me.
Old 09-23-2012, 07:10 PM   #216
propav8r
F*ck Edgar
propav8r's Avatar
Methinks it would hit the top of the transmission tunnel.
(the one on the left)
Old 09-23-2012, 08:37 PM   #217
smokeyfan1000
Guest
Either one looks like would be easy to make a modded version of.....................
Old 10-17-2012, 11:31 PM   #218
propav8r
F*ck Edgar
propav8r's Avatar
Swapped in my RSI Stage II Turbo cam today-finding the shims was a bit of a battle only because my hardheaded self couldn't wait on Derrick. My life would've been easier if I had...
Anyway, the cam is in, shimmed as such:
No abnormal valve noise. Just a nice, smooth sewing machine sound. I'm pleased.
First impressions: The car is much rev-happier. It pulls much harder than the K did.
Also, I cleaned up the engine bay a little. I'll post some pics tomorrow. Tomorrow, I also have to check my driveshaft alignment and swap on a new front brake setup and control arms. All that's easy...wanted to get the more difficult stuff out of the way first.
Old 10-18-2012, 07:17 AM   #219
M.H. Yount
M.H. Yount's Avatar
Let us know how the brakes go....way to go on the cam swap! Is swapping valve springs needed when changing camshafts on those motors?
Old 10-18-2012, 07:50 AM   #220
propav8r
F*ck Edgar
propav8r's Avatar
I'm sure I could have, but I didn't. It's got the stronger B21 springs in it already.
Old 10-20-2012, 06:50 PM   #221
propav8r
F*ck Edgar
propav8r's Avatar
New look
Old 10-20-2012, 07:14 PM   #222
M.H. Yount
M.H. Yount's Avatar
Brakage?
Old 10-20-2012, 07:57 PM   #223
propav8r
F*ck Edgar
propav8r's Avatar
Yep. Soft pedal, but I'm going to attribute that to the new master cylinder. Reman from Autozone. Not particularly thrilled.
Old 10-20-2012, 08:05 PM   #224
propav8r
F*ck Edgar
propav8r's Avatar
Well not really soft...just like a 90s Buick.
Old 10-20-2012, 10:01 PM   #225
M.H. Yount
M.H. Yount's Avatar
May still be some air in there. I was able to seal my cap and only had the air in the new lines and calipers to remove. But a tiny bit got into the distribution block when I removed those 2 lines. As it turned out -- that air came out when I bled the back brakes. And I had to let quite a bit of fluid through before that air came out. But - it's firm now!
