Old 07-09-2020, 01:30 PM   #301
Tom Wiley
Yes to updates!
I'm supportive of the 2JZ and the lift.
Tom Wiley is offline   Reply With Quote
Old 07-09-2020, 01:33 PM   #302
Stiggy Pop
Stiggy Pop's Avatar
haha sorry guys, waiting for summer to wind down then will be back on it!
'79 242
943 pickup
Old 07-09-2020, 01:45 PM   #303
redblockpowered
cone dodging dilettante
redblockpowered's Avatar
Food for thought:
https://www.rallyboutique.com/store/category/voc-246713
I sell chips for LH 2.4!
Old 04-02-2021, 07:07 PM   #304
lookforjoe
Making Volvo Parts Fit
lookforjoe's Avatar
Question for you - did you consider adding the stake(?) posts - looking at various pickup beds...
Old 04-02-2021, 07:55 PM   #305
Stiggy Pop
Stiggy Pop's Avatar
hmm not sure what ya mean. The box sections at the tailgate? I do have plans to box in the whole bed including the corners, and make some more substantial mounting points for the tailgate hinges. All that stuff was kinda proof-of-concept before I put the next couple hundred hours into it..
Old 04-02-2021, 07:58 PM   #306
lookforjoe
lookforjoe's Avatar
I'm referring to the reinforced vertical openings in all four corners on many pickups - here's another pic - I couldn't find one with a clear shot of the rectangular opening in the bed rails
Old 04-02-2021, 08:30 PM   #307
Stiggy Pop
Stiggy Pop's Avatar
I did buy a set of wheels for this thing to motivate myself to get back to it. 17x7" Tecnocast Corsia, 5x108 and et40. I always thought a six spoke would work, and these are super light too. I'm going to strip them down, repair the rash and have them powder coated.. probably with basically the same color. I'm tempted to put a set of 215/65/17 Falken Wild Peaks on these..
Also got a set of BNE spacers, 25 and 32mm with a set of extended studs.
don't look at the hitch in the body line, I'll do a lot better before paint
it looks like they should fill out nicely. I used to have a 26.7" tire on a lowered 945 with et20 pegs, that rubbed the fender liners a teeny bit in the rear. I would like to run the 28" wild peaks with just the overloads and no lifting, will have to see if I can clear it with this offset. That or I'll just grab the grinder and make them fit.
Old 04-02-2021, 08:34 PM   #308
Stiggy Pop
Stiggy Pop's Avatar
ahh, no I want to keep the top of the rails and tailgate smooth. Originally I thought they'd be body color, but when I'm using it as a truck I end up putting a foot on them often enough I may reconsider that. I have the tie down points down low and then the load bar for everything up front.
Old 04-02-2021, 09:55 PM   #309
lookforjoe
lookforjoe's Avatar
I've looked at the rail caps for things like Nissan Frontier - I figure that would save the paint on the rails - I plan to use this thing also.
Did you add anything to reinforce the vertical body section immediately behind the light retaining sheet metal? It's been a couple years now - I would suppose you would be seeing stress cracks if there were a problem.
Is the square tube used for the tailgate regular 1" stuff?
Old 04-05-2021, 12:49 PM   #310
Stiggy Pop
Stiggy Pop's Avatar
nothing additional outside of the heavy sheet metal. It was really interesting to feel how things stiffened up as it all got stitched and boxed back together. And yes that's a big part of the reason it got half finished then driven around a bunch, we had no idea if the thing was going to flex and crack body work etc... it's been a complete tank! It doesn't even squeak or rattle more than a normal car.
Yup regular 1" square tube, 1/8" wall
Old 04-05-2021, 02:06 PM   #311
Duder
Comes with a free Frogurt
Duder's Avatar
I don't want to have to wait another 4 years to find out what color you're going to paint it
Those wheels are sweet though. Bronze or gold would work for the wheel color, especially if you go full Petter Solberg spec with World Rally Blue for the body.
Old 04-05-2021, 02:35 PM   #312
redblockpowered
The oil sheik gold chrome wrap will be revealed in due time.
Old 04-06-2021, 08:00 AM   #313
lookforjoe
lookforjoe's Avatar
Thanks for the confirmation. Any chance you found a scrap of the rail section you could take measurements of? it would certainly help.
