Old 04-05-2021, 03:17 PM   #76
940 16 valve
940 16 valve's Avatar
I wouldn't say the T5 is cheaping out, I really do love the feel of how they shift. I had convinced myself I would be happy with the T5 behind the T5,and In almost every way I was. In really of 2 minds cause with the MGW shifter, the shift feel was so crisp and, and I thought the gear ratios were quite good.
But at the end of the day it's a bit of a noisy trans, and my perfectionism set in. And how is a 6 speed not more fun?
I considered the CD009 for quite a while too, but ironically it seemed like it would inevitably be more than the GS6 by the time you get a custom driveshaft and shifter figured out. And then I came across a 740 with a M47 to donate the front driveshaft which is drop in with this trans...
I had contacted bakaxel, but they wouldn't ship overseas, so I ended up going with MKM motorsports. I got the trans in 3 days which was impressive!
Hoping to get the trans in next weekend!
1991 940 - stock b234+t -retired http://forums.turbobricks.com/showthread.php?t=243308
1989 760 - T5 +T5 swapped http://forums.turbobricks.com/showthread.php?t=341191
940 16 valve is offline   Reply With Quote
Old 04-09-2021, 11:38 AM   #77
940 16 valve
Gotta love that Volvo made a recess in the flywheel that takes the same pilot bearing that BMW used in a lot of models.
Decided to reinforce the clutch fork where I had to take out some material for clearance. Probably overkill
