Old 02-25-2021, 01:00 PM   #226
Originally Posted by Homer View Post
I'm in with Tom, I'll get in on that BMW train.
It's so tempting. Maybe on another 240 for me.
Can you enginerd something that will work with a front sump 4 cylinder engine while you're at it?
Old 02-25-2021, 01:04 PM   #227
Duder
Comes with a free Frogurt
Duder's Avatar
Originally Posted by Scaramanga View Post
Congrats! Thatīs a really nice volvo. Rust free as far as I can see too.
I have to give all credit to Luke (122power) for rescuing its faded hulk from that Colorado high desert field, dragging it back to its rightful home of California, sprucing it up and then eventually selling it to me.
It does have rust bubbling around the windshield, rear quarter windows, and rear hatch. The car lived in Sebastopol, CA for a long time which is a foggy coastal forest type environment. I haven't pulled the carpet yet but there may be some in the floor pans like most 240s. But the fenders, rockers, doors, and so on are really nice.
Originally Posted by The Full Banana View Post
This is going to look so so good. I love those wheels and that paint.
It already looks good, it just doesn't go anywhere
And the wheels fall over if a stiff breeze comes through the garage.
Yeah the wheels and tires look great in that mockup!
One thing I have found to be super satisfying is getting the body mechanical components to work just right. The doors on mine took me many hours of fettling before they would shut juuuust right without rattling or needing to be slammed. The trunk lid recently got a new seal and now the panel wonít align, which is driving me nuts.
For sure. Ultimate satisfaction when you can get a door or lid to line up perfectly and close with a solid click almost on its own. My '66 Beetle's doors are like that paradoxically, even though the rest of the car is beat to crap.
My rubbers aren't wide enough for your big meats :/
Any intent to paint the area around the volvo logos on the mudflaps white?
Hell yeah, those buttcheek flaps will be getting white racing stripes. Any suggestion on what type of paint to use? I was thinking maybe one of those tire markers that "those damn kids" use to make their tire lettering white on stanced Miatas and such. Or maybe something better like vinyl and trim paint in an aerosol can.
Old 02-27-2021, 09:52 AM   #228
aidanahunter
aidanahunter's Avatar
My hood has never lined up properly and I just might try fixing it now!
Aidan
4.6 32V 240 Wagon
aidanahunter is offline   Reply With Quote
Old 02-27-2021, 01:41 PM   #229
redblockpowered
cone dodging dilettante
redblockpowered's Avatar
Hinges could be a little tweaked from lack of lubrication as well.
I like the idea of the BMW struts on the Volvo control arm even better, maybe. Seems like a lot of the benefits for a lot less work. For you I guess it would depend on how appropriate the Volvo crossmember is for the V8 stuff.
Although that E46 lower control arm is extra fancy and you get a nice ball joint on the inner pivot. Wonder how that would compare to, say, a stiff inner 240 control arm bushing (like a Delrin or similar)
I sell chips for LH 2.4!
Old 02-27-2021, 03:23 PM   #230
Duder
Duder's Avatar
Give it a shot! It wasn't hard, once I got the bolts broken loose. Even California 240s have rust in the hinge areas, especially the older non-galvanized bodies.
I only adjusted at the bolt shown by the yellow arrow. You can see how far down I moved it. After breaking the bolt loose I snugged it back up until it would stay put on its own, but still loose enough that I could push down on the hood corner by hand and move it. Took a few tries but it worked.
I thought about using just the BMW strut / spindle on 240 lower arms and crossmember, for sure. The 240 crossmember is pretty close for my V8 swap purposes but I'd need to modify the pan either way.
The balljoint vs. bushing thing is a nice benefit, but I guess if I had to sum up the reason for swapping everything over to BMW is that I can be sure all the geometry will work out... meaning bump steer, roll center, camber curve, scrub radius, and so on. The E36 steering rack, lower arms, and spindles will all be located correctly vs. each other with the way I'm planning to do it.
Static caster and camber settings may have to be a bit different in the 240 body vs. OE BMW values but that's OK with me because there should be plenty of adjustment. Track width is super close so I think I can fudge that. 240 wheelbase is 2.0" shorter than E36 so I may have to tweak the steering arms on the spindles ever so slightly to get Ackermann right on. Stuff like that is fun, I don't mind doing minor adjustments as long as the basic components are all located where they should be.
Old 04-02-2021, 12:32 AM   #231
Duder
Duder's Avatar
Since this project is mainly a packaging puzzle, I thought it would be advantageous to knock out one of the smaller pieces now, allowing a few other larger ones to fall into place. Ford 4.6 engines have this big honkus of an oil filter mount which is in a separate casting bolted to the block that integrates the coolant return port from the lower radiator hose. The oil pressure sender screws in here, and it's also a convenient place to tap into pressurized oil for turbo oil supply.
This area is awkward and the big oil/coolant chonkus is right in the way of where I want to put my power steering pump. I can't have a PS pump in the stock location up higher on the driver's side, because that will block the route my exhaust manifold wants to take - straight forward from the exhaust ports and a little bit up and to the left to the turbine inlet. And I don't want to use a Ford PS pump, because they are loud and annoying. And I want to use an E36 M3 steering rack anyway, so it only makes sense to make a custom bracket to mount a matching E36 M3 PS pump as well. If I'm already making a custom bracket then it's not hard to move the pump location downward...as long as that other annoying stuff gets moved out of the way.
Better view of the chonkus with the filter removed:
Back when I was working on the Mustang twin turbo kit mentioned in the first post, we came up with a gizmo we called "the UFO" which was a bespoke machined adapter that allows for tapping into the oil supply for the turbos, retaining the stock oil pressure sender, sandwiching in between the oil/coolant housing and the sender. I don't remember exactly but I think I designed this part. It has 1/4" NPT male threads which go into the engine, and 1/4" NPT female threads to accept the sender, which just moves outward a bit. The inbetween bit is the clever part - which wasn't my idea - but at least I was charged with executing it. The UFO has 6 radially drilled holes around the outer diameter that branch out from the center passage, all tapped with 1/8" NPT fittings. They all came with plugs installed. The idea was for the kit installer to remove the oil pressure sender, screw in the UFO until it was tight, install the sender again, then remove whichever two NPT plugs were facing mostly outwards. Those become the turbo oil feed ports and the others remain blocked and unused. Because there was no way to guarantee clocking of this adapter fitting since it has to just be threaded in until tight to seal at the pipe threads, we had to allow for any random orientation of the turbo oil feed ports. Hence the redundant port pattern and the UFO name. This was just one dinky part of the kit, which wasn't sexy, didn't improve performance at all, but we had to design it from scratch for the application and work out all of the little details. Multiply this by dozens of parts and make everything integrate seamlessly in an OEM+++like way. Fun stuff.
Anyway...major sidetrack! Let's get back on topic.
I like Improved Racing a lot - they make a ton of useful little parts mainly for domestic V8s, with a focus on function and quality. Most of their parts are black anodized, not flashy, but very well thought out and manufactured. They make this oil filter relocation adapter for the 4.6 and 5.4 engines that should make enough space for my PS pump mounting with ports for a remote filter housing / thermostat, and also 3 more oil outlet ports. I'll use the filtered outlet ports for turbo oil supply and the non-filtered one for the pressure sender. A more elegant and comprehensive but definitely more expensive solution vs. the UFO that we just looked at. So this little guy should accomplish everything that the stock chonkus + UFO offered, in a much tidier package, with any luck leaving enough space for an E36 M3 pump down low on the driver's side. It will be tight but maybe possible. Either way it's a nice improvement.
https://www.improvedracing.com/remot...odular-v8.html
Stock vs. Improved Racing EFR-100:
This EFR is a nice little effer. Oil and coolant adapter fittings can be swapped out for different sizes if desired. And there are well made molded o-ring seals in grooves on the back side that I forgot to take a photo of, replacing the bulky stock gasket.
Bare block looks like this on the driver's side:
Improved Racing EFR-100 installed:
So much more room for activities.
Next I need to get my hands on an E36 M3 PS pump and start mocking up a bracket and maybe custom pulley if I need to fudge the ratio. Good news is the pump looks pretty small and compact. It's a ZF and uses a remote reservoir and has a little hard line cooler in the stock application. Should be easy enough to fit everything I think. Belt wrap and routing shouldn't be a problem at all with the serpentine setup on this 4.6 - I think I'll be able to get more belt wrap than it had on the BMW engine.
The 4-bolt bracket comes off, so I'll make my own to fit the "E36 M3 pump on a 2005 Mustang GT engine in Volvo 240" application which should be a huge seller.
Old 04-02-2021, 01:40 AM   #232
James M
Bored member
James M's Avatar
I'm sure the guy at napa will like hearing that when asking year make and model
Old 04-02-2021, 02:47 AM   #233
Jack
junkman
Jack's Avatar
Itís been on my list to fit e46 front coil overs to my 242 (they just need an upper plate) ... but swapping the whole subframe ... very nice
Very nice build
I love you even more Jack.
Donít bother, I would literally rather throw them away than give you the pleasure. I will never sell to you.
Old 04-02-2021, 03:24 PM   #234
Duder
Duder's Avatar
They won't want to touch it! I have a big binder going with all my notes for the project, and plan to put a master parts list in there to help with maintenance and replacement of bits in the future. When I'm 85 and senile and driving this thing by braille I won't be able to remember which belt to buy, or the right spec of brake pad or whatever. Good times.
Very nice build
We'll see how it works out, thanks though! It's a fun process regardless. Originally I was just going to fit the E36 struts/uprights and spindles but it snowballed from there.
Old 04-04-2021, 04:53 AM   #235
aidanahunter
Great call on not using a ferd pump - especially if you take the hydroboost route. Can't remember if you made a decision on brakes yet or not. I replaced my pump because I thought it was getting loud, and the new one was only slightly quieter. I hear a faint power steering whine in my cabin constantly and I believe it's amplified by the hydroboost being against the firewall. Drive me nuts that I have to listen to that over an otherwise beautiful sounding engine.
Also, I got my hood adjusted and it's looking much better now! Turns out one of my hinges was bad. The car came with two different colored hood hinges - one silver-painted, presumably original to the car, and one gold-painted, definitely from another car. The box of parts the car came with had another gold hinge in it, same orientation as the silver one. I guess the previous owner never got around to installing that extra hinge for some reason. Swapping the gold with the silver allowed the hood to adjust properly. Love a good cheap easy fix!
Old 04-05-2021, 06:48 PM   #236
Duder
Duder's Avatar
The main downside of the ZF pump from the E36 M3 is that they don't seem to be available new anymore. There are a few reman options though. I'll have to get my hands on one to ensure I can make it fit on the engine, but if so then I think it's a no-brainer.
There has to be a way to use a vacuum booster in this project, but I have to nail down a few other things first. There's that remote mount booster I posted a long time ago in this thread that might work for the front circuit, and then size the rear for unboosted operation. I'm going to do my best to avoid hydroboost simply to reduce complexity if at all possible.
That's rad - I am all about the cheap & easy fixes! If you do enough of them they add up to more than their sum and can really lift up the feeling and condition of the whole car.
