#301 |
![]() ![]() My buddy Namgyal and his friend Thomas wanted to take some pics of the Volvo today. Once they develop them I'll post them here. Got a cool polaroid out of it. ![]() Had to remove the intake to install a Lowdoller oil pressure sensor and adapter since the factory one **** the bed ![]() Got everything assembled, needed to buy new injector o-rings. Aaaand I didn't torque the oil pressure adapter enough, so its leaking a bunch of oil. Great. Headed back out Monday to remove everything and torque it down. |
#302 |
![]() ![]() ![]() At least it looks good... I'm exhausted trying to get this thing to idle. I feel like I've tried everything at this point. When you start the car, it starts to idle around 700-800 then runs up to 2500. -Car will die if I cover the TB with a glove/cardboard. Also sprayed all around engine with starting fluid and no noticeable RPM spikes. So vacuum leaks = ruled out? -Swapped in a new IAC today. It idled perfectly for 10min. Went and got gas and killed it, when I started it back up it runs up to ~2500rpm and won't come down -Checked pin-out for the IAC and its good Any v8 have any suggestions? |
#303 |
Salaminizer
![]() Any engine codes?
It does look great!
Feedback thread https://forums.tbforums.com/showthread.php?t=144924 1978 242, 5.3 L33 1979 242, MS, R brakes 2006 V50 T5 AWD @ 17 PSI |
#304 |
![]() What engine management?
STSmachining |
#305 |
#306 |
Aero challenged
![]() I want a ride.
![]() @PDXvolvo on IG |
#307 |
![]() It sounds like your idle PID terms may be off.
Hot idle IAC setting should be around 10% from what I know. The Holley Terminator X FB group is a pretty good resource as well. |
#308 |
![]() You'll get one soon! Once I get this issue figured out, I'll shoot you a text
Term X group hasn't provided much help at this point, I've dug through old posts for hours trying to find someone with a similar situation. I think I'm going to run the startup wizard again and start with a fresh tune |
#309 |
![]() A fresh start can be good for sure. I ran the HP in my last LS 427 track car and had good results with a higher target idle of ~850, hot idle IAC at ~10%, and PD terms set at the recommended factory setting. The big cam also liked it a little rich around idle.
#310 |
![]() Started a fresh tune on the Terminator and have mostly solved my idle issues. The IAC still wants to hang, so I made some tweaks to the IAC Hold parameters and am gonna try it out today. ![]() I ended up ordering GAZ Golds for the front earlier this week. Once I install them, I'll be taking it to get aligned at Trackside in Portland. |
#311 |
Aero challenged
![]() What a sleeper...
#312 |
#313 |
Aero challenged
![]() I may have to LS.
I blame you... |
#314 |
#315 |
![]() The black car will be going up for sale soon. Let me know if you're interested.
#316 |
![]() I'm a snob, I think I need to stick with a 242... I'm picking up an 86+ front end for my other beige shell this weekend, and grabbed a flathood last weekend. Starting to consider getting it painted and cleaned up, then dropping the LS into it later on
#317 | |
![]() Quote:
#318 |
![]() Join Date: May 2007
![]() As a dad I prefer the 2-door. Fite me.
#319 |
#320 |
#321 | |
![]() Quote:
84 242 TIC |
#322 |
![]() Headed home this weekend to see the family (now that everyone is vaccinated) and did a little work on Derek (Vol242vos) old beige shell. I picked up this 86+ front end from a buddy and found a flathood on a FB group. I'm considering getting this shell painted and putting the V8 into it, but no decisions yet
![]() Also, my grandpa and I worked out a deal for me to buy his 2008 Tundra. I helped him buy this truck brand new and have always loved it. He's getting older and just doesn't really need a big truck anymore. I'm excited to have a reliable tow rig, maybe I can start jumping on those deals that are a little farther away now... ![]() No progress on the V8 car, gonna head out this weekend and get a few small things done. I put in a universal carpet kit and its been bugging me this entire time, so I think I'm going to swap in the factory brown carpet after cleaning it up. |
#323 | |
![]() Quote:
Click below: Buyer/Seller Feedback My Volvo parts for sale on eBay Volvo parts for sale on forum - Post are regularly updated |
#324 |
![]() No, I didn't end up taking many pictures during install. The carpet was a pain in the ass to work with, I wasn't patient enough and the actual carpet seems to be shorter on one side than the other (door sill trim doesn't fully cover the carpet). I should have waited for a factory black carpet to pop up in the junkyard
#325 |
![]() ![]() ![]() ![]() A few quick 35mm shots from my buddies. At this point, I'm just waiting to get my front coilovers and I think the car is "finished" for now! |
