Old 10-17-2020, 09:39 PM   #51
fatcatbestcat
Professional Hack
fatcatbestcat's Avatar
okay -- don't.
ez
Doing the wrong thing the right way.
Speed parts for sale: http://forums.turbobricks.com/showthread.php?t=359797
Originally Posted by redblockpowered View Post
Will you do $14.99 shipped?
Originally Posted by IansPlatinum View Post
please no more prying things with screwdrivers and bashing things with hammers!
fatcatbestcat is online now   Reply With Quote
Old 10-19-2020, 03:14 AM   #52
Scaramanga
Hey, why didnīt you paint the head before installing it? Just thinking....
Volvo 145 1972, 245 GLT 1991
Scaramanga is offline   Reply With Quote
Old 10-19-2020, 10:49 AM   #53
fatcatbestcat
Professional Hack
I think a freshly painted head on a crusty block would look even worse. It's not even completely installed yet, I just got the head bolts on finger-tight just to line up the exhaust. If the engine's coming out completely, I'll probably separate the two, clean and paint them.
Old 11-26-2020, 01:39 PM   #54
fatcatbestcat
Professional Hack
It's been a while since I've touched the car, but I finally got my hoist and the leveler.
I'm a little busy today, but I have this coming Sunday, Monday and Tuesday off. My plan (assuming it doesn't start snowing again) is to get the hoist and my engine stand all assembled Sunday, then I need to clear some space in the garage, lift the left side of the car and put it on jack stands, pull the FL wheel, then I can try to slide under the car and disconnect the clutch linkage.
Then, I'll have to unbolt the bellhousing from the transmission, and jack the M41 up to prevent premature fall-based impact trauma.
Then, I should be able to remove the exhaust, and bolt up the leveler somewhere on the head (I was thinking to either the manifold studs or two head bolts on the front and back of the engine.
That's all for now, hopefully I can update this soon with some real progress!
Old 02-15-2021, 01:46 PM   #55
fatcatbestcat
Professional Hack
Yeah, you can tell how that worked out.
I need to write something on this thread to make me feel better about my lack of progress recently, or historically. I've had this damn car since October 2019, and I have yet to mount a single new part on it. In theory, I could just crush this car and only be out $200, but honestly that would be a waste of a first-year 144S. I've been flirting with the idea of getting a cleaner shell to put the parts on, but a lack of second garage or driveway space kills that plan every time.
I'm going to have to work with what I have.
Anyways, here's some pictures I took right after my last post in November 2020.
I did, at least, manage to find space to put the engine crane. It's in my side yard, under a tarp. Building one of these on my own was not fun, but given three hours, I got it done. Let's ignore the fact that a bunch of bolts were mismatched, and I had to physically bend some of the parts to get them to fit.
Naturally, any further progress was halted by, well, Canada.
Yep. Until it warms back up to acceptable working conditions in 3-6 weeks, I'm not really able to do what I want. That being said, I think I have most, if not all, of the parts I need to remove, rebuild and reinstall the motor. I think that's really the point of no return on this project. If the B20 is borked in some irreparable way (destroyed bearings, etc), I'm either into a V-engine swap or just giving up on this car entirely. God, I'm a terrible pessimist.
I've already acquired some .030 over pistons for the rebuild, since I don't trust the rings currently in the motor, and I had a really hard time finding std. bore rings. Also, boring it over would help alleviate the cylinder wall taper that I know will come back to haunt me in the future.
Plus, it gives me to opportunity to clean and paint my rusty, crusty and grimy engine. Will look nice in my disgusting engine bay.
Getting under the car to disconnect the clutch won't be fun though...
Sketchy Wiring
I have absolutely zero confidence in any of the electrics in this car. Most of the chassis harness is gone, and it seems like what is here is just dash wiring, and stuff for running the engine. I managed to score a full loom from a '69 145, but none of the wires are labeled in any way. Sometime I'll have to go outside and stretch them out, then guess what they are and label them. The previous owner included a Hayne's manual, and I would suspect that he had trouble with the electrics, since the whole 'wiring' section of the manual is either torn out, or replaced with countless photocopies of other diagrams.
There's this sketchy aftermarket junction box under the hood. It's not bolted to anything, and just freely dangling on a bunch of wires. I have no idea what they do, or if this was ever hard mounted.
Also, the alternator (which I have since deleted, because it was stuck), seemed to have been connected in some way to a 3-pronged outlet of some kind? This isn't part of the rest of the chassis harness, and I don't understand what its purpose was.
Well, I guess that's all I can talk about for now. I'm hoping to start the engine rebuild process as soon as the snow melts.
Stay tuned for more not-progress.
Old 02-18-2021, 11:57 AM   #56
142 guy
The 'sketchy aftermarket junction box' that you are referring to, is that that row of three relays mounted on a bracket? If so, that is not aftermarket. It is OEM and (on a 1971 model) the three relays are the reverse light relay, the rear window defogger relay and the headlight high/low flasher relay (rectangular). The bracket mounts to the top of the driver side inner fender wall.
I have some photos of the reassembly of my 1971 which show the routing of some of the wiring if you need some references. If needed ,I can also advise on where the various harness components should go. My 1971 Is an E so it has more wiring for the EFI than your car; but, the non injection portion of the wiring should be very similar.
Old 02-18-2021, 12:16 PM   #57
joel142
There's also a battery distribution block just below and forward of that - honestly, it does look a little tractor.
'71 142E, M41, Corbeau GT seats, iPd bars and springs, Nardi wheel, GT gauges, overmatched KYB Gas-A-Justs, Canisto wheels, 7" and Series 175 Cibies
'95 T5-R, yellow, M56H swap
joel142 is offline   Reply With Quote
Old 02-18-2021, 01:17 PM   #58
fatcatbestcat
Professional Hack
Damn, if only I had bolts to mount it. I think I can see where it's supposed to go, but perhaps cleaning 30-ish years of road grime off of that box is a good idea.
This does confirm my hypothesis that someone parted out a '72 140E of some description and just threw all the parts on this particular car.
Old 02-18-2021, 09:16 PM   #59
142 guy
The bracket with the relays would have been common on all 140s up until at least 1972. No bolts associated with mounting the bracket, just a couple of phillips head sheet metal screws (probably #8 or #10) to hold it in place against the inner fender. You can see them mounted in this Skandix photo.
https://www.skandix.de/en/installati...28010/2000042/
Old 03-20-2021, 06:18 PM   #60
fatcatbestcat
Professional Hack
Default Time for some more 'not progress'.
Finally, a nice warm day that I have off work, and plenty of time on my hands!
I figured it was time to take the top end of the motor apart, partially to check on everything's condition after sitting over the winter, but mostly to pull the R cam out, which I was selling.
This is pretty much where I left off. I assembled the top-end so I could test fit my intake an exhaust.
Not touching a car for pretty much a whole season always leaves you with surprises. Apparently, I had left a bottle of assembly lube open, and I'm guessing the squirrels had tipped it over. Fun.
Taking the intake off actually took a considerable amount of time. It was probably from having bashed it with a hammer a few times... just a guess.
Seriously, it's like I fused them together.
Fortunately, taking the rocker shaft off didn't reveal anything concerning. I was a bit worried that maybe my Iske pushrods would've started to rust or something catastrophic like that.
I bought some brand new head bolts, so I don't need to reuse these nasty ones.
Taking the head off revealed the first possible signs of badness.
Not sure what the goop is, but I suppose I'm replacing the head gasket.
Fortunately, all the ports and the combustion chambers seem fine.
Is there an approved method for removing lifters? I accomplished it by turning the cam and just picking them out with a pair of pliers. They're also reusable.
Now for what I set out to do in the first place. Notice the girdle of shame on the crank gear. Bad memories.
Also, I seem to have found that piece of tubing I lost in the motor at some point.
Alright, that's the R cam gone.
I'm probably going back to a D or K cam. Keeping this motor pretty basic this time. I just need it to run.
Old 03-23-2021, 04:08 AM   #61
Scaramanga
If you get a new cam you should get new lifters as well.
If you reuse your old cam, you should match lifters and pushrods with the cam lobes. You donīt just put them in a bag and put them back randomly.
Good luck!
Old 03-23-2021, 01:06 PM   #62
fatcatbestcat
Professional Hack
Good luck!
I'd never tightened any of the adjusters on the rocker shaft, just kinda left the lifters dangling in the hole. Engine had never run, d'uh. I don't see any reason why I couldn't just reuse them.
If it is a problem, I accidentally bought Iske's V8 lifter pack, so I have another eight I can use.
EDIT: The old K cam is absolutely wasted. Lack of Zinc. I'm getting a new one from a friend.
Old 03-24-2021, 04:03 AM   #63
Scaramanga
Oh, so the lifters and rods are brand new? In that case just mix and match randomly
I guess you can mix used rods and lifters but not used lifters and cam.
Anyhow, great to see some progress here! Keep it up!
Old 03-24-2021, 09:24 PM   #64
fatcatbestcat
Professional Hack
Default Is this progress?
Thanks for the encouragement. I definitely need it.
It being consistently above 15°C outside means I can work on the car more frequently, and it also means more frequent 'updates' for... whoever's reading this I guess.
Today I endeavored to pull the engine. Got up nice and early, and had some semblance of a plan.
I figured that assembling my engine stand was probably a good start.
Also, removed my hoist from hibernation. It had developed a little bit of rusty from just sitting for six months, but nothing that hinders its function.
Once again, probably the biggest challenge of working the car is my tiny garage. Doesn't help that it's constantly full of junk. It took me a fair amount of time just to clear out the front so I could get the hoist in. The plus is that I can put it back better organized than before.
Engine leveler, as suggested.
I wasn't totally sure where to mount the chains, so I just installed the spare head bolts all the way.
Sketchy? Yes. Functional? Probably.
Unfortunately, I couldn't really get any pictures of me working under the car (just due to the cramped environment). This is the part where I cut to someone else's hackery on this old car.
For some reason, the nuts/bolts are different from one engine mount to the other. One used a normal 5/8" nut, while the other had two 17mm nuts stacked on top of each other.
I took all the bolts out of the bellhousing, which took an unusually long time. They were pretty well stuck, but I managed to get my torque wrench to free the ones at the bottom.
The ones at the very top, however were a special challenge. I must've smashed my hand numb trying to fit a wrench in the small space between the firewall and the back of the engine block.
My problem now is that I still can't separate the engine from the bellhousing.
That said, going through all these pictures from today reveals that I left a starter bolt in.
Whoops.
Old 03-25-2021, 11:40 AM   #65
spock345
spock345's Avatar
They can also just be stubborn after being bolted together for so long. Sometimes when pulling a motor I've had to tap the seam between the block and bell housing with a mallet and then gently wiggle it a bit to get them to separate.
Edit: Gentle prying may also work, but I don't like putting force on the input shaft.
1967 122s, B20F, M40
