Old 04-08-2021, 12:35 AM   #151
Jack
junkman
Jack's Avatar
Originally Posted by James M View Post
it needs a wash/wax
stop making excuses
there's enough change on that center console to buy yourself few min at the coin carwash
I love you even more Jack.
Old 04-08-2021, 01:01 AM   #152
James M
Bored member
James M's Avatar
I've only got $1.95 there, takes $2.50 to get any time around here. Higher standards then Oroville. I guess I could have your alleyway neighbors clean the windshield for half that
Old 04-08-2021, 01:06 AM   #153
Jack
junkman
Jack's Avatar
Comes with free rock through it
Old 04-08-2021, 01:11 AM   #154
James M
Bored member
James M's Avatar
As long as it's threw the windshield, keep locking my keys in the car, would be much easier without it.
Old 04-09-2021, 03:17 PM   #155
940 16 valve
940 16 valve's Avatar
Did you end up getting Motronic to control boost through the valve?
1991 940 - stock b234+t -retired http://forums.turbobricks.com/showthread.php?t=243308
1989 760 - T5 +T5 swapped http://forums.turbobricks.com/showthread.php?t=341191
940 16 valve is offline   Reply With Quote
Old 04-09-2021, 04:37 PM   #156
James M
Bored member
James M's Avatar
I have not tried since the exhaust but thanks for the reminder. Seems the back pressure was stopping anything over 8psi before, I've got a MBC now but would prefer to use the soleniod, gotta recheck the wiring diagrams and put it back on
Old 04-11-2021, 12:20 AM   #157
James M
Bored member
James M's Avatar
After some annoying driveshaft vibration I decided to install the BNE torque rods I've had around for months, much easier to adjust and very nice feel in hand.
PXL-20210410-231259615
Along with the torque rods I installed a poly transmission mount, the stock mustang one had quite a bit of bounce to it.
PXL-20210411-005810764
PXL-20210411-003734361
Setting pinion angle I've found myself in a predicament, the 3.5" SN95 driveshaft won't go back onto the diff flange after correcting the angle at this ride height (or anything the springs will reach). It runs right into the area it's been rubbing on in the tunnel. I dropped off my coleman 2.5" shaft for balancing this morning before starting the work so hopefully it's done soon and fits.
Just to ask in case anyone knows, the engine/transmission sits at about -3.5° (down in the back), setting the diff anywhere close (-3.5°, flange up) it won't get close to fitting. I could drop the rear of the transmission some more but how much engine angle is too much?
On a side note I double checked the info i've read about BMW 24v exhaust ports being the same general size and placement, looks good enough to find a manifold that will clear the side of the head
PXL-20210410-012135389
PXL-20210410-012252153
Old Yesterday, 08:54 PM   #158
rms
rms's Avatar
As far as driveline angle, I have my transmission (T5) 3.0 degrees down and my diff only 1.0 degree flange up. Mustang driveshaft, no vibration.
-Ryan
rms is offline   Reply With Quote
Old Yesterday, 09:14 PM   #159
James M
Bored member
James M's Avatar
What rear trailing arm bushings/bearing are you running? None under load or decel?
Old Yesterday, 09:50 PM   #160
rms
rms's Avatar
Zero vibration. Tremec has an iphone app that has you set your phone on each angle and it tells you go or no go. Mine was a go. I have super pro poly bushings in the trailing arms and the BNE torque rods.
