Old 01-10-2021, 11:33 PM   #126
James M
Bored member
James M's Avatar
Make sure the water pump is high enough for the upper Oring to seal, kinda tough with the head off
That motor is looking nice, makes me want to pressure wash my block
Old 01-11-2021, 12:06 AM   #127
turbojose
thanks for the heads up... I will double check that once i set the head on.
turbojose is offline   Reply With Quote
Old 02-24-2021, 12:49 AM   #128
turbojose
It's been a while since my last update... I dropped off the head at a well known machine shop for a cleanup... as it turned out more than a few of the valves were leaking, and there were some questionable water jacket rot. after getting all of the valves redone and seated, and having the water jackets welded up, and head surfaced, it is back and ready for installation. I'll be spending the weekend putting the head on the new 2.5L.
Untitled
Untitled
Untitled
Looking for the torque sequence for both the head and the cam carrier if anyone can help me out.
Old 02-24-2021, 04:29 AM   #129
Racecar with AC is where it's at.
Specs below. I can't remember where I have the cam carrier specs. Let me dig through my greenbook pdf stash...
https://yoshifab.com/store/webdocs/torquespecqrr.htm
Old 02-24-2021, 10:09 PM   #130
turbojose
Thanks Harald.... she even has cruise control and power steering too...
Old 02-24-2021, 10:21 PM   #131
Hahaha you got me beat on cruise control!!
Old 02-24-2021, 11:23 PM   #132
turbojose
Nathan made me a special bracket for the GM transmission TV cable, and the cruise control.
old photo.
IMG_0050
Old 02-24-2021, 11:30 PM   #133
turbojose
Old 02-25-2021, 10:56 AM   #134
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Uh.. What a Beaty
Old 03-28-2021, 10:46 PM   #135
turbojose
Been off for a while, but got lots of work done on the motor today. installed the complete hotside, and put the cams in and modified an original timing belt cover for a timing mark. its getting there.... still need to do much of the wiring for the new MS-Pro.... but feels good working on the volvo again.
Untitled
Untitled
Untitled
Untitled
Old 03-28-2021, 10:50 PM   #136
turbojose
looking for some advice on MS-pro inputs.... here is the list I have that I want to use. I'm gonna start wiring this week. just wondering if I should just start grabbing inputs in no specific order, or if there should be some order to the madness.
here is a list of the items I have on the plans.
1. Knock sensor
2. Methanol injection.
3. CAS sensor
4. Temp
5. IAT
6. Idle up for AC
7. Electric aux fan control
8. Converter lockup (maybe) I’m still running a 700R4
9. Single stage of nitrous
10. Boost control (speed and throttle position dependent)
considering
11. Fuel pressure
12. Oil Pressure
Any input would be greatly appreciated.
