Old 03-14-2021, 10:22 PM   #126
atomicdeathmonkey
atomicdeathmonkey's Avatar
Originally Posted by bobxyz View Post
Nice progress! Check the wiring diagram, but some (or maybe all) years of K-Jet have a wire from the coil "-" tab to the fuel pump relay (and to tach, if any). The fuel pump relay only turns on once cranking, and spark, is detected. It's a safety thing - don't pump fuel when the engine isn't running.
Will do man, I did change the coil so may have put something where it didn't belong! Thanks!
Time to wash out the cooling system. Nothing terrible, all clear water and a little sediment, no rust !
More than a bit of a process.
I have all new hoses and I'm cleaning up the t junctions.
Tested out the new thermostat
My overflow tank has a good bit of pitting on one side, may need to replace it?
Looks like someone used sealant where it meets the bracket too.
There was no thermostat in it !
Threw the cleaned up idle air control valve back in, fiddly thing to get the bolts in!
The front splitter clip had disintegrated see o quick but if cable tie action !
More on the rebuild of the coolant system later,all the hoses red rotten! Hope my heater core is okay !
Volvo 242 turbo intercooler 1984, w124 300d, toyota big fridge, small toyota washing machine.
atomicdeathmonkey is offline   Reply With Quote
Old 03-15-2021, 12:51 AM   #127
atomicdeathmonkey
Boring stuff here for the most part, had to improvise some brazing with the solder I had on hand for one of the pipe t's. Used a bit too much sealant but got some pretty even squeeze out ;)
Little jobs tonight so they'll be all cured for tomorrow!
Old 03-18-2021, 01:46 PM   #128
245tic
I had to just purchase new tees. Mine were rotted thorough. Nice work!
245tic is offline   Reply With Quote
Old 03-18-2021, 11:03 PM   #129
atomicdeathmonkey
Originally Posted by 245tic View Post
I had to just purchase new tees. Mine were rotted through. Nice work!
Yeah, I might be buying new ones too - that or pipes that are a bit smaller. Did a water test and it took a leak immediately!
20210317_170956 by V G, Flickr에서
Some new shiny hoses
20210317_134353 by V G, Flickr에서
20210316_204459 by V G, Flickr에서
20210317_134343 by V G, Flickr에서
20210317_134356 by V G, Flickr에서
Next was to figure out some injector issues - just bought new ones!
20210318_151259 by V G, Flickr에서
20210317_184458 by V G, Flickr에서
20210318_151701 by V G, Flickr에서
Took off the injector lines - was afraid of them twisting or breaking - try finding a replacement!
20210318_155252 by V G, Flickr에서
New crush washers from m1 autohaus
20210318_152139 by V G, Flickr에서
20210318_182131 by V G, Flickr에서
Got my spacers too!
Had to give the firstborn a wash - going on a month without any water on it!
20210318_175129 by V G, Flickr에서
Old 03-19-2021, 05:37 PM   #130
swedishiron.com
I sell Volvo parts!
I have new Volvo water Tees if you are interested.
I may also have a spare fuel injector line or two.
Here's my feedback thread:
http://forums.turbobricks.com/showthread.php?t=25568
I ship small packages/purchases on Fridays, and larger ticket items via FedEx in the middle of the week.
swedishiron.com is offline   Reply With Quote
Old 03-20-2021, 12:43 PM   #131
atomicdeathmonkey
Thanks, man - I just ordered them on VP parts yesterday! the injector line survived but i'll keep you in mind next time !
YouCut_20210320_111508995 by V G, Flickr에서
So she'll run if I manually actuate the kjet fuel distributor, the engine runs and that's good enough for now, I've to work my way through the troubleshooting guides and see why she needs so much help!
I'm waiting on one of the connector pipes for the cooling system - though I got away with the repair on mine but it's leaking from the seam and a few more pinholes!
Screenshot_20210319-211632_DuckDuckGo by V G, Flickr에서
Old 03-21-2021, 01:34 AM   #132
atomicdeathmonkey
To avoid getting static in terms of progress I decided to get the cross threaded wheel stud out of the way! $16 sae set from harbor freight and a bit of luck and got the threads cleaned up.
20210320_163824 by V G, Flickr에서
20210320_165745 by V G, Flickr에서
20210320_165911 by V G, Flickr에서
20210320_172259 by V G, Flickr에서
20210320_174418 by V G, Flickr에서
20210320_180225 by V G, Flickr에서
20210320_180240 by V G, Flickr에서
20210320_190333 by V G, Flickr에서
New coolant bottle and cap fitted
Lots more plasti-dip to remove from the old wheels.
20210320_190343 by V G, Flickr에서
Nice filling of the arches now with the spacers
20210320_195923_001 by V G, Flickr에서
20210320_192523 by V G, Flickr에서
Old 03-22-2021, 12:10 PM   #133
Murploid1
Murploid1's Avatar
On the advice of a more learned member in terms of these cars I removed and cleaned the idle air control valve too and it was stuck.
Can you tell me the location of that idle air control valve?
Murploid1 is offline   Reply With Quote
Old 03-23-2021, 01:21 AM   #134
atomicdeathmonkey
It's right under the intake manifold, towards the rear of it, undo the two pipes going into the throttle body and undo two ten bolts I think they were, it will also have an electrical connector to remove on it.
Old 03-23-2021, 09:09 AM   #135
atomicdeathmonkey
Got distracted with a smoking deal on some storage and hardware, $50 all in so took the weekend to organise my garage.
20210320_224109 by V G, Flickr에서
20210320_224935 by V G, Flickr에서
20210322_151308 by V G, Flickr에서
I really should put some paint on the walls at some stage.
Old 03-23-2021, 11:20 AM   #136
Murploid1
Murploid1's Avatar
Hmmm interesting. Not sure my car has one. Its a 1982 Kjet turbo car. I don't remember seeing that and i have had the intake manifold off.
Old 03-23-2021, 01:46 PM   #137
kampman
dunning-krugersquirt
Every US market Volvo got electronic idle speed control starting in 1981 so your car should have it. No guarantee that someone hasn’t played Volvo lego in the intervening 40 years though.
1984 245T
2006 V50 T5M
Feedback Thread
kampman is offline   Reply With Quote
Old 03-28-2021, 03:39 PM   #138
atomicdeathmonkey
20210325_163815 by V G, Flickr에서
Got the right part thanks to a member on here giving me the links! very much appreciated!
20210325_164232 by V G, Flickr에서
New clamps on everything!
20210325_173529 by V G, Flickr에서
made sure to use the right coolant :D
Confirmed it was the right color when it came pissing out the back of the head somewhere.
This car really doesn't want to be on the road!
20210327_144438 by V G, Flickr에서
Old Yesterday, 10:37 PM   #139
atomicdeathmonkey
Time for new battery cables, slow starter and serious heating up !
These are the sizes in first pic if you ever go near an old 240.
Got distracted by a pretty heavy oil leak in the truck! Thankfully sorted quite quickly, I love my Toyotas ;)
Tried to check the timing, can't see any of the flywheel marks, have the belts on order so I can reach when I take off the timing belt cover to check.
No power at the #30 pin of the fuel pump relay with key off so have to chase that.
No bounce in the tach so I've ordered the pickup/ hall sensor, I have a spare distributor here with a new sensor/ pickup lead but I can't get the current distributor out!
Hopefully I can put this new sensor in with distributor in place?
Quick vid of her turning over now, much better than it was, after the cables and cleaning up grounds
https://flic.kr/p/2kSDKy1
