![]() Here is my attempt at a project thread. Please bear with me.
Back in 2015 a good friend of mine was ready to purchase his first Volvo, and a fellow member (Svenski) informed me of a super clean '88 744 turbo at his Volvo dealership. My friend and I went to look at the car and he knew he wanted it... A 744 Turbo AW71 White w/ hooker's blood red interior. 185k on the clock, but looked brand new inside, out, and under. It was traded in by a former SCCA racer with the name of Patron. It was his wife's car that they ordered through the Tourist & Diplomat Sales Program on one of their trips to Sweden. Within a month I gave him a 13c/90+manifold to replace the leaking Garrett turbo. We turned up the boost to 14psi, and went through a head gasket shortly after. The HG was replaced and it wasn't 2 months before the Kool-Aid man came to visit. Shortly after that, he sold the cleanest 740 I've ever seen. Fast forward 3 years and I see it for sale on CL thanks to [Edit]: 89_740Turbo. Despite the PO's best attempts to remove decals, I was able to identify the car via the outline of SCCA and High mileage decals that the old racer had added before my friend purchased the car. He had it priced at a high $13k but it had a new (to the car) drivetrain. A LS1/T56 out of a '99 firebird, and some twin turbos to boot. I obviously haggled a bit, and got the car for a deal. I got off work early and immediately withdrew my Engagement ring/Mortgage Down Payment, and hopped in my buddy's car to Canton. After a short visit I was on my way home with my own personal time capsule of 530hp (@ a more reasonable price to boot). Much of the PO's quality of workmanship is **** to say the least and the car came with great parts w/ poor execution, but I am slowly making this car my own. I am currently 1.5yrs into my ownership and have made much progress. Pics of said progress to follow. I hope you all enjoy reading this journey as much as I enjoy sharing it with you. ![]() The Pics w/ Moose out the sunroof are circa b230ft power
Daily: '91 245, B230F/M46 P-type, '93 Dana 30 '88 744, Twin Turbo LS1/T56, Grizzly locked Dana 30. Last edited by KwikBrik245; 12-04-2020 at 09:28 PM.. Reason: Horrible composition skills |
![]() The first upgrades to the car:
Kaplhenke rear subframe, adjustable torque rods, adjustable panhard bar. The PO built a "scavenge" setup for the turbos. Completely standalone. No filter, No cooler, No regulator. Just a Tilton electric oil pump. This wouldn't do, so I added a Turbosmart oil pressure regulator, inline filter, and Setrab oil cooler/fan pack. |
![]() I went to the track and my best time was 14.1 @ 107mph. I could tell I had a miss so I went to work. Found that one of my turbos gave out and I had damage to 2 pistons, none to the cylinders amazingly. Next I tore everything apart so that I could rebuild it how I think it should be.
#4 |
![]() The PO deleted the ABS pump, but nothing else. He added the delete plate seen in the pics, but nothing to support or shield it from heat. After a couple good pulls you had ZERO pedal to slow the car down.
![]() I also got to verify the cam that was claimed to have been installed. |
#5 |
![]() The rebuild.
Wiseco Pro series pistons Summit ProLS forged H-Beam rods Clevite coated H series rod and main bearings Meling 10296 Hi volume oil pump ARP main studs Griffin fan shroud to replace the full sheet baking pan shroud Last edited by KwikBrik245; 11-28-2020 at 09:17 PM.. Reason: Forgot to upload pics |
#6 |
Salaminizer
![]() Very cool, nice project! That is gonna be quick!
Feedback thread https://forums.tbforums.com/showthread.php?t=144924 1978 242, 5.3 L33 1979 242, MS, R brakes 2006 V50 T5 AWD @ 17 PSI |
#7 |
![]() The Center console was a very awkward situation. The PO removed the factory head unit and equalizer, and somehow managed to rivet a generic racekor switch panel with push to start. No fitment whatsoever and gaps all around. Since this also would not do, I started making my own panel with a hinge so that I can access the fuse panel. I also removed the hvac box from under the dash to make room for my coil packs and to mount the ECM.
#8 |
![]() I went to run the new pigtail to the reverse switch and realized I don't have room for the connector to clear the trans tunnel. I am not sure if I just want to hammer out the tunnel more just to make it fit, or if I want to get this switch I found online
https://www.sikky.com/product/sikky-...e-lamp-sensor/ |
#9 |
![]() After a little google and calling around, I found the company that will be widening a pair of Hydras for me.
https://weldcraftwheels.com/ I just need to figure out how much width will be added. I currently have 225/50r16 tires so 1-2" additional width with the help of some spacers will give me quite a bit more traction without being too obvious. |
#10 |
Salaminizer
![]() Cool, that will be pretty undercover!
#11 |
![]() Thanks. Hydras aren't my first choice of wheels, but they absolutely look like they belong on the car. I may have to bite the bullet and get something in at least 17" so I can upgrade the brakes as the car gets faster. 225 wide to 255s should fill the wheel well nicely w/o much modification to the body.
#12 |
Keep it clean...
![]() Very cool project and power plant in it.
Bad ass car build > Engagement Ring. No brainer
Derek 1 Owner - 85k mile 1980 242 Recaro LX Bs - 16" ARE 398s - 25/25 Sway Bars - Bilstein HDs - SuperPro Poly/STS Derlin Bushings - MSD - R Sport Wheel -Project Thread- Follow on IG: @vol242vo |
#13 |
![]() question how well does the T56 shifter line up with the stock hole?
1985 740GLE sedan winter beater Cali car. |
#14 | |
![]() Quote:
It lines up ok. Slightly to the left of center. I need to get some sort of offset shifter to bring the shifter back an inch or two. I am not the guilty party who twisted that opening up btw. |
#15 |
![]() GTO shifter might help with that.
#16 |
#17 |
![]() I guess now is as good a time as any to tackle the most horrid part of the car... Headliner
![]() Since I have a sedan and I wont be removing either the front or rear glass, my only other option is through the trunk. I have been procrastinating for quite some time with this task. I even put it off when my buddy first owned the car. lol. I probably won't be sticking with the same color or material but I know I have plenty of prep to do on it before then. Also, here is my list/spreadsheet. It is ever changing, so bear with me. https://docs.google.com/spreadsheets...it?usp=sharing |
#18 |
![]() Did some digging around and found one of the Dyno sheets. Those numbers are with a standard FPR without boost reference and a faulty in tank pump. Also went to Summit Racing today and gabbed a few more goodies to fix fueling issues as well as some other stuff.
Walbro 450 pump Deatschwerks DWR1000 Fuel Pressure Regulator. Edelbrock Performer-Link adjustable timing set. ICT timing cover with twin -10 AN oil drains. Autometer sending units. Also the wiring cleanup seems to never end |
#19 |
Salaminizer
![]() Updated dyno sheet will be exciting, not that that one is weak at all!
I went with this shifter handle to avoid punching my dash. http://cart.hanlonmotorsports.com/hm...d-handle-black |
#20 | |
![]() Quote:
I am excited to see what numbers the car will make. The wall it was hitting was only getting bigger with boost. Obviously the lighter internals and balancing will help too. |
#21 | |
![]() Quote:
DZ |
#22 |
Salaminizer
![]() I didn't mount it yet because it would be in the way of my heater core repair. I hate that job...
#23 |
#24 |
![]() After too much procrastination I will be starting the sending unit upgrade/refresh.
New wiring for the Walbro 450 pump and sender. Picked up a stainless fuel strainer from AI North America. I'm not sure if I will see more fuel aeration vs the OEM style sock strainer, only one way to find out I guess. |
#25 |
![]() Today I tore down my fuel sender as it hasn't worked in quite some time. I tested continuity from the connector down to the float assembly. Everything checked out.
Next I disassembled the float assembly and found a broken wire on one of the resistor rods that the float contacts slide along. The break is right at the bottom where the wire connects to the metal base. I am hoping I can either repair the break or at least find a replacement piece. |
