Old 01-16-2021, 01:17 AM   #1
89-240gl+t
Default My 1965 122s Journey
After a year of looking for the right one I finally found an amazon that fit my needs. My ideal car was one that ran and drove decent, had pretty good paint cause I don't want to keep it original. The interior didn't really matter since there are so many replacement parts.
What I came up with
1965 122s
The paint is in pretty decent paint for it being original, has the usual flaws and rust. Really like it, shows the age/history of it
Its pretty well gone through mechanical wise, the car runs and driver pretty well. Needs new tires and some bushings.
The passenger side has some bondo work that can be seen, the door will be replaced with a different one hopefully. Will have to weigh my options with what I want to do with the rear quarter panel
Newer parts
Front Wheel Bearings
Electric Fuel Pump
Brakes/Rotors/caliper were rebuilt
New radiator
E-Fan
Weber 32/36
Interior
VP Autoparts Front Seat Covers
VP Autoparts Front Door cards
Repainted dash
My Goal
Bring it back to as stock as possible with a good ride. Im wanting to do some progressive sport springs, bilsteins, all the bushings and a ipd sway bar up front
Interior will be redone and everything purchased through VP Autoparts, want some good quality parts.
'84 242 Turbo
Rebuilt 93 B230FT block, KL Racing T3 Cam, Dual Valve Springs, 38/46 Valves, Ported, ARP Head Studs, T5WC, MSII-Extra, EDIS, Nathan Exhaust Manifold, Ebay Turbo , 90lb injectors, Full E85, 3" exhaust, Kaplhenke Coilovers Front/Rear Koni Race Single Adjustable’s, RX7 Brakes, IPD 25/25 sways
1965 122s
89-240gl+t is offline   Reply With Quote
Old 01-16-2021, 01:23 AM   #2
89-240gl+t
The day after I got it home it went in for a wash, it was sitting under a tree and was covered with these red marks. Even with a pressure washer they did come off. Broke out the clay bar and my Torq orbital buffer. What I thought would be a quick job turned into a 5 hour one. But the results were worth it.
Found out that almost every rubber seal on the car needs to be replaced, first order from IPD and Vp Autoparts will be a good one
Old 01-16-2021, 01:59 AM   #3
spock345
spock345's Avatar
Those red tree stains are a pain to deal with. I remember spending hours on that when I got my 240. They are really bad on light single stage paint.
1967 122s, B20F, M40
Old 01-16-2021, 03:47 AM   #4
wtarkington
Car looks clean after the wash. Good looking car.
wtarkington is offline   Reply With Quote
Old 01-16-2021, 12:28 PM   #5
89-240gl+t
Yeah it was pretty bad, but with the buffer and a little bit of time it come off pretty easily!
Old 01-16-2021, 12:31 PM   #6
89-240gl+t
No perfect but definitely 100% better then it was before
Old 01-16-2021, 09:13 PM   #7
89-240gl+t
ended up putting in some hefty orders today
IPD
Two Side Mirrors
Trunk Rubber Seals
Brake Light Rubber Seals
Turn Signal Rubber Seals
Filler Neck Rubber Seals
Hood Cushion Rubber Stoppers
Trunk Handle Rubber Seal
Hood To Fender Rubber Cushions
Hood Release Cable
Pedal Pads
Spark Plugs/Wires
VP Autoparts
Rear Seat Cover
Headliner
Rear side Panel Covers
Rear Shelf Panel
Hood Rubber Seals Front and Rear
Windshield Seal
Rear Window Seal
Door Pop out Window Rubber Seals
Door Seal Rubber Kits with the Windlace
Interior Dome Light
Pretty stoked to get the parts to really get this project running!
Also had to order a new Carburetor throttle linkage since the hack job the previous owner installed is sticking pretty bad.
She got to meet the 242 today
Old 01-16-2021, 10:08 PM   #8
PaddyGarcia
Nice start for what looks like a nice car!
PaddyGarcia is offline   Reply With Quote
Old 01-17-2021, 11:56 AM   #9
spock345
spock345's Avatar
That linkage is kind of horrifying to look at. I thought mine with a janky auxiliary return spring was a hack job.
It is probably sticking because the part that mounts onto the manifold should have a bearing or ball joint for the shaft to rotate around.
Also you are missing a metal battery tie down.
Personally I thought the throttle linkage on the weber was a pain. The pedal travel always seemed a bit long and my foot would end up in a weird position next to the tunnel to hit WOT. Although that may have just been the larger transmission tunnel as my car was once an automatic.
Old 01-17-2021, 12:45 PM   #10
89-240gl+t
Yeah it’s pretty bad, I ended up going with a universal kit that looks like the stock linkage. Driving and the throttle sticking isn’t very ideal.
http://www.piercemanifolds.com/product_p/99006.104.htm
Yeah I have that on order also, it’s currently tied down with a bungy cord
Throttle isn’t too bad, this is the first one I’ve ever driven/owned so I don’t really know a difference.
Do you have any part cars down there?
Old 01-17-2021, 02:27 PM   #11
spock345
spock345's Avatar
Nope. Nothing down here. I know of someone on the east side of town that occasionally sells parts from their car. Recently got rid of a B18 when they went to a B20. Other than that there isn't much in terms of availability. Although the Vintage Volvo Nuts group is pretty useful and seems to be where everyone around here with parts hoards hang out.
I remember my throttle being terrible when I first bought the car. It wouldn't engage the secondary at all. The automatic cars have a larger tunnel and swapping to a manual and putting a clutch pedal in there just makes everything a bit cramped. I sort of had to tilt my foot against the tunnel to get full travel.
Old 01-17-2021, 03:02 PM   #12
89-240gl+t
Yeah I’m on that group, lots of helpful people there.
Even with the manual trans the pedal is super close to the trans tunnel, pretty much have to use the side of my foot as well. Isn’t too bad, just can’t wear bulky shoes while driving it
Old 01-17-2021, 05:45 PM   #13
The Librarian
Redline sells a linkage kit for the downdraft carbs that's specific for Volvo OHV engines. The kit you bought is a universal one for a single DCOE.
Old 01-17-2021, 05:57 PM   #14
89-240gl+t
They look to be pretty close, what’s the main difference. The kit that I bought looks to be adjustable for what I need. The company I went with is somewhat local and need something pretty quick
Old 01-17-2021, 06:16 PM   #15
The Librarian
The kit for Volvo comes with a linkage rod with an arm for the kickdown cable for automatics which you may or may not need. It also comes with the arm for the carb which is different for DCOE. The shaft is supposed to be smaller in diameter where it goes through the bushing on the body side bracket because the shaft will bind in the stock bushing but they haven't been coming that way lately. You may need to file/grind down the shaft of try to open up the bushing a little.
Redline is close to me and they have 1 kit in the local warehouse. I can get it tomorrow and ship it same day.
You can see the linkage bits in this pic.
Old 01-17-2021, 06:22 PM   #16
89-240gl+t
I don’t need the whole kit, I already have a Weber 32/36, all I’m trying to do is get a new throttle linkage. My car is manual.
Old 01-17-2021, 06:29 PM   #17
The Librarian
I know. I couldn't find a pic of the just the linkage kit.
Old 01-17-2021, 07:58 PM   #18
89-240gl+t
Yeah I looked and couldn't find anything. Already have this on order so going to make it work, im sure that it will be fine.
This is what the stock setup looks like, pretty similar so hopefully she'll do
Old 01-17-2021, 08:15 PM   #19
The Librarian
Do you have the offset lever on the carb already? The kit you bought doesn't come with it and the lever it comes with won't fit the DGV shaft.
Also, the link rods in that kit are too long.
Old 01-17-2021, 08:33 PM   #20
89-240gl+t
This is what it looks like on my car
Old 01-17-2021, 09:32 PM   #21
spock345
spock345's Avatar
Yeah, that doesn't look quite right for the Volvo setup. Probably one of the contributing factors to the previous owner's setup.
The links do look a bit long.
At least the thing is a manual choke carburetor. The electric choke carburetor is annoying to deal with. Especially when you are running the original coil and don't have an easy way to just give power to the choke when the ignition is on (ignition wire is in the armored cable). Also your choke knob will actually do something.
Also if you have cold start hesitation issues hooking up the manifold heater helps a little.
Old 01-17-2021, 09:45 PM   #22
89-240gl+t
Yeah figured the person just slapped it on and didn’t want to do it the right way sadly... hoping that what I ordered will work, if not I’ll just return it and order the correct one. I’m not very familiar with the throttle linkage but I think it’s pretty close to what it needs to be. Should work out
Actually cold start isn’t that bad at all
Old 01-18-2021, 12:24 PM   #23
MikeJr.
Gloss Boss
MikeJr.'s Avatar
I've always liked that green on green color combo. Very cool
Old 01-18-2021, 12:42 PM   #24
89-240gl+t
I was too fond of it at first, but it has definitely grown on me. Excited to get the rest of the interior together to see how it looks
Old 01-18-2021, 01:53 PM   #25
R32RennSport
Outlaw Amazonian
R32RennSport's Avatar
Right on, looks like a great start to a pretty solid purchase! Keep us updated!
Steven
1966 Outlaw Volvo Amazon, 2004 VW R32 Golf
R32RennSport is offline   Reply With Quote
