Old 03-07-2021, 10:34 PM   #1
Dvroofer
Default New user build 91 240 wagon b230f
I’m new to the board. 2 years ago I bought a 1991 240 wagon b230f for my son. As i have some experience with Chevys in the past, i quickly learned they are not the same. We talked the owner down to 800$ because it had been sitting. I attempted to get it to stage 0. After driving it home we ordered a tuned up kit(IPD), motor mounts (shot out), new red water pipe( cracked ), new drive shaft support (busted), fuel pump- in tank and in line. Wire set and plugs, air filter, thermostat, some hoses that needed replaced and 2 racing seats.
[IMG]1-A014-A08-6190-4702-BE02-835-F7-E3-B630-D[/IMG]
[IMG]4-DC17-E9-E-A888-4-F38-8533-77-C5-F085-D457[/IMG]
[IMG]DC646-B7-B-78-DC-4-C0-E-A619-70226-BC729-B7[/IMG]
I also had a hood latch incident that resulted in a new hood and windshied
[IMG]subsource-done-button-uid-2-DD2-AEE5-B69-B-4262-BABA-DDBB5-CE86-DE6-1603064428636-source-other-origi[/IMG]
I Changed the oil and fired her up. Lots of smoke but ran.... barely. I quickly got intimate with various fuel codes. I really wish I had started this post back then and maybe I would have avoided the headaches of buying autozone/ eBay parts. That being said I bought a autozone MAF (duralast), o2 sensor and some yellow top eBay injectors.
[IMG]D3050-C51-F91-A-43-ED-8376-34921-D2-CECB9[/IMG]
This solved some problems but pretty much at the same time I noticed leaks out of the freeze plugs .
I replaced the plugs but was still experiencing overheating. It had been 3 months without him being able to reliably drive the Volvo so my son scored a little truck to dd. He also scored a job in Big Bear so he took off on me leaving the 240.
I ended up replacing the entire pcv system including the canister all hoses flame trap kit. I also replaced the idle control vale and the Ignition control module and fuel relay. I kept having issues with the Maf and found a faulty heater valve for the hot air flap. Replaced it via (ipd). Next issue was a leaking radiator at the hose connection. Someone had cut it so close the hose clamp barely caught.
I read it might be a good idea to also replace the fpr. So in my trip to the local salvage yard down here in Long Beach I found a new fpr and a decent radiator I grabbed a front bumper and rear bumper along with a air dam.Not knowing anything I grabbed a 3bar.
I put it on and the Volvo had a little more life in her but was hesitant had a rough idle and still threw codes. I decided to address to sound of rocks in my exhaust
And found a crumbled pile of junk in my cat. Ordered a new magnaflow high flow bolt on.
At this point she’s running good but overheating.
[IMG]5-EBCE8-DF-6-E1-F-477-E-99-FA-A07907-ECE1-E4[/IMG]
[IMG]F25-C8-EE3-A920-492-C-B028-C4-A8-BD151-A9-A[/IMG]
After hours of scratching my head looking i decided the head gasket must be fried. So i pull the head and what I find is a tiny little freeze plug with a whole in it directly over the front of the block leaking. I figure out the size and cant find it anywhere online. I finally do have it ordered and while I’m at the junkyard I decide to just pull a b230ft head with a t cam already installed. At this point I also started paying attention to the forum so please excuse that i skipped a couple steps.I cleaned up the intake and port match the head I installled the new head and it was a different car.
[IMG]ED6-FEBFC-36-DC-49-EA-BD06-A3-D55-E75-DF78[/IMG][IMG]0-D816984-67-E1-4-AFD-ABFF-EAEEED42-E5-BC[/IMG]
[IMG]4-BBFFA02-957-A-49-A9-B477-860715-DD4-A7-A[/IMG]
[IMG]8-D0-DE36-D-3718-4-B30-ACE2-776-E4687-D3-ED[/IMG]
[IMG]51-AE811-E-D584-4-B0-C-A371-C08-A9-C480-EB6[/IMG]
So it was running decent besides the throttle response so I decided to start with the suspension and get rid of the rattling torque rods. I replaced everything . Koni adjustable struts in front Billstein in the rear sport coils all the way around , pan hard bar, 25mm anti sway bars, chassis braces,strut reinforcement plates, aluminum skid plate all IPD except the struts. Also got some silicone hoses and blue hose clamps.
[IMG]6-A00-D319-09-D4-4137-96-E3-DABA956-B8-E00[/IMG][IMG]BAB2-B774-40-B1-4475-B07-C-9-AAED46-CEEDA[/IMG][IMG]9-DB86404-B877-458-D-BC48-CD80-C434-BB60[/IMG]
[IMG]004-DDABD-6554-4-A13-9-CAF-8-E4259-BAEDAB[/IMG]
[IMG][/IMG]
i still have an acceleration issue from stop. It stumbles on its face then picks up. I have ordered the IPD turbo cam with adjustable gear and am waiting to see if I may remedy it with the timing.I’m still getting a fuel code of 113 bad injector. My injectors measure 16 ohm all the way across. I have came across other posts about the yellow tops having this issue any help would be appreciated. I do have a set of greens with a resistor pack but have not found the proper info on wiring it.
I have currently found turbo donor parts from a 1989 donor car and an extra ezk to send in for core on my ms3 from Linuxman. still trying to source a turbo ecu. Again Im new here and learning as I go any words of wisdom or pushes in the right direction would be greatly appreciated. Heres my only other project ever. very proud
[IMG]C92-AC4-E3-6-BC3-4016-86-F3-90789-F50-F92-A[/IMG][IMG]E817392-D-66-D2-4-F82-BF5-D-161806-DA5573[/IMG]
Dvroofer is online now   Reply With Quote
Old 03-07-2021, 10:40 PM   #2
Dvroofer
duplicate
Old 03-07-2021, 10:51 PM   #3
Dvroofer
please delete
Old 03-08-2021, 12:33 AM   #4
Dvroofer
Default New user 1991 240 wagon project
http://forums.turbobricks.com/showthread.php?t=359423
Old 03-08-2021, 01:01 PM   #5
DavePolyakov
I'm not super experienced, but why the turbo cam over the vx cam for a b230f? I put a vx in my 1986 240 m46 and it revved much happier. After messing around with the adjustable timing gear I put back on the stock timing gear.
DavePolyakov is offline   Reply With Quote
Old 03-08-2021, 05:11 PM   #6
Dvroofer
Buy the time I had come around to buying the cam I kinda had it in my head that I would either be eventually putting a +t on this car or eventually putting a b230ft in her. Either way I would have the cam. I plan on running it with the adjustable cam gear to see the differences if I am unhappy I will put the t cam back in. I will say the t cam over my old m cam was night and day. Thanks for the info. I will have to play around with it myself and see.
Old 03-12-2021, 11:13 PM   #7
Dvroofer
So I got the ipd turbo cam in and it’s running pretty well. Noticed a significant difference in idle and power band. Haven’t laid into it yet though .
Set the gear at 0 and wil start adjusting as soon as I change the break in oil.
Old 03-15-2021, 04:09 AM   #8
Scaramanga
I think your car has some other issue causing the acceleration problem. You should sort that out first instead of trying to cure it with a new cam and adjustable gear. A t-cam without turbo sounds really wrong in my ears.
Volvo 145 1972, 245 GLT 1991
Scaramanga is offline   Reply With Quote
Old 03-15-2021, 11:08 AM   #9
Dvroofer
I did not make my decision lightly. I did research before I bought it and installed it. The n/a motor does great with the cam
. Better acceleration that the t cam throughout the gears even with the adjustable set at 0
http://forums.turbobricks.com/showthread.php?t=19799
I did fix my acceleration issue by clearing my return line with air. But I plan on adding the turbo I would like to upgrade to a set of green giants or some other injectors I have a resistor pack to wire in as well if needed Thanks for the feedback though.
Old 03-26-2021, 09:51 PM   #10
Dvroofer
I have no acquired a
td05-12b turbo
KL racing extreme exhaust manifold
Moroso block off plate
White Mitsimoto oil cooler
Earls oil relocation adapter
Oil lines and cooling lines
Set of 4 white 16v injectors
Nuke performance fuel rail
Nuke performance adjustable fuel pressure regulator
I still need to acquire the proper piping,down pipe and ezk and ecu for my build then I’ll be ready to drill the block And connect everything together. I hope...
I don’t know if I’m forgetting anything.
My ipd turbo cam in my na setup is pretty powerful compared to the m and t cam . I advanced 2.5 degrees and it really surprised me and all my coworkers.
