84B23F
Well-known member
- Feb 11, 2008
- Kansas, USA
Ignition module is receiving a lowered voltage of 2.5 volts, instead of 5 volts, so it is not firing up the coil correctly...hit and miss. CPS is receiving a reduced voltage also. In short, ECU is working, but this voltage drop is the issue.
Question - Would an ECU's voltage regulator fail via reduced voltage output?
I plan to clean up connections Monday, and hot wire ECU's power lead.
thx
thx
