Old 03-25-2019, 10:29 AM   #351
LC4CARL
Aero challenged
LC4CARL's Avatar
OMG! That ain't no Redblock.
@PDXvolvo on IG
Life begins at 10PSI.
Old 03-25-2019, 07:19 PM   #352
Sander
Good news everyone!
Sander's Avatar
That's kind of what I'm aiming for with the sound, to get a real V12 howl.
Finally got the adapter I needed for my new micro Tig torch to fit my machine. Welded 2 of the 4 manifolds today. It works great, although it's a pita to do. The joint where the runners slide into the collectors that needed to be welded is about 10cm into the collector and the hole is pretty small to work from, so you can only ever see what you're welding with 1 eye at the time, so no depth perception. But it worked, should be nice and air tight now.
And my ghetto backpurging setup (which is now on the outside as I'm welding the inside), but it did the trick.
Old 04-02-2019, 03:43 AM   #353
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Mine is bigger
It is btw the big Brother of yours.. celtic 20 mk2
Old 05-01-2019, 08:24 AM   #354
Swedbrick
Swedbrick's Avatar
That's still a pretty tight fit, but crazy access, reminds me of why I need to get myself a TIG Nice work as usual on the headers!
Any projects completed on the new awesome lathe yet?
Volvo 745 - IPD springs, Sways, K-cam, LH2.4, M90 swap, 3.94 diff, track/daily
Old 05-02-2019, 12:52 AM   #355
Sander
Good news everyone!
Sander's Avatar
Thanks! No not much yet, didn't have time lately for anything but I should have some time finally next week. Hope I can finally make a bit of progress there
Old 05-07-2019, 01:59 AM   #356
JerryJS8
der Junge
JerryJS8's Avatar
Progress updates, can't wait!!!!!
- 1992 480 (Renault disaster)
- 1989 745 16v
- 1991 744 (SE) 16v Turbo
Old 05-10-2019, 04:32 PM   #357
Sander
Good news everyone!
Sander's Avatar
Finally could do something. Welded the remaining 2 collectors on the inside, welded the runners to the flanges on the inside too and then ground the mounting surface flat again. Then I welded an extension for the secondaries to clamp onto and finally installed them. I hope they don't have to come off again as they are a pita to install. All other progress was sort of depending on this They needed to be on the car to do the rest that has to route around it etc. All ancillaries can now be installed too. Next up is everything else under the hood.
Old 05-15-2019, 05:58 PM   #358
Sander
Good news everyone!
Sander's Avatar
Got started on the radiator. I would've liked to use the stock S600 one, but it is too wide to fit between the Volvo frame rails so I got an Ebay one with a nicely sized core and a trans cooler and modified it. It's for a Chevy Nova I think, it has an integrated coolant resevoir and cap which I don't like so I modded it to work with an expansion tank. Cut a bit off of the large side and added some to the weird small side. I also made new correctly sized inlet and outlet fittings on it. The stock ones where a lot smaller than the ones on the engine. I still have to add the little hose fitting that goes to the expansion tank. I cut away the stock Volvo radiator mounts and will mount this one between the headlights, about 60mm further forward than stock. This gives me enough space for a decent fan behind it. The S600 oil cooler will live in front of it and fits exactly behind the air intakes in the front air dam.
Old 05-15-2019, 11:36 PM   #359
Vol242vo
Keep it clean...
Vol242vo's Avatar
I’m really looking forward to hearing this thing run. Can’t imagine how fun it’s going to be to drive.
Derek
1980 242
-Project Thread-
Follow on IG: @vol242vo
Old 05-16-2019, 07:15 AM   #360
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
whoa.. nice tig alu skills.. i still need to improve mine
Old 05-21-2019, 11:07 AM   #361
Sander
Good news everyone!
Sander's Avatar
The radiator is in, it's mounted on 4 of these rubber vibration damper things. The top ones are mounted to this plastic panel between the headlights. I moved it forward about 10cm compared to stock so now there is enough space for a fan. Should also still be enough space to add the ac condenser. The oil cooler will live in front of it all at the bottom, behind the air intakes in the front air dam.
Yeah me too, it's progressing a lot slower than I would like at the moment.
Thanks, still have a lot of room for improvement too
Old 05-22-2019, 04:16 AM   #362
rijk
rijk's Avatar
Default Journey
+1. But untill that moment I immensely enjoying the amazing engineering and fabrication skills of Sander. Regarding the resources at his disposal. After reading his last posting I wonder what obstacles he will encounter next. It seems like no obstacle is too high to overcome. Not the destination but the journey and all the victories on the way. Silent with admiration...
The B204FT to B234FT conversion
http://forums.turbobricks.com/showthread.php?t=182821
rijk is offline   Reply With Quote
Old 05-23-2019, 04:54 AM   #363
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Flux capacitor... ;)
That one time, he stood on the toilet to change the batteries in his dumphouseclock ;)
Old 05-23-2019, 10:55 AM   #364
tomasss
tomasss's Avatar
Concentrated insanity... just quietly watching your fabricating skills and loving it.
Volvo 740 Turbo B204GT 1991 >project thread<
It's the oversteer that scares passengers. It's the understeer that scares the driver.
I would rather push a 240 than drive a V70.
lazy PRV engine? Check >this< out
tomasss is offline   Reply With Quote
Old 05-26-2019, 05:02 PM   #365
jmc0369
jmc0369's Avatar
Truly Magnificent!
Member: TBCCS
"Emancipate yourselves from mental slavery; only ourselves can free our minds" - you know who!
"It is no measure of health to be well adjusted to a profoundly sick society" - Jidu Krishnamurti
jmc0369 is offline   Reply With Quote
Old 06-27-2019, 04:47 PM   #366
code5150
Default New to forum I have a V12 in my 240z project.
I have some pictures if you'd like. I decided to run to Nissan ECU's, and still deciding on the transmission, I have a AMG55, a Hemi v8 (with a MB M104 V12 bell housing, and a 1997 S60, and a T56 Magnum. I have enough space to run radiator and electric fans, and most of the engine is behind the strut towers (maybe a foot over). I have Gt500 14" disc's on the front and BMW 330mm vented on the back, also have brembo's from the newer Mercedes S600. I am running a R200 VLSD for now with 3.57:1 i think, 18"x9.5" wheels.
https://www.instagram.com/mdccode515...JR-J-yq4pUOFDM
code5150 is offline   Reply With Quote
Old 06-27-2019, 04:52 PM   #367
code5150
I installed a Mercedes S600 V12 M120 in my 240z I have some pictures if you'd like. I decided to run to Nissan ECU's, and still deciding on the transmission, I have a AMG55, a Hemi v8 (with a MB M104 V12 bell housing, and a 1997 S600, and a T56 Magnum. I have enough space to run radiator and electric fans, and most of the engine is behind the strut towers (maybe a foot over). I have Gt500 14" disc's on the front and BMW 330mm vented on the back, also have brembo's from the newer Mercedes S600. I am running a R200 VLSD for now with 3.57:1 i think, 18"x9.5" wheels. It looks like we did the mounts the same, also not to make you jealous, but the oil pan exactly fit the contour of the crossmember.
Old 06-30-2019, 08:53 PM   #368
JohnLane
Sander I'm eager to see/listen to this one!
Old 07-22-2019, 12:19 PM   #369
Sander
Good news everyone!
Sander's Avatar
Thanks everyone!
Looks like fun too! Manual trans would be cool of course, but a lot of work to do.
Me too! Although I hope it'll be any time soon.
I didn't do anything to the car the last 2 months, mainly because the summer season is the high season at work and I'm building a CNC plasma cutting machine as a sort of in between project to make my life a bit easier. I have so many brackets and levers etc to fabricate for the intake and other stuff on the car that it would be nice to automate it. On that I did make progress. Once that's done, I'll continue with the car again.
Old 07-23-2019, 02:35 PM   #370
JerryJS8
der Junge
JerryJS8's Avatar
I mean, it's not a car update, but I guess we can let this little side projekt slide as progress
Looks great! Can understand the desire for automation
Old 09-16-2019, 12:58 PM   #371
Sander
Good news everyone!
Sander's Avatar
All pictures were dead in this thread thanks to tinypic stopping... I'm almost caught up again with re-uploading everything and editing every post I've made. I'kll continue later. In the meantime, it lives! Well, sort off. Basically all the hardware is done. Finishing up all the settings etc in the software and then it's time to test it. After that I'll clean up the wiring.
Old 09-20-2019, 08:44 PM   #372
JerryJS8
der Junge
JerryJS8's Avatar
Looks fantastic!
But dang if I wouldn't be wary of those chinese eBay special firework Trafos you put in there :-X The fans they come with on average don't last 40 hours and I had a unit blow out on my 3d printer and take my beautiful and expensive 32bit controller with it... Otherwise I've had a failure rate of about 60% and usually needed to replace a dead unit every 6-10 months (150-300 Hours).
About a year ago I bought some Meanwells and am pretty darn happy with the build quality.
Old 09-26-2019, 05:07 PM   #373
Sander
Good news everyone!
Sander's Avatar
Originally Posted by JerryJS8 View Post
Looks fantastic!
Thanks for the heads-up! All the expensive stuff is powered by Meanwells, just the (cheap) servo drivers run off of those power supplies and they are optically isolated from the controller. I'll definitely replace them with something better should one go though. Meanwhile, it lives! I have a few things to still work out and then get it all dialed in and figure out the proper feed rate/amperage/air pressure/cutting height for the materials I'll cut with it, but one of the first things will be all the throttle linkage bits for the 12 itbs. Me not wanting to cut out all those things by hand kinda snowballed into this thing here.
Old 09-30-2019, 08:59 AM   #374
JerryJS8
der Junge
JerryJS8's Avatar
B-E-A-UTIFUL! Inspiring results, as always
Old 09-30-2019, 11:11 AM   #375
Ursan
Bored Member
Ursan's Avatar
All your pictures are gone.
Originally Posted by 740freak View Post
how psi a stock can support?
1990 780t Kind of Modded 1994 945t Pegz, Tintz, Hidz.
"Rear Wheel Drive, the way God intended. If a car is being pulled from the front, doesn't that mean it's being towed?"
"Lister, you are a polyp on the anus of society." - A.J. Rimmer
Ursan is offline   Reply With Quote
