- Nov 12, 2002
Dropping knowledge bombs. Thanks for the insight, Chris.
I'm curious to see if this accumulator idea works out.
I think original idea of the porsche style accumulator is on point and you could probably fab that up pretty quickly. That would get you some breathing room above the oil level and you wouldn't likely need a scavenge pump or anything since it'll still gravity drain.
Not sure if you'd be better with the outlet facing straight down (so your hose run is straight connectors) or at the end, I'd imagine straight down is better.
