Old 08-03-2008, 01:54 PM   #1
volvorod85
volvorod85's Avatar
Default 1031 rear end rebuild specs
Gonna throw a new gearset in my 1031 rear end and wondered if anyone has the specs...backlash for the ring gear, torque for the pinion gear nut...im gona be picking up new bearings and a new crush ring
Mark
1995 E320 wagon AMG 3.6 swap <-- Daily driver
2009 Honda Fit <-- Wifeys ride
1959 Austin Healey Sprite <--something completely different (my project)
1974 Fiat X1/9 <--Mom's little toy (next project)
1982 Olds Custom Cruiser LQ4 <--Dad's beast (current project)
"Driving the old 2 valve 740 is a bit like driving an IKEA wall unit, so leisurely is its acceleration, so angular its lines."
My former brick saved my life 6/25/03....Volvo for Life
volvorod85 is offline   Reply With Quote
Old 02-24-2017, 12:18 AM   #2
CTessmer
I need the same info, about to put a TrueTrac and all new bearings in our 1992 240.
CTessmer is offline   Reply With Quote
Old 02-24-2017, 12:19 AM   #3
CTessmer
The Bentley doesn't have the info in it
Old 02-24-2017, 12:50 AM   #4
gsellstr
Vintage anti-ricer
gsellstr's Avatar
Backlash is .006". Don't have the turning torque spec for the crush sleeve setup off-hand.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 02-24-2017, 01:33 AM   #5
The pocket data booklet has the specs for 1031 on page 115.
http://www.ohio.edu/people/ridgely/v...et_700-900.pdf
Old 02-24-2017, 02:28 AM   #6
CTessmer
You guys ROCK!! Thanks a bunch!!
Old 02-24-2017, 07:59 AM   #7
DET17
Reformed SAABaholic
Run the back lash toward the loose end of the range they give. Greenbook has 100% of the data you need as well as some HOW TO pics.
Pros say they run "street gears" in the .008-.010" range of backlash to avoid generation of heat. Now that pinion setup is another story.... cinch up your britches, you're in for some fun........
Old 09-29-2018, 10:24 AM   #8
CTessmer
Hi, Y'all. It's been quite awhile but I'm finally ready to assemble my diff. The problem I'm running into is that I am finding discrepancies in all of the specs I'm finding everywhere. Dana 30 specs show 12-15 in/lb torsional movement on pinion while the pocket data book shows 21-30 in/lb for new bearings. Does anyone know the exact specs for a 1031 axle? My TrueTrac is ready to be buttoned up but I don't want to grind the gears all to hell the first time i drive it or smoke my bearings. HELP!! (please) BTW, it's in a 1992 240.
Old 09-29-2018, 01:58 PM   #9
DET17
Reformed SAABaholic
1031 pinion specs should match the 1041, but double check to confirm bearing set is the same. I've linked an early 960 1041 online spec set in a thread earlier this year.... can't remember if here OR in Performance. Search the webs, and otherwise find a green book for the 1031. You might also check the Anthony Hyde Volvo pages down under.... I think he details all the pinion specs.
Old 09-29-2018, 08:58 PM   #10
freevolvos
freevolvos's Avatar
wouldn't dana 30 be the same? o.p. look around they may sell a solid (crush) sleeve and shim kit they do for the 12 bolt way better than crushing those crush sleeves..... way better
Old 10-02-2018, 11:21 AM   #11
GTJordan
Been here for too long
GTJordan's Avatar
I had a small solid sleeve made to replace the crush sleeve using hiperfauto's specs in another thread. Should make things a bit stronger.
I haven't gone digging for a torque spec on the pinion yet though.
Jordan
Old 10-09-2018, 11:50 PM   #12
Wren
Porkchop Sandwiches
Wren's Avatar
I believe that I've got a rear axle greenbook in my stash if it would be helpful to you.
Old 10-15-2018, 02:14 PM   #13
DrZiplok
DrZiplok's Avatar
... and just when I need it, k-jet.org is gone so the greenbook PDFs aren't there anymore. Argh!
DrZiplok is offline   Reply With Quote
Old 10-16-2018, 10:42 PM   #14
oifish
I'm feeling extra zazzzy
oifish's Avatar
will this help?
1990 Volvo 744T M46 - Daily Driver - ( ͡° ͜ʖ ͡°)
1996 Chevy C1500
__________________________________________
Buy/Sell Feedback
oifish is offline   Reply With Quote
