Old 10-11-2018, 07:26 PM   #1
nelsonmouellic
Default Amazon/B20 mystery exhaust support bracket.
I've recently installed the Simons sport exhaust on my 122 wagon, and am perplexed as to where the exhaust bracket is supposed to mount to. The bracket in question looks like this:
Nothing along the oilpan or bellhousing appears to fit
Any help would be appreciated!
1967 122s Wagon Project
Instagram: @67AmazonWagon & @NelsonMouellic - www.mouellic.com
nelsonmouellic is offline   Reply With Quote
Old 10-11-2018, 07:41 PM   #2
It goes between the trans mount bracket and transmission. There should be a clamp that holds the down pipe to that bracket.
Old 10-14-2018, 05:34 AM   #3
alschnertz
Enough already!
alschnertz's Avatar
Isn't it just a u-bolt that goes through th bracket?
Old 10-14-2018, 12:41 PM   #4
The original bracket uses this style clamp.
I'm not sure what type of clamp Simons uses.
Old 10-14-2018, 06:16 PM   #5
nelsonmouellic
Oh interesting. The previous owner swapped to a B20F with an M41, and I suspect the trans support might have been changed as part fo the swap.
The Simons clamp looks like this:
Does the ear on the bracket face forward or backwards? I can't find a diagram or picture of it installed anywhere.
Old 10-14-2018, 06:47 PM   #6
The ear faces down and forward with the long part of the bracket toward the passenger side.
The clamp circled is the correct one for an Amazon. I posted a pic of the 140 clamp by mistake. A stock one looks like this.
The Simons pipe is larger so they use a different clamp.
