Old 10-11-2018, 07:46 PM   #176
Pillow
Sleazebag 7-9 Owner
Pillow's Avatar
More thread resurrection!
Stuck on the PILOT BEARING... Any ideas folks?
Everything else is as above #172 and looks good.
#79WDP
Old 10-12-2018, 09:23 AM   #177
stick70
All the gauges
stick70's Avatar
I didn't read your previous posts, what year/model is your engine from? One takes a bushing, the other a bearing. I'll dig up the part number for the bearing, it's in one of Alex Buchka's threads. I've done it both ways, the bushing I used is here:
https://forums.tbforums.com/showpost...7&postcount=91
Old 10-16-2018, 02:24 PM   #178
VictorianBuilder
Default I can't squeeze the M90 in my English Hot Rod...
Hello, new here. Read all the posts with great interest, but can't find an answer to this.........
Is it true I can get the 960 AW 30-40 Auto box on the back of my 5 cylinder 2.4turbo whiteblock?
I am struggling with clutch space.....
Currently running a 4 pot Ford and 5 speed T9 Ford box. Car goes to the chassis shop at end of November........
Based in London
VictorianBuilder is offline   Reply With Quote
Old 10-17-2018, 03:00 PM   #179
stick70
All the gauges
stick70's Avatar
I don't see why not. I'm running a 960 bellhousing on my wagon to mate it to the T5 trans
Old 12-11-2018, 08:48 PM   #180
oldschoolvolvo
oldschoolvolvo's Avatar
Originally Posted by Pillow View Post
If anyone has completed this on TB please chime in and share your journey!
+1
Has anyone completed the whiteblock + T5 trans conversion via the DeeWorks adapter?
The whiteblock/RWD swaps that I am aware of do not use the T5.
Homer 244: 5cyl + M90
http://forums.turbobricks.com/showthread.php?t=219119
Buchka 242: 6cyl + Toyota W58
http://forums.turbobricks.com/showthread.php?t=310055
daButcher 242: 6cyl + AW30-40
http://forums.turbobricks.com/showthread.php?t=41789
v240tic 242: 6cyl + AW30-40
http://www.turbobricks.org/forums/sh...d.php?t=110561
broke4speed 244: 6cyl + AW30-40
https://forums.tbforums.com/showthread.php?t=323599
Edit:
fullbanana 242: 5cyl + Getrag 265
https://forums.tbforums.com/showthread.php?t=284730
stick70 Amazon wagon: 5cyl + T5
https://forums.tbforums.com/showthread.php?t=251079
tentshedtrev 242: 5cyl + T5
IG @analogluxury
Lankku 245: 6cyl + M90 / BMW trans
https://forums.tbforums.com/showthread.php?t=309746
-Mike
1998 V70 T5
|Feedback|
Old 12-12-2018, 02:15 PM   #181
RvolvoR
stick70 has a t5 behind the 5 cyl in his 122.
I am working on a b6284t + R154/AR5 swap currently. Should have it up and going by march/april.
RvolvoR is online now   Reply With Quote
Old 12-12-2018, 09:12 PM   #182
Tentshedtrev
Tentshedtrev's Avatar
I have a t5 to t5 in my 242 project, kelvar 850r clutch disc, singlemass 850r flywheel, Tilton hydraulic throwout. All bolted together will no strange issues, Rodger makes good stuff.
Life is too short to stay redblock..
1990 740 SE, Eaton m90 + Holset he351, twincharged b230F drift car
1983 242 turbo t5 whiteblock swap (in progress) (He351, MS3x, WC T5)
1983 244 (on blocks, currently parts storage)
1990 245 Mitsubishi 4D56 turbo diesel km132 transmission, water/meth
1983 245 m46 b230f Stahl header Toyota 4age ITBs MS2extra
Tentshedtrev is offline   Reply With Quote
Old 12-13-2018, 07:59 AM   #183
DET17
Reformed SAABaholic
Check with the "Fullbanana".... he either has a T5 or a Getrag 265 behind his whiteblocked 242.
Old 12-13-2018, 09:40 AM   #184
oldschoolvolvo
Cool, do you have a build thread anywhere?
Which Tilton hydro TOB are you using?
Edit: found you on IG (@analogluxury)
