Old 09-28-2018, 06:27 PM   #26
So does this car start, or not? I can't understand....
Old 09-28-2018, 06:58 PM   #27
arjunsw
No not yet, im fairly certain its bad fuel pumps. It worked off starting fluid, so i looked more into the fuel system. The fuel pump relay energizes when i crank, so its not burnt. The main fuel pump is getting 12 V even when I bypass the fuel relay, but it only spins once I tap it with a rubber mallet. If I tap it with a rubber mallet, get it spinning for a bit, and crank, it'll start up fine, but will stall after a couple seconds once the pump stops spinning again. I also couldn't hear the in-tank pump when i put my ear in the gas filler neck.
The fuel pump connections were also falling apart in my hands, so i dont thinks it been changed recently, possibly ever.
arjunsw is offline   Reply With Quote
Old 10-05-2018, 09:46 PM   #28
Bready
board deviant
Bready's Avatar
Replace fuel pump fuse - regardless of what it looks like - and clean the terminals.
At least half of 240 no starts are the result of that fuse.
Costs nothing and it saves you the hassle of the rest of the stuff if that was the issue.
Originally Posted by Pennybridge Pioneer View Post
Just because you didn't experience something growing up doesn't mean other people didn't. Case in point: I can't remember ever being a total moron, but that doesn't mean you aren't one.
Someone said “gavin” three times, and a troll appeared.
Keep your minds out of my pants.
Originally Posted by centason View Post
Bready is right.
Kalazdar - (3/23/83 to 5/12/03)
MUST READ!!! https://cleantechnica.com/2017/04/24...-adds-screwed/
Bready is offline   Reply With Quote
Old 10-05-2018, 09:47 PM   #29
Bready
board deviant
Bready's Avatar
*Sorry missed 12v at pump.
