Old 10-03-2018, 12:56 AM   #1
Jack
Banned
Jack's Avatar
Default 240 accessory bushings - what to use ?
blue ipd ones wore out faster than a china fuel pump
Yoshifab ones wore out after 15-20k miles
what else is there ? new OEM ones anygood still ?
Old 10-03-2018, 01:11 AM   #2
300+hp on the shelf club
I like the rubber ones. Maybe try shopping for Beck Arnley? They are usually reboxed oem.
Old 10-03-2018, 07:18 AM   #3
Vincent Gagnon
Vincent Gagnon's Avatar
I used these, not a lot of mileage on them, so I can't talk about long term, but for this price... and, as a bonus, it gives cancer and reproductive harm to California customers.
https://www.rockauto.com/en/moreinfo...287075&jsn=403
Old 10-03-2018, 08:18 AM   #4
J_Jones
J_Jones's Avatar
The aluminum ones? If so, surprised.
Old 10-03-2018, 08:37 AM   #5
57plymouth
57plymouth's Avatar
I was going to suggest the Yoshi aluminum ones. I had a blue IPD fail two months ago. If you had a Yoshi aluminum fail, then I don't know what else there is. Maybe have someone make some out of bronze or brass on a lathe?
Sven, the 1991 245
Old 10-03-2018, 09:32 AM   #6
oldschoolvolvo
oldschoolvolvo's Avatar
What was the failure mode on the Yoshifab aluminum bushings?
-Mike
1998 V70 T5
|Feedback|
Old 10-03-2018, 09:44 AM   #7
Restore it to stock for another ~20 years of driving pleasure.
Old 10-03-2018, 10:16 AM   #8
DMFWallace
Ignoramus Bigotus
+1
'90 244 - Too many memories to crush
'92 944T - Need any 940 parts?
'96 854 GLT - Not mine any more but still in the family
'92 245 - For Sale?
'97 854R - Waiting to get fixed
'06 XC90 V8 - Family Hauler - Wifemobile
'04 XC70 - Impulse buy of the year
Feedback:http://forums.turbobricks.com/showth...ght=dmfwallace
DMFWallace is offline   Reply With Quote
Old 10-03-2018, 01:09 PM   #9
Jack
Banned
Jack's Avatar
The aluminum ones get smaller. Might have thrown them out
Old 10-03-2018, 01:10 PM   #10
Jack
Banned
Jack's Avatar
Thatís what Iím thinking but is OeM any good still ?
Old 10-03-2018, 01:32 PM   #11
Wren
Porkchop Sandwiches
Wren's Avatar
The blue Uro ones that FCP sold were great until they weren't.
Anyone try the SuperPro urethane ones?
Old 10-03-2018, 01:56 PM   #12
Jack
Banned
Jack's Avatar
alternator
Old 10-03-2018, 02:31 PM   #13
Vincent Gagnon
Old 10-03-2018, 02:33 PM   #14
Vincent Gagnon
Do you have a rough estimate of how long it took?
Old 10-03-2018, 02:34 PM   #15
Jack
Banned
Jack's Avatar
Originally Posted by Vincent Gagnon View Post
bracket is/was fine I put used oe bushings and seems to be fine ...
I think I just answered my question
Maybe yoshi and ipd poly wear out because they allow rotation while stock "sticks" in housing
Old 10-03-2018, 02:36 PM   #16
Jack
Banned
Jack's Avatar
Old 10-03-2018, 03:14 PM   #17
Rusty_ratchet
Rusty_ratchet's Avatar
I put Meyle rubber bushings on my car about 2 years/30k miles ago. The PS and AC bushings still look fine, but the alternator bushings were starting to deform so I replaced them with Volvo bushings. The Volvo and Meyle rubber look the same to me.
Rusty_ratchet is offline   Reply With Quote
Old 10-03-2018, 03:29 PM   #18
Vincent Gagnon
I just have a special interest in those bushings (especially the alternator).
This summer, I was working butt**** nowhere (60 miles down a logging road around Horsefly,BC) and the alternator bushings (probably the original ones) deformed and broke the adjusment bracket. I had to drive about 150 miles like this, worked surprisingly good.
Old 10-03-2018, 04:02 PM   #19
oldschoolvolvo
Wow, those bushings are beat.
You are saying that type of wear came from installing them once and driving 15-20k?
Old 10-03-2018, 04:09 PM   #20
Jack
Banned
Jack's Avatar
Thats a great solution
I hate changing these bushings especially on ac/ps side
yes
Old 10-03-2018, 06:37 PM   #21
lummert
lummert's Avatar
Not sure how those aluminum bushings could wear out unless the bolts weren't properly tightened. The aluminum bushings need to be press fit (0.002" larger than the bore). Put the bushing in freezer to shrink before installing.
Old 10-03-2018, 06:43 PM   #22
Stock it to restore.
Old 10-03-2018, 06:47 PM   #23
quillc
yv1a.com
quillc's Avatar
On my DD (40k miles/year), I've gone through several iterations.
My original rubber bushings were beat when I put the car together. I figured 'poly is better' so bought the iPD bushings.
1. iPD poly bushings. They lasted a year or so and that was it.
2. Yoshi aluminum bushings. They also lasted about a year.
3. Yoshi aluminum bushings welded to the arms. Again, about a year (wore out where the bolt passes through).
4. Stock rubber bushings. Lasted about two years.
5. Replacement rubber bushings with a washer added to the outside of each bushing. Three years and counting. I also added a steel spacer on the pivot of the alternator. Blue Loctite on the bracket bolts into the block help prevent them from getting loose (and falling out).
The washer seemed to do the trick. I seem to recall it being a 7/16" fender washer (but you should verify). I suspect its because the force is spread over the face of the bushing rather than just being concentrated at the steel insert. Compressing the bushing slightly helps keep it in full contact with the bushing bore and prevents it from squirming (deforming) under load too much.
Overall, I've been terribly unimpressed with the longevity of any of the poly materials in automotive applications. Mobile One synthetic seems to degrade the material pretty readily and keeping these old motors leak-free is unrealistic.
The conclusion that I've come too is that these old V belts that we use need some minor amount of flex in the pully system that they run in to absorb the harmonic vibrations that they are subject too. If the material is too hard, the bushing doesn't absorb enough and wears rapidly as the cyclic motion of the vibration moves the bushing against the steel bolt/bushing center. The key is to have enough vibration absorption while preventing rotational movement to limit wear.
Chris
www.yv1a.com
Old 10-03-2018, 07:31 PM   #24
Jack
Banned
Jack's Avatar
Shiet was tight
They just fit, some slightly tight some not, even yoghurt says it
See below
Thought about #3 so thatís good to know
Would switch to 7/9 accessory bracket but canít on the 16v with dizzy in block
Will do #4 thank you very much. Awesome write up
What brand ?
Old 10-03-2018, 07:39 PM   #25
quillc
yv1a.com
quillc's Avatar
What brand ?
Whatever it was that Rock Auto (I think) sent me.
I did the same thing (the washers) to the 91 245 that my wife drives on an old set of rubber bushings. Doesn't seem to matter brand as long as you use the washers.
The alternator seems to be the worst/highest wear location.
the #4 scenario was with Volvo NOS bushings (made in Germany).
The #5 scenario was with the 'whatever' brand bushings that Rock Auto sent. They were the cheapest ones that I could find. I had given up and was just going to replace them every year as a matter of course. With the washers and steel spacer in the alternator I haven't had too.
